Matlab install issues
I tried what is mentioned on another topic on matlab 2021b (sorry, can’t insert links) (unzip -X -K) and I get these errors:
finishing deferred symbolic links:
  matlab_2021a_installer/bin/glnxa64/libprotoc.so -> libprotoc.so.3.6.1
symlink error: Operation not permitted
  matlab_2021a_installer/bin/glnxa64/libCppMicroServices.so -> libCppMicroServices.so.3.6.1
  matlab_2021a_installer/bin/glnxa64/libfreetype.so.6 -> libfreetype.so.6.16.0
  matlab_2021a_installer/bin/glnxa64/libicuuc.so.67 -> libicuuc.so.67.1
  matlab_2021a_installer/bin/glnxa64/libcrypto.so.1 -> libcrypto-mw.so.1.1
  matlab_2021a_installer/bin/glnxa64/libunwind.so.8 -> libunwind.so.8.0.1
  matlab_2021a_installer/bin/glnxa64/libicudata.so.67 -> libicudata.so.67.1
  matlab_2021a_installer/bin/glnxa64/libicuio.so.67 -> libicuio.so.67.1
  matlab_2021a_installer/bin/glnxa64/libXss.so.1 -> libXss.so.1.0.0
  matlab_2021a_installer/bin/glnxa64/libssl.so.1 -> libssl-mw.so.1.1
  matlab_2021a_installer/bin/glnxa64/libprotobuf3.so -> libprotobuf3.so.3.6.1
  matlab_2021a_installer/bin/glnxa64/libicui18n.so.67 -> libicui18n.so.67.1
  matlab_2021a_installer/bin/glnxa64/libConfigurationAdmin.so -> libConfigurationAdmin.so.1.0.0
  matlab_2021a_installer/bin/glnxa64/libexpat.so.1 -> libexpat.so.1.6.11
  matlab_2021a_installer/bin/glnxa64/libDeclarativeServices.so -> libDeclarativeServices.so.1.1.1
  matlab_2021a_installer/cefclient/sys/os/glnxa64/libgtk-x11-2.0.so.0 -> libgtk-x11-2.0.so.0.2400.31
  matlab_2021a_installer/cefclient/sys/os/glnxa64/libgdk-x11-2.0.so.0 -> libgdk-x11-2.0.so.0.2400.31
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libffi.so.5 -> libffi.so.5.0.2
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libglib-2.0.so.0 -> libglib-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libgthread-2.0.so.0 -> libgthread-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libglib-2.0.so -> libglib-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libgmodule-2.0.so.0 -> libgmodule-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libffi.so -> libffi.so.5.0.2
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libgobject-2.0.so -> libgobject-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libgio-2.0.so -> libgio-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libgobject-2.0.so.0 -> libgobject-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libgmodule-2.0.so -> libgmodule-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libgthread-2.0.so -> libgthread-2.0.so.0.5600.1
  matlab_2021a_installer/cefclient/sys/glib/glnxa64/libgio-2.0.so.0 -> libgio-2.0.so.0.5600.1
  matlab_2021a_installer/sys/opengl/lib/glnxa64/libGLU.so.1 -> libGLU.so.1.3.1
  matlab_2021a_installer/sys/opengl/lib/glnxa64/libGL.so.1 -> libGL.so.1.6.0
  matlab_2021a_installer/sys/os/glnxa64/orig/libstdc++.so.6 -> libstdc++.so.6.0.25
  matlab_2021a_installer/sys/os/glnxa64/libstdc++.so.6 -> libstdc++.so.6.0.25
Then I launched ./install as root and I got a libicu.67 error. I installed icu67 AUR package and now I obtain this:
./install
/mnt/DATA/Documents/Downloads/matlab_2021a_installer2/bin/glnxa64/install_unix: symbol lookup error: /mnt/DATA/Documents/Downloads/matlab_2021a_installer2/bin/glnxa64/libmwi18n.so: undefined symbol: UCNV_FROM_U_CALLBACK_ESCAPE_WITH_INVISIBLE_CHARS_67
Doing all the same with the latest version 2022a I got the same, but libicu69 error and the error launching ./install:
./install
/mnt/DATA/Documents/Downloads/matlab_2022a_installer/bin/glnxa64/MathWorksProductInstaller: symbol lookup error: /mnt/DATA/Documents/Downloads/matlab_2022a_installer/bin/glnxa64/libmwi18n.so: undefined symbol: UCNV_FROM_U_CALLBACK_ESCAPE_WITH_INVISIBLE_CHARS_69
Note the on version 2021a the error ends with 67, while with 2022a is 69.
I had matlab 2021a installed on my system, but after the big manjaro updates of some days ago there was something broken, so I tried to reinstall with this result.
Please help me to solve it.
Tnx
Hello @Teo76 and welcome :wink:
Looks like there is PKGBUILD for it: PKGBUILD - aur.git - AUR Package Repositories and according to the comment here: AUR (en) - matlab it should work with 2022a.
git clone https://aur.archlinux.org/matlab.git
cd matlab
copy the files matlab.fik, matlab.lic and matlab.tar into that folder and run:
makepkg --syncdeps --install
It creates a native package for it and installs it. That is the preferred way.
However, maybe you find a solution at the script.
Thanks @megavolt
I have followed the instruction, got .fik and .lic file, but cannot get the .tar file since to obtain it I have to run matlab installer and I obtain the same errors, both symlink while unzipping (no idea if relevant) and while installing
@Teo76 Since I cannot get the Installer, I also cannot reproduce anything for testing. So I cannot help here. I guess nobody will able to help here without testing it locally.
