Many std::bad alloc errors recently
Just update while installing the packages ..
sudo pacman-mirrors -f && sudo pacman -Syu ffmpeg ffmpeg4.4
That too, depending on his intention.
Weirdly it seems that saving works the first time, but the second time it crashes.
Also for skanlite^^
skanlite         ✔
kf.kio.filewidgets.kfilefiltercombo: Could not find filter "image/png"
kf.kio.filewidgets.kfilefiltercombo: Could not find filter "*.png|PNG-Bild "
kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///home/joh/-vcodec")
libKExiv2: Cannot load metadata from file   (Error # %1: The file contains data of an unknown image type )
Not a JPEG file: starts with 0x62 0x6c
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
zsh: IOT instruction (core dumped)  skanlite
Hmm, reinstalling ffmpeg with
didn’t change anything :confused:
Any other suggestions?
Hooray!
Seems to have been a qt5 related issue.
Deleting ~/.config/QtProject.conf fixed it :smiley:
You mean that you didn’t try that five months ago? :scream_cat:
