Installation of WiFi with USB Adapter
Hello,
What to do to install WiFi with TP-LINK AC 1300 (Archer T4U) ?
Thanks for your reply.
Best regards.
Most USB sticks are created for Windows - there may not be a solution for Linux.
Plug’in the stick then open a terminal and run
lsusb
Paste the output in a comment (when pasted - select the text and click the </> icon in the comment toolbar.
Hello,
Please find below the output :
[lukvdl@Desktop-LVDL Downloads]$ lsusb
Bus 002 Device 002: ID 0480:a200 Toshiba America Inc External USB 3.0
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 001 Device 006: ID 04d9:1603 Holtek Semiconductor, Inc. Keyboard
Bus 001 Device 005: ID 18f8:0f99 [Maxxter] Optical gaming mouse
Bus 001 Device 003: ID 050d:0234 Belkin Components F5U234 USB 2.0 4-Port Hub
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 002: ID 2357:010d TP-Link Archer T4U v2 [Realtek RTL8812AU]
Awaiting your comments,
Best regards.
Luk.
It looks like the driver is available from the AUR. You can install it via Pamac. It appears that this one was last modified in December 2020.
http://aur.archlinux.org/packages/rtl8812au-dkms-git
Take note of the pinned comment on the aforementioned webpage as an option, just in case.
Hello,
Sorry, but don’t know what to do.
Manjaro Linux 21.0 is installed on my standalone PC.
Awaiting your reply,
Best regards.
