Hi,
I bought a used PC and a used GPU and want to install Manjaro on it (encrypted).
I installed it before to test all the parts and everything works fine. I want to install it now encrypted.
My drive configuration is like this:
SATA SSD 128GB : is / and also the bootable drive that came with the PC
NVME Drive 1TB from the old Laptop (only connectable in a way that is sadly not bootable): is /home
I installed it via manual partiton and encrypted / and /home with a different key, but at the start of my pc i only had to input the / key and when i logged in /home was allready mounted without inputting the different password.
My question is: Is that normal that /home mounts without inputting the password even if it is encrypted? Does Linux automatically mount and enters the pw on boot because /home is necessary? Shouldn’t I have to enter a pw first or am I missing something?
