Continuing the discussion from Keyboard missing after suspend:
^in case our troubles are related
It has happened within past month of testing updates, i cannot input my password into MATE’s lock-screen after suspend-resume. Problem is apparent on linux41 (my regular kernel), linux49 and linux410 (current kernel for log outputs). I can however use my keyboard to switch between tty shells and restart lightdm service, losing my work obviously.
Problem cannot be reproduced on i3-gaps session which uses xautolock. Here i can suspend-resume and xautolock lets me type my password.
I have attached following three logs in two different scenarios doing boot > suspend > resume
dmesg > dmesg-*.txt
journalctl -b -p 3 > log-*.txt
journalctl -b -p 5 > toomuchlog-*.txt
1. i3-gaps (no problem)
2. MATE
dmesg-mate
log-mate
toomuchlog-mate
Following MATE specific packages were upgraded
[2017-01-20 23:21] [ALPM] upgraded mate-session-manager (1.16.0-2 -> 1.16.0-3)
[2017-02-13 03:31] [ALPM] upgraded mate-settings-daemon-gtk3 (1.16.0-2 -> 1.16.1-1)
[2017-02-13 03:31] [ALPM] upgraded mate-control-center-gtk3 (1.16.0-1 -> 1.16.1-1)
[2017-02-13 03:31] [ALPM] upgraded mate-panel-gtk3 (1.16.0-1 -> 1.16.1-1)
[2017-02-13 03:31] [ALPM] upgraded mate-power-manager-gtk3 (1.16.0-2 -> 1.16.1-2)
[2017-02-13 03:31] [ALPM] upgraded mate-session-manager (1.16.0-3 -> 1.16.1-1)
[2017-02-13 03:31] [ALPM] upgraded mate-screensaver-gtk3 (1.16.0-2 -> 1.16.1-1)
[2017-02-13 03:31] [ALPM] upgraded mate-sensors-applet-gtk3 (1.16.0-1 -> 1.16.1-1)
[2017-02-13 03:31] [ALPM] upgraded mate-terminal (1.16.1-2 -> 1.16.2-1)
[2017-02-21 12:14] [ALPM] upgraded mate-power-manager-gtk3 (1.16.1-2 -> 1.16.2-1)
System info
System: Host: 0ne-punch Kernel: 4.10.0-1-MANJARO x86_64 (64 bit gcc: 6.3.1) Desktop: MATE 1.16.1 (Gtk 3.22.8)
Distro: Manjaro Linux
Machine: Device: laptop System: LENOVO product: 2958 v: Lenovo G550
Mobo: LENOVO model: NITU1 v: REFERENCE BIOS: LENOVO v: 18CN44WW(V2.53) date: 04/19/2010
CPU: Dual core Pentium T4300 (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 ssse3) bmips: 8382
clock speeds: max: 2100 MHz 1: 2100 MHz 2: 2100 MHz
Graphics: Card: Intel Mobile 4 Series Integrated Graphics Controller bus-ID: 00:02.0
Display Server: X.Org 1.19.1 driver: intel Resolution: 1366x768@60.07hz
GLX Renderer: Mesa DRI Mobile Intel GM45 Express GLX Version: 2.1 Mesa 17.0.0 Direct Rendering: Yes
Audio: Card Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture v: k4.10.0-1-MANJARO
Network: Card-1: Broadcom Limited BCM4312 802.11b/g LP-PHY driver: b43-pci-bridge bus-ID: 04:00.0
Card-2: Broadcom Limited NetLink BCM5906M Fast Ethernet PCI Express
driver: tg3 v: 3.137 bus-ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Drives: HDD Total Size: 500.1GB (59.7% used)
ID-1: /dev/sda model: HGST_HTS725050A7 size: 500.1GB
Partition: ID-1: / size: 35G used: 25G (75%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 35G used: 17G (52%) fs: ext4 dev: /dev/sda2
ID-3: swap-1 size: 4.40GB used: 0.00GB (0%) fs: swap dev: /dev/sda7
Sensors: System Temperatures: cpu: 52.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 195 Uptime: 28 min Memory: 1118.0/3889.5MB Init: systemd Gcc sys: 6.3.1
Client: Shell (zsh 5.3.1) inxi: 2.3.8
