Hi,
is there a way to enable “AV-1 10bit (Intel QSR)” in Handbrake on a i5-13500/Arc A750 that I’ve missed?
H.264 and H.265 are available in either software encoding or hardware encoding through Quicksync - however AV-1 is only possible through SVT.
inxi -Ga
Device-1: Intel AlderLake-S GT1 vendor: ASRock driver: i915 v: kernel ports:
active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0380
Device-2: Intel DG2 [Arc A750] driver: i915 v: kernel arch: Gen-12.7
code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 1 ports: active: DP-2 empty: DP-3, DP-4, DP-5,
HDMI-A-3, HDMI-A-4, HDMI-A-5 bus-ID: 03:00.0 chip-ID: 8086:56a1
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1013x570mm (39.88x22.44")
s-diag: 1162mm (45.76") monitors: <missing: xrandr>
Monitor-1: DP-2 model: AOC AG271UG built: 2016 res: 1920x1080 dpi: 82
gamma: 1.2 size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9
modes: max: 1920x1080 min: 640x480
device: 1 drv: iris device: 2 drv: swrast surfaceless: drv: iris x11:
drv: iris inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A750 Graphics (DG2)
device-ID: 8086:56a1 memory: 7.75 GiB unified: no
API: Vulkan v: 1.3.264 layers: N/A device: 0 type: discrete-gpu name: Intel
Arc A750 Graphics (DG2) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:56a1 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel UHD Graphics 770 (ADL-S GT1) driver: mesa intel
v: 23.1.9-manjaro1.1 device-ID: 8086:4680 surfaces: xcb,xlib
pamac list -i | grep intel
ffmpeg-intel-full-git 6.1.r112499.ga76b409dd0-1 AUR 40,2 MB
intel-gmmlib 22.3.11-1 extra 1,6 MB
intel-media-driver 23.3.3-1 extra 37,8 MB
intel-media-sdk 23.2.2-2 extra 29,2 MB
intel-ucode 20230808-1 extra 7,4 MB
lib32-libva-intel-driver 2.4.1-1 multilib 8,3 MB
lib32-vulkan-intel 1:23.1.9-1 multilib 29,3 MB
libva-intel-driver 2.4.1-2 extra 8,2 MB
onevpl-intel-gpu 23.3.3-1 extra 11,2 MB
vulkan-intel 1:23.1.9-1 extra 30,3 MB
xf86-video-intel 1:2.99.917+923+gb74b67f0-1 extra 2,3 MB
I’ve tried handbrake from flatpak as well as from the extra repository without success.
