As apparently many others, I’ve been trying to get hardware acceleration of videos in Firefox by VAAPI to work, without much success.
I’ve been following the instructions on the arch wiki and from what I understand, my hardware should definitely support it, too.
What I’ve acchieved so far:
Firefox uses Webrender, vainfo output seems fine, I think, environment variable (MOZ_EGL_X11=1) is set, playing a youtube video using mpv works with minimal CPU use, as I would expect - but in Firefox CPU use always jumps to ~15-20% for 1080p videos on my 6C/12T CPU.
Here’s my system info:
Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.9-x86_64
root=UUID=... rw
cryptdevice=UUID=...:cryptroot quiet
udev.log_priority=3 mem_sleep_default=deep
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81YM v: IdeaPad 5 14ARE05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 14ARE05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: DTCN20WW(V1.06) date: 06/09/2020
ID-1: BAT1 charge: 44.9 Wh condition: 56.5/56.5 Wh (100%) volts: 12.3/11.5
model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x 0x4C 0x31 0x39 0x4D 0x33 0x50 0x5650
type: Li-ion serial: <filter> status: Discharging cycles: 50
Info: 6-Core model: AMD Ryzen 5 4600U with Radeon Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 L2 cache: 3072 KiB
bogomips: 50323
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397
10: 1397 11: 1396 12: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 04:00.0
chip ID: 1002:1636
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:2
chip ID: 174f:244c serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.3-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.2.1 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 04:00.1
chip ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 04:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.3-1-MANJARO
and vainfo:
vainfo: VA-API version: 1.9 (libva 2.9.1)
vainfo: Driver version: Mesa Gallium driver 20.2.1 for AMD RENOIR (DRM 3.39.0, 5.9.3-1-MANJARO, LLVM 10.0.1)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
What I have not tried so far is something like h264ify, but Youtube seems to use VP9, which should be supported by Renoir’s iGPU.
Any suggestions?
Indeed Firefox VAAPI is broken in Manjaro, tried the KDE live USB today and Firefox outputs errors when using VAAPI and fallbacks to CPU decoding.
Manjaro Unstable works fine on my end with manjaro-vaapi
installed using Intel video.
cscs
16 November 2020 03:50
4
Dont just make unsubstantiated claims because you cant configure it.
Theres nothing making it not work on manjaro when it would work on Arch, etc.
For my part it seems to work fine.
Which parts?
What packages do you have installed that you believe are required?
What firefox settings have you configured?
These firefox options are probably the ones in about:config
gfx.webrender.all > true
gfx.webrender.enabled > true
layers.acceleration.force-enabled > true
# media.ffmpeg.dmabuf-textures.enabled > true
media.ffmpeg.vaapi-drm-display.enabled > true
media.ffmpeg.vaapi.enabled > true
# media.ffvpx.enabled > false
(the ones commented out are probably not required but may be nice)
I’ve installed the vaapi-related packeges and seem to have hardware acceleration working fine e.g. in mpv, and to some degree, vlc (which seems to have other issues there, but those probably don’t belong here).
Yet, in Firefox, I always get the same high CPU, no matter what.
I’ve rechecked the options in about:config, but they are already set accordingly.
moson
16 November 2020 10:30
6
I have a Renoir CPU as well. Working fine here.
Start Firefox like this and check if it spits out lines with “VA-API” in it:
(Play a video and then check for vaapi…)
MOZ_LOG="PlatformDecoderModule:5" firefox
Stupid question - where does the log end up?
The console output doesn’t contain anything about vaapi, though, only numerous of those:
[Child 74713: Main Thread]: D/PlatformDecoderModule Sandbox decoder rejects requested type
[Child 74713: Main Thread]: D/PlatformDecoderModule Sandbox decoder supports requested type
[Child 74713: MediaController #2]: D/PlatformDecoderModule Sandbox decoder supports requested type
[Child 74713: MediaPDecoder #1]: D/PlatformDecoderModule AudioTrimmer[0x7f131f9b9660] ::Decode: sample[0,21000] no trimming information
[RDD 74972: MediaPDecoder #2]: D/PlatformDecoderModule OpusDataDecoder[0x7f8e06f650b0] ::Decode: Opus decoder skipping 312 of 960 frames
[Child 74713: MediaPDecoder #1]: D/PlatformDecoderModule AudioTrimmer[0x7f131f9b9660] ::HandleDecodedResult: sample[0,21000] (decoded[0,13500] no trimming needed
[RDD 74972: MediaPDecoder #1]: D/PlatformDecoderModule DAV1DDecoder[0x7f8e06fa2ab0] ::GetPicture: Decode error: -11
[RDD 74972: MediaPDecoder #3]: D/PlatformDecoderModule DAV1DDecoder[0x7f8e06fa2ab0] ::GetPicture: Decode error: -11
moson
16 November 2020 11:46
8
Dino-Fossil:
DAV1DDecoder
Seems you are trying to play a video with AV1 codec.
That codec is not supported to be decoded in hw by renoir.
Try some other video with VP9 or H264 for example.
https://www.youtube.com/watch?v=8Kb8s0P9D4I
Same CPU use - hovers around ~10% total, which is about one core fully occupied.
