Materiav2: My awesome theme
Screenshots of each style can be found on the project page.
My current style on XFCE:
(Autohide panel)
I'd appreciate someone helping me make a Kvantum theme for this so that KDE users can also enjoy it.
@gsbhasin123 what is the license? The same as original materia theme? I want import in Manjaro .. Hope you maintain this for future :wink:
No, it's MIT. I should add it, thanks! What do you mean import in Manjaro...
And yes, I do plan to maintain this for a long time. If you like it, please donate here: https://www.paypal.me/materiav2?locale.x=en_US
I can make a package and import in our repository ( Manjaro Repository ) .. only after a quick surfing in your repository your themes are inconsistent. All of your theme are referenced as Materia and not match with your theme name like materiav2-dark-maia for example. I think you hav to rename all folders and also into index.theme you need to match with it.. If you correct all i can reconsider to import in Manjaro but for now i have to decline my previous post...
I'm not sure what you mean. What should I rename ? If you want I can give you access and you can do it yourself...
Hey so I figured out what you mean and have started renaming files. Dark is done, now to do to light... :wink: When can you import it? And why rename all folders i dont get that...
Light's also done!
@Ste74 everything is renamed check description, new link, can you import to manjaro now?
I actually started working on a materia theme for kde/kvantum ... I might be able to help .. but the curves kill me, I cant stand them - the reason I bring it up is that it seems in your photos that only some windows have curved corners. Why is that ?
@cscs: XFWM limitation afaik. I've updated the desc link, and I now have a couple variants without curves or low curves :wink:
Anyways for a short time I'm on Ubuntu Budgie, which is great too, but I'll be back on Manjaro (Budgie, now that I found it so epic) ASAP!
And I'd truly appreciate the help.
@Ste74: Now i updated everything and changed the index.theme etc, can you consider importing it to the Manjaro repo? Or atleast the AUR because i dont know how to make aur packages?
Ok, i look into it..
There's a fork of compton that adds rounded corners to all windows. Just like KDE
https://aur.archlinux.org/packages/compton-rounded-corners/
Ooh nice!
I need help with making a PKGBUILD, pls help
Ste74 wrote 8 h ago, so
STOP-Dev-sgs-50
in the meantime read this :wink:
https://wiki.manjaro.org/index.php?title=Create_Manjaro_Packages
because Yorper's asleep in Australia right now. :smiley:
:+1: i like this pic...
here you go @gsbhasin123
Imported in Manjaro adding at AUR later..
Thanks so much! Appreciate it
@Ste74 please help create an aur package too and send me link, i have friends who use stock arch and want this theme in package management. also in aur can you give me permission
http://aur.archlinux.org/packages/materiav2-gtk-theme
Was that you? THANKS!
