Hello, this is my first post here.
The Manjaro installation used to run fine for a couple of weeks. One day, the system freezed and crashed but would boot again. This happened several times and now it doesn’t boot anymore.
(Side note: this happened before on the same computer with Linux Mint 20.1. I changed to Manjaro because of this, hoping it was a compability error.)
When I try to boot I get a black screen with some error messages starting with:
switch root: failed to execute /sbin/init: Input/output error
Kernel panic …
(Screenshots are not allowed here and I have no other option to copy the text.)
Please help me to find out whether this is an hardware issue or not. In either way please help me fix it, thank you.
Here is the results of inxi, manjaro chroot, and dmesg run from a live USB version:
[manjaro@manjaro ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=de tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2021 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: HP product: HP EliteBook 840 G3 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8079 v: KBC Version 85.77 serial: <filter> UEFI: HP
v: N75 Ver. 01.24 date: 01/30/2018
ID-1: BAT0 charge: 27.2 Wh condition: 42.1/42.1 Wh (100%) volts: 11.4/11.4
model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging
RAM: total: 15.52 GiB used: 1.16 GiB (7.4%)
Info: Dual Core model: Intel Core i5-6300U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: E2
L2 cache: 3 MiB bogomips: 20004
Speed: 700 MHz min/max: 400/3000 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d
fma fpu fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1
xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel Skylake GT2 [HD Graphics 520]
vendor: Hewlett-Packard EliteBook 840 G3 driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1916
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus ID: 1-9:6
chip ID: 04f2:b51c
Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio
vendor: Hewlett-Packard EliteBook 840 G3 driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d70
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard EliteBook 840 G3
driver: e1000e v: kernel port: efa0 bus ID: 00:1f.6 chip ID: 8086:156f
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: efa0
bus ID: 02:00.0 chip ID: 8086:24f3
IF: wlp2s0 state: down mac: <filter>
Device-3: HP HP hs3110 HSPA+ Mobile Broadband Device type: USB
driver: usb-network bus ID: 1-3:3 chip ID: 03f0:521d
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 510.43 GiB used: 2.18 GiB (0.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Innovation model: IT size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 4A0
ID-2: /dev/sdb maj-min: 8:16 type: USB model: USB DISK 2.0 size: 29.83 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: PMAP
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston model: DT 101 G2
size: 3.66 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: PMAP
ID-1: / raw size: N/A size: 11.64 GiB used: 69.7 MiB (0.6%) fs: overlay
source: ERR-102 label: N/A uuid: N/A
ID-2: /run/media/manjaro/KINGSTON raw size: 3.65 GiB size: 3.65 GiB (99.89%)
used: 2.11 GiB (58.0%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: KINGSTON
uuid: 87CA-2356
ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: N/A
uuid: 4A40-BCEF
ID-2: /dev/sda2 maj-min: 8:2 size: 467.84 GiB fs: ext4 label: N/A
uuid: 7fa39da2-fccc-4716-a999-f6139c642ac1
ID-3: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: swap label: N/A
uuid: fac73f86-1d39-4b60-adda-f27e3f4bae24
ID-4: /dev/sdb1 maj-min: 8:17 size: 2.73 GiB fs: iso9660
label: MANJARO_XFCE_2021 uuid: 2021-01-03-08-16-14-00
ID-5: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C274-6DF3
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-1:2 info: Kingston Flash drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 13fe:4100 serial: <filter>
Device-2: 1-2:7 info: Toshiba Kingston DataTraveler 102/2.0 / HEMA Flash
Drive 2 GB / PNY Attache 4GB Stick
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s chip ID: 0930:6545 serial: <filter>
Device-3: 1-3:3 info: HP HP hs3110 HSPA+ Mobile Broadband Device type: N/A
driver: N/A rev: 2.0 speed: 480 Mb/s chip ID: 03f0:521d
Device-4: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2b
Device-5: 1-8:5 info: Validity Sensors VFS495 Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip ID: 138a:003f serial: <filter>
Device-6: 1-9:6 info: Chicony HP HD Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b51c
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 28.0 C mobo: 0.0 C
Processes: 201 Uptime: 15m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1203 lib: 370 flatpak: 0 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.2.01
[manjaro@manjaro ~]$ manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
chroot: failed to run command '/bin/bash': Input/output error
--> umount: [/mnt/boot/efi]
--> umount: [/mnt]
[manjaro@manjaro ~]$ fsudo dmesg | less
exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 365.049503] audit: type=1104 audit(1614805284.456:165): pid=2756 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 473.234124] audit: type=1101 audit(1614805392.639:166): pid=3532 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 473.235012] audit: type=1110 audit(1614805392.642:167): pid=3532 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 473.235984] audit: type=1105 audit(1614805392.642:168): pid=3532 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 477.815467] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 478.077128] audit: type=1106 audit(1614805397.482:169): pid=3532 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 478.077737] audit: type=1104 audit(1614805397.486:170): pid=3532 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 917.408842] audit: type=1130 audit(1614805836.816:171): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 917.409392] audit: type=1131 audit(1614805836.816:172): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1010.920764] audit: type=1101 audit(1614805930.326:173): pid=4570 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1010.921358] audit: type=1110 audit(1614805930.329:174): pid=4570 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1010.926480] audit: type=1105 audit(1614805930.332:175): pid=4570 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1010.931182] audit: type=1106 audit(1614805930.339:176): pid=4570 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1010.931532] audit: type=1104 audit(1614805930.339:177): pid=4570 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1022.786053] audit: type=1101 audit(1614805942.192:178): pid=4572 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1022.786380] audit: type=1110 audit(1614805942.192:179): pid=4572 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1022.789489] audit: type=1105 audit(1614805942.196:180): pid=4572 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
(END)
What is the next step?
