Hi all!
This is just for interest sake and not at all important, seeing as everything is working as it should.
I have several mounts to cloud providers that I use with rclone.
These mounts do not happen automatically, I manually mount them as neccessary, and everything works like a charm.
I was wondering though, is there a way to add the newly mounted directory to Dolphin File Managers “Places” panel if the mount was successful? And a command to remove it? (When the mount is unmounted?)
As I said, this isn’t important, it would just be very cool!