And still no mention whatsoever of vaapi:
[Child 81972: MediaPDecoder #4]: D/PlatformDecoderModule AudioTrimmer[0x7f44f145afc0] ::HandleDecodedResult: sample[34401000,34421000] (decoded[34394500,34414500] no trimming needed
[Child 81972: MediaPDecoder #4]: D/PlatformDecoderModule Got one frame output with pts=32800000 dts=32800000 duration=40000 opaque=-9223372036854775808
[Child 81972: MediaPDecoder #4]: D/PlatformDecoderModule AudioTrimmer[0x7f44f145afc0] ::Decode: sample[34421000,34441000] no trimming information
[Child 81972: MediaPDecoder #5]: D/PlatformDecoderModule AudioTrimmer[0x7f44f145afc0] ::HandleDecodedResult: sample[34421000,34441000] (decoded[34414500,34434500] no trimming needed
[Child 81972: MediaPDecoder #5]: D/PlatformDecoderModule Got one frame output with pts=32840000 dts=32840000 duration=40000 opaque=-9223372036854775808
[Child 81972: MediaPDecoder #5]: D/PlatformDecoderModule AudioTrimmer[0x7f44f145afc0] ::Decode: sample[34441000,34461000] no trimming information
[Child 81972: MediaPDecoder #4]: D/PlatformDecoderModule AudioTrimmer[0x7f44f145afc0] ::HandleDecodedResult: sample[34441000,34461000] (decoded[34434500,34454500] no trimming needed
If I picked a AV1 vid, that was by accident, I had also tried various VP9 before.
moson
16 November 2020 13:03
10
Yeah then, it’s indeed not switched on.
Try this config setting:
gfx.webrender.all = true
And then start with:
MOZ_EGL_X11=1 MOZ_LOG="PlatformDecoderModule:5" firefox
No, no change, but that’s no wonder, I had already set all of those variables…
moson
16 November 2020 15:15
12
Ok, sorry, no clue then. Working for me on cinnamon unstable.
By the way, which driver is being used by vaapi on your system?
Did you also install vdpau or just vaapi?
cscs
17 November 2020 00:09
14
$ pacman -Qs 'libva|vdpau|mesa|amd'
amd-ucode 20201113.r1774.2ea8667-1
Microcode update files for AMD CPUs
glu 9.0.1-2
Mesa OpenGL Utility library
lib32-libva 2.8.0-1
Video Acceleration (VA) API for Linux (32-bit)
lib32-libva-mesa-driver 20.2.2-2
VA-API implementation for gallium (32-bit)
lib32-libva-vdpau-driver 0.7.4-6
VDPAU backend for VA API (32-bit)
lib32-libvdpau 1.4-1
Nvidia VDPAU library
lib32-mesa 20.2.2-2
An open-source implementation of the OpenGL specification (32-bit)
lib32-mesa-vdpau 20.2.2-2
Mesa VDPAU drivers (32-bit)
lib32-vulkan-intel 20.2.2-2
Intels Vulkan mesa driver (32-bit)
lib32-vulkan-radeon 20.2.2-2
Radeons Vulkan mesa driver (32-bit)
libva 2.9.1-1
libva-utils 2.9.1-1
Intel VA-API Media Applications and Scripts for libva
libva-vdpau-driver 0.7.4-4
libvdpau 1.4-1
libvdpau-va-gl 0.4.2-3
VDPAU driver with OpenGL/VAAPI backend
mesa 20.2.2-2
mesa-demos 8.4.0-4
Mesa demos and tools incl. glxinfo + glxgears
mesa-vdpau 20.2.2-2
Mesa VDPAU drivers
mhwd-amdgpu 19.1.0-1
MHWD module-ids for amdgpu
vamp-plugin-sdk 2.10.0-1 (pro-audio)
The Vamp audio analysis plug-in system
vdpauinfo 1.4-1
Command line utility for querying the capabilities of a VDPAU device
xf86-video-amdgpu 19.1.0-2 (xorg-drivers)
X.org amdgpu video driver
(I removed some local things unrelated)
Thanks!
Only differences I spot are that I was missing libvdpau-va-gl, which I have installed now (no change) and you are on a slightly newer version of some mesa packages. Are you using Testing branch?
cscs
17 November 2020 18:07
16
I am on Unstable. So makes sense.
I doubt that the slightly newer Mesa branch is responsible here, but if so, it will eventually fix itself…
In the meantime, I might check out creating a new Firefox profile or play around with a few other settings. It’s strange, though, vaapi works in mpv, but is completely ignored in Firefox…
I found the solution! It’s actually rather simple and I was being stupid…
It’s not MOZ_EGL_X11=1, it’s MOZ_X11_EGL=1
I guess it’s possible, that in the process of trying to fix this issue, I might have done something else, e.g. set a variable I had forgot earlier, or installed some missing package - but ultimately the issue was the above setting.
I had previously misspelled it and never checked on it thereafter.
Well, at least it works now, CPU use is much lower, just a few hours lost over it…
cscs
18 November 2020 02:17
19
Good you found it.
BTW … my preferred way of changing the firefox default env vars is like this:
Exec=/usr/bin/sh -c "MOZ_X11_EGL=1 GTK_USE_PORTAL=1 /usr/lib/firefox/firefox %u"
Exec=/usr/bin/sh -c "MOZ_X11_EGL=1 GTK_USE_PORTAL=1 /usr/lib/firefox/firefox --new-window %u"
Exec=/usr/bin/sh -c "MOZ_X11_EGL=1 GTK_USE_PORTAL=1 /usr/lib/firefox/firefox --private-window %u"
Then whenever you start FF from a key combo or link or menu … it will use your variables.
(and you arent editing a system file, which also means it wont overwrite during an update etc)
cscs
Split this topic
19 November 2020 01:53
20
A post was merged into an existing topic: Vaapi errors with intel i965
