I want to make xcompmgr as default compositor. I have blank screen problem while screen sharing in Zoom.
I noticed xdpyinfo isn’t installed, which shouldn’t be a problem, at least I don’t think it should. But I’m not on that, so let’s install it. It’s in the extra
repository:
$ pamac search xdpyinfo
xorg-xdpyinfo 1.3.4-1 [Installed] extra
Display information utility for X
…and can be installed using:
pamac install xorg-xdpyinfo
…and them check and follow the install guide:
https://wiki.archlinux.org/title/Xcompmgr#Installation
…again.
Edit:
I suspect you’ll have to do this part:
If there is no output, add the Composite option to the Extensions section of xorg.conf:
/etc/X11/xorg.conf
Section "Extensions" Option "Composite" "true" EndSection
…although I could be wrong.
No, see this ZOOM blank screen issue.
~ pamac search xdpyinfo ✔
xorg-xdpyinfo 1.3.4-1 extra
~ pamac install xorg-xdpyinfo ✔
Preparing...
Authenticating as: raman
Password:
Warning: pop-gtk-theme: local (5.5.1+12+7ba5da8-1) is newer than extra (5.5.1.r6.190b5cce-1)
Resolving dependencies...
Checking inter-conflicts...
To install (1):
xorg-xdpyinfo 1.3.4-1 extra 16.5 kB
Total download size: 16.5 kB
Total installed size: 34.0 kB
Apply transaction ? [y/N] y
Download of xorg-xdpyinfo (1.3.4-1) started
Download of xorg-xdpyinfo (1.3.4-1) finished
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Installing xorg-xdpyinfo (1.3.4-1)... [1/1]
A restart is required for the changes to take effect.
~ xdpyinfo | grep Composite ✔ 18s
Composite
~ xcompmgr -c -l0 -t0 -r0 -o.00 ✔
Another composite manager is already running (0x400006)
~ 1 ✘
Please stop posting images of text when you can just post formatted text.
Tip:
In the future, when posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Edit:
If this doesn’t work, I have no idea what to do further. Sorry.
Edit #2:
And remember to reboot afterwards!
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
