Manjaro XFCE 19.0-rc2 released
I am proud to announce our release candidate build of the upcoming Manjaro-XFCE 19.0 Kyria release. This build is based on stable branch .
The Xfce edition remains our flagship offering and has received the attention it deserves. Few can claim to offer such a polished, integrated and leading-edge Xfce experience. We ship Xfce 4.14 with this release of Manjaro.
We mainly focused on polishing the user experience on the desktop and window manager, and on updating some components to take advantage of newly available technologies such as optimization of our theme we call Matcha. The new feature Display-Profiles allows you to store one or more profiles for a particular display configuration that you may be using. To make the deal a little sweeter we implemented auto-applying of profiles when new displays are connected.
Higlight features
New features in xfce edition:
  • Polishing of Matcha themes (incl. dark theme)
  • Whiskermenu can now be more customized
  • Additional wallpapers to match theme changes
  • Fixing bugs and featuring improved translations
  • More features added to Pamac
We hope you enjoy it and please leave feedback. :grinning:
Changes since rc1:
  • Calamares updated to use kpmcore4
  • small fixes overall
Regressions:
  • seems Whiskermenu changed. We updated our configs so it will be fixed in our final release
Will the upcoming Manjaro Xfce edition include the 4.14 latest maintenance release, 4.14.3?
Only XFCE component which have version 4.14.3 version now, is xfce4-panel. This version is already on Manjaro Stable.
Was able to get this installed on my system. However I had to restart the live-usb 3-4 times before it booted into a graphical state that was usable. The other times it would boot to a static screen filled with colored snow. Was going to take a picture on next reboot then the it booted up normally. I am 100% sure this is because of my odd hardware setup I will drop my inix below for reference. What kind of support is coming down the pipes for and amd/nvidia hybrid combo.
  Kernel: 5.4.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
  Desktop: Xfce 4.14.2 tk: Gtk 3.24.13 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: Zephyrus G GU502DU_GA502DU v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: GU502DU v: 1.0 serial: <filter>
  UEFI: American Megatrends v: GU502DU.208 date: 08/01/2019
  ID-1: BAT0 charge: 68.3 Wh condition: 68.3/76.0 Wh (90%) volts: 15.8/15.8
  model: ASUSTeK ASUS Battery type: Li-ion serial: <filter>
  status: Not charging
  Topology: Quad Core model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
  bogomips: 36744
  Speed: 1344 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz):
  1: 1386 2: 1582 3: 1194 4: 1175 5: 1496 6: 2522 7: 1177 8: 1175
  Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
  driver: nvidia v: 440.59 bus ID: 01:00.0 chip ID: 10de:2191
  Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
  bus ID: 05:00.0 chip ID: 1002:15d8
  Display: x11 server: X.Org 1.20.7 driver: amdgpu,nvidia
  resolution: 1920x1080~120Hz
  OpenGL: renderer: GeForce GTX 1660 Ti with Max-Q Design/PCIe/SSE2
  v: 4.6.0 NVIDIA 440.59 direct render: Yes
  Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
  bus ID: 01:00.1 chip ID: 10de:1aeb
  Device-2: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 05:00.1 chip ID: 1002:15de
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.4.21-1-MANJARO
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  vendor: AzureWave driver: rtl8821ce v: N/A port: e000 bus ID: 03:00.0
  chip ID: 10ec:c821
  vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.0
  chip ID: 10ec:8168
  IF: enp4s0 state: down mac: <filter>
  Local Storage: total: 476.94 GiB used: 11.37 GiB (2.4%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 002C scheme: GPT
  ID-1: / size: 456.91 GiB used: 11.37 GiB (2.5%) fs: btrfs
  dev: /dev/nvme0n1p2
  ID-2: /home size: 456.91 GiB used: 11.37 GiB (2.5%) fs: btrfs
  dev: /dev/nvme0n1p2
  ID-3: swap-1 size: 19.53 GiB used: 0 KiB (0.0%) fs: swap
  dev: /dev/nvme0n1p3
  System Temperatures: cpu: 62.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2900
  GPU: device: nvidia screen: :0.0 temp: 52 C device: amdgpu temp: 62 C
  Processes: 271 Uptime: 6m Memory: 15.39 GiB used: 1.19 GiB (7.7%)
  Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
  running in: xfce4-terminal inxi: 3.0.37
