Manjaro32 Testing iptables-1:1.8.3-1.2
@jonathon There is currently no testing announcement thread so I have raised a new thread for this.
This update to iptables fails:
Summary
[keith@Laptop1 ~]$ sudo pacman -Syu
[sudo] password for keith:
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
resolving dependencies...
Packages (1) iptables-1:1.8.3-1.2
Total Installed Size: 2.45 MiB
Net Upgrade Size: -0.03 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [###########################################] 100%
(1/1) checking package integrity [###########################################] 100%
(1/1) loading package files [###########################################] 100%
(1/1) checking for file conflicts [###########################################] 100%
(1/1) checking available disk space [###########################################] 100%
(1/1) upgrading iptables [###########################################] 100%
(1/2) Reloading system manager configuration...
/usr/bin/systemctl: error while loading shared libraries: libip4tc.so.0: cannot open shared object file: No such file or directory
error: command failed to execute correctly
(2/2) Arming ConditionNeedsUpdate...
[keith@Laptop1 ~]$
NO NOT try to reboot your system as the kernel will dump and you will be unable to start your system.
Temporary fix: downgrade iptables:
If you have already tried to reboot your system you will need to chroot into it to do the downgrade.
Summary
[keith@Laptop1 ~]$ sudo downgrade iptables
Available packages:
    1. iptables 1 1.8.2 1.2 i686 (local)
    1. iptables 1 1.8.3 1.2 i686 (local)
select a package by number: 1
loading packages...
warning: downgrading package iptables (1:1.8.3-1.2 => 1:1.8.2-1.2)
Packages (1) iptables-1:1.8.2-1.2
Total Installed Size: 2.48 MiB
Net Upgrade Size: 0.03 MiB
(1/1) downgrading iptables [###########################################] 100%
add iptables to IgnorePkg? [y/n] y
[keith@Laptop1 ~]$
A post was merged into an existing topic: [Testing Update i686] 2019-08-07
