Manjarowish : Kde-Gaming edition
~ >>> sudo cat /boot/grub/grub.cfg | grep 'configfile '
[sudo] password for sk:
	configfile "${prefix}/grub-btrfs.cfg"
tux-question-02-sgs
It's a mystery to me.
But I have now long enough researched why it does not go with me, again ;), as with the others.
My solution, I edit the path direct in 41_snapshots-btrfs :smiley:
New, missing MJW icons in "taskbars" (red ones)
grafik
grafik
Mouse clicks ar working.
Who knows the path to this
icons?
May be I make a black/white version, if they don't already exist.
I keep forgetting I know everything :smiley:
/usr/share/icons/hicolor/128x128/apps/flameshot.png
/usr/share/icons/hicolor/48x48/apps/flameshot.png
/usr/share/icons/hicolor/scalable/apps/flameshot.svg
flamshot48-bw flamshot128-bw
flameshot.svg
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg
   xmlns:dc="http://purl.org/dc/elements/1.1/"
   xmlns:cc="http://creativecommons.org/ns#"
   xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
   xmlns:svg="http://www.w3.org/2000/svg"
   xmlns="http://www.w3.org/2000/svg"
   id="svg10"
   version="1.1"
   viewBox="0 0 64 64">
  <metadata
     id="metadata16">
    <rdf:RDF>
      <cc:Work
         rdf:about="">
        <dc:format>image/svg+xml</dc:format>
        <dc:type
           rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
        <dc:title></dc:title>
      </cc:Work>
    </rdf:RDF>
  </metadata>
  <defs
     id="defs14" />
  <g
     style="opacity:1"
     id="g4569">
    <path
       d="M 32 0 C 14.3 0 0 14.3 0 32 C 0 49.7 14.3 64 32 64 C 49.7 64 64 49.7 64 32 C 64 14.3 49.7 0 32 0 z M 32 1.3554688 C 48.95 1.3554688 62.644531 15.05 62.644531 32 C 62.644531 48.95 48.95 62.644531 32 62.644531 C 15.05 62.644531 1.3554688 48.95 1.3554688 32 C 1.3554688 15.05 15.05 1.3554688 32 1.3554688 z "
       id="path2"
       style="fill:#ffffff" />
    <path
       style="fill:none;stroke:#ffffff;stroke-opacity:1"
       d="m 37.388672,9.1367188 c 0,0 1.202528,9.1542942 -10.767578,15.8066402 -1.343111,-6.452395 -5.929688,-12.21289 -5.929688,-12.21289 0,0 1.987123,8.169125 -6.845703,19.816406 -3.9162994,5.164173 1.558037,14.163375 4.248197,17.987183 1.599227,2.182967 0.497694,1.929766 1.496546,0.288887 1.58827,-2.385926 6.258809,-7.086364 18.956429,-8.328804 13.559534,-1.326777 15.021484,-26.404297 15.021484,-26.404297 0,0 -0.578394,6.316498 -13.511718,10.257812 C 41.010622,18.402569 37.388672,9.1367188 37.388672,9.1367188 Z"
       id="path4" />
    <path
       style="fill:none;stroke:#ffffff;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
       d="m 26.621094,24.943359 c 2.66861,9.001487 -11.045326,15.201422 -7.638043,27.124438"
       id="path4550" />
    <path
       d="M 40.056641,26.347656 C 37.885455,39.948682 23.148523,33.704514 18.983051,52.067797"
       id="path4552" />
  </g>
</svg>
Why they give this path and do not use it???
I copied my svg and png, reboot, nothing . :frowning:
got the update - mw-icons-r2.85cbd60-1-any
reboot :slight_smile:
Update work, icons back :slight_smile:
If I move over the colored icon I got my svg :slight_smile:
grafik
But on topbar noting changed,
OT off :slight_smile:
update again and check if flameshot icon changed
They are hard hard coded :wink:
Same, but my copied pic on same place.
/usr/.../48x48/apps >>> ls | grep flames
-rw-r--r-- 1 root root 1,9K 18.02.2020 17:07 flameshot.png
perhaps make an issue in flameshot repo
and ask them to add your icon to tray
279 in front of mine :slight_smile:
FYI :slight_smile:
I got the bw icon flameshot :slight_smile:
On searching for inkscape menu on app and not on tray, I found (think) plasma5-applets-window-appmenu is the guilty :wink: app.
So I delete it and on update yesterday and today I was asked about change to manjarowish-dark-kde-settings(Y). It changed not the color icon on tray for flameshot.
But it would delete with plasma5-applets-window-appmenu, after reboot the tray look good :wink:
(flameshot icon) :point_up_2:
Inkscape use now User-settings . :100:
Perfect. :slight_smile:
2020-02-20_00-46_1
2020-02-20_00-47
The clock changed from black to white but you can not have everything :wink:
This looks pretty cool, I may have to test this on my gaming laptop
Always ? :wink:
:: Replace mw-icons with chaotic-aur/mw-icons? [Y/n]
Third time, but icons work now in black and white. Or new ones inside?
Deinstalled , and again installed. Its a loop?
i will have to check what is causing this
perhaps pkgbuild need changes
Dosn't stop. Possible solution?
i will remove
conflicts=
replaces=
Circles
~ >>> LANG=C sudo pacman -S gwe        [1]
resolving dependencies...
warning: cannot resolve "libappindicator3", a dependency of "gwe"
:: The following package cannot be upgraded due to unresolvable dependencies:
      gwe
Fixed with libappindicator-gtk3 in pamac build-file.
diff --git a/PKGBUILD b/PKGBUILD
index c2f6de7..d601af1 100644
--- a/PKGBUILD
+++ b/PKGBUILD
@@ -7,7 +7,7 @@ pkgdesc="A system utility for controlling NVIDIA GPUs"
 arch=('any')
 url="https://gitlab.com/leinardi/gwe"
 license=('GPL3')
-depends=('gobject-introspection' 'libdazzle' 'libappindicator3' 'python' 'python-cairo' 'python-gobject' 'python-injector' 'python-matplotlib' 'python-peewee' 'python-py3nvml' 'python-requests' 'python-rx' 'python-xdg' 'python-xlib')
+depends=('gobject-introspection' 'libdazzle' 'libappindicator-gtk3' 'python' 'python-cairo' 'python-gobject' 'python-injector' 'python-matplotlib' 'python-peewee' 'python-py3nvml' 'python-requests' 'python-rx' 'python-xdg' 'python-xlib')
 makedepends=('meson' 'appstream-glib')
 provides=()
 source=("https://gitlab.com/leinardi/gwe/-/archive/$pkgver/$pkgname-$pkgver.tar.gz")
Cudos to manuel ups, profile is hidden
so path to solution :wink:
Announcement
it is something i have to announce regarding manjarowish future.
from now on im abandoning manjarowish .
all the manjarowish spins wont have new iso from now onwards.
reason
i have moved on and created Garuda Linux
which is based directly on arch linux and uses arch repo
the reason is manjaro branches i just dont like the structure at all.
i also have modified mhwd and manjaro-settings-manager
and made mhwd-garuda , mhwd-db-garuda and garuda-settings-manager
it works with arch repo
and uses nvidia-dkms instead of kernel modules
and garuda-settings-manager displays all kernels available and not just with format linux44 linux49 etc
so in short garuda linux is arch based and has most of manjaro goodies
without mess of branches and delays.
this distro also eliminates any need for stable and what ever branch as we use btrfs
so even if bad updates break things you are safe and you can have working system in seconds.
and it contains all the tweaks of manjarowish
Gitlab
Sourceforge
Telegram