It is not clear, which libs it depends on.
ldd -v binary_file
This seems to be a lib from matlab:
libmwi18n.so
How is it linked?
ldd -v libmwi18n.so
ldd -v libmwi18n.so                        ✔
	linux-vdso.so.1 (0x00007fff9bfb7000)
	libmwresource_core.so => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwresource_core.so (0x00007f7309b41000)
	libmwfoundation_filesystem.so => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwfoundation_filesystem.so (0x00007f7309b21000)
	libdl.so.2 => /usr/lib/libdl.so.2 (0x00007f7309aec000)
	libmwcpp11compat.so => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwcpp11compat.so (0x00007f7309ac8000)
	libmwboost_filesystem.so.1.75.0 => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwboost_filesystem.so.1.75.0 (0x00007f7309800000)
	libmwboost_thread.so.1.75.0 => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwboost_thread.so.1.75.0 (0x00007f7309400000)
	libexpat.so.1 => /usr/lib/libexpat.so.1 (0x00007f7309a95000)
	libicuuc.so.69 => /usr/lib/libicuuc.so.69 (0x00007f73091fa000)
	libicui18n.so.69 => /usr/lib/libicui18n.so.69 (0x00007f7308eba000)
	libpthread.so.0 => /usr/lib/libpthread.so.0 (0x00007f7309a90000)
	libstdc++.so.6 => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6 (0x00007f730962a000)
	libgcc_s.so.1 => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libgcc_s.so.1 (0x00007f7309a74000)
	libc.so.6 => /usr/lib/libc.so.6 (0x00007f7308cb0000)
	/usr/lib64/ld-linux-x86-64.so.2 (0x00007f7309ccf000)
	libmwlocale.so => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwlocale.so (0x00007f7309a6f000)
	librt.so.1 => /usr/lib/librt.so.1 (0x00007f7309a6a000)
	libm.so.6 => /usr/lib/libm.so.6 (0x00007f7308bc8000)
	libicudata.so.69 => /usr/lib/libicudata.so.69 (0x00007f730706f000)
	Version information:
	./libmwi18n.so:
		libstdc++.so.6 (GLIBCXX_3.4.18) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.3) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.14) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.2) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.26) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.15) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.7) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.8) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.21) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.9) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.20) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.9) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4.11) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libstdc++.so.6 (CXXABI_1.3.5) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6
		libc.so.6 (GLIBC_2.3) => /usr/lib/libc.so.6
		libc.so.6 (GLIBC_2.2.5) => /usr/lib/libc.so.6
		libc.so.6 (GLIBC_2.4) => /usr/lib/libc.so.6
		libc.so.6 (GLIBC_2.14) => /usr/lib/libc.so.6
		ld-linux-x86-64.so.2 (GLIBC_2.3) => /usr/lib64/ld-linux-x86-64.so.2
		libgcc_s.so.1 (GCC_3.0) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libgcc_s.so.1
		libdl.so.2 (GLIBC_2.2.5) => /usr/lib/libdl.so.2
		libpthread.so.0 (GLIBC_2.2.5) => /usr/lib/libpthread.so.0
	/mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwresource_core.so:
	/mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwfoundation_filesystem.so:
	/usr/lib/libdl.so.2:
	/mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwcpp11compat.so:
	/mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwboost_filesystem.so.1.75.0:
		libc.so.6 (GLIBC_2.6) => /usr/lib/libc.so.6
	/mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwboost_thread.so.1.75.0:
		libpthread.so.0 (GLIBC_2.3.3) => /usr/lib/libpthread.so.0
		libpthread.so.0 (GLIBC_2.3.2) => /usr/lib/libpthread.so.0
	/usr/lib/libexpat.so.1:
		libc.so.6 (GLIBC_2.25) => /usr/lib/libc.so.6
		libc.so.6 (GLIBC_2.3.4) => /usr/lib/libc.so.6
	/usr/lib/libicuuc.so.69:
		libm.so.6 (GLIBC_2.29) => /usr/lib/libm.so.6
		libm.so.6 (GLIBC_2.2.5) => /usr/lib/libm.so.6
		libc.so.6 (GLIBC_2.33) => /usr/lib/libc.so.6
		libc.so.6 (GLIBC_2.34) => /usr/lib/libc.so.6
	/usr/lib/libicui18n.so.69:
	/usr/lib/libpthread.so.0:
	/mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libstdc++.so.6:
		libgcc_s.so.1 (GCC_4.2.0) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libgcc_s.so.1
		libgcc_s.so.1 (GCC_3.4) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libgcc_s.so.1
		libgcc_s.so.1 (GCC_3.3) => /mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libgcc_s.so.1
		libc.so.6 (GLIBC_2.16) => /usr/lib/libc.so.6
		libc.so.6 (GLIBC_2.3.2) => /usr/lib/libc.so.6
	/mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libgcc_s.so.1:
	/usr/lib/libc.so.6:
		ld-linux-x86-64.so.2 (GLIBC_2.2.5) => /usr/lib64/ld-linux-x86-64.so.2
		ld-linux-x86-64.so.2 (GLIBC_PRIVATE) => /usr/lib64/ld-linux-x86-64.so.2
	/mnt/DATA/Documents/Downloads/MATLABROOT/bin/glnxa64/./libmwlocale.so:
	/usr/lib/librt.so.1:
		libc.so.6 (GLIBC_PRIVATE) => /usr/lib/libc.so.6
	/usr/lib/libm.so.6:
