Dbeaver does not start on launch - reference to arch linux issue
There is an error regarding starting the application dbeaver in manjaro KDE.
I will attach the error log file.
To me it appears to be related to the following issue
arch linux issue tracker
And in reference to the following github issue:
github issue reference
Using the command provided in the archlinux issue tracker, seems to fix the issue (update java openjdk version >= 11)
archlinux-java set java-11-openjdk
Not sure if this helps out on some other user.
It seems I am not allowed to attach links, so I will try to provide a pseudo links, please remove the ~:
https:~//bugs.~archlinux.~org/task/69133
https:~//github.~com/dbeaver/dbeaver/issues/10837
:+1: Thanks for sharing! :+1:
but could you do me a favour and split that into a question and an actual answer (just cut and paste and respond to yourself) and then click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
If you do that I’ll convert the pseudo-links to real links.
:innocent:
Thanks for the post, it helped me solve my issue so I will try to clarify it a bit so that it might help others too.
Issue: After fresh installation of ‘dbeaver’, opening from gui gives an error:
version 1.8.0_xxx of the jvm is not suitable for this product
It says that java version should be >= 11
Even after installing latest version of java, the error remains, when you use the following command to check java version:
java -version
you see the version is listed as something like:
version 1.8.0_292
Solution:
Install latest jdk if not already installed (it might work with the default version that comes with Manjaro too).
Check the directory /usr/lib/jvm to list out the versions
Assuming you have java-17-jdk installed
use the command like:
sudo archlinux-java set java-17-jdk
You should now be able to open dbeaver. Hope this helps.
