Manjaro XFCE (17.0)
If you have made all your updates, you are running 17.0 now. This is a rolling release. (SOLVED) How to know current manjaro version and plasma version I use? You can use search function here in the forum.
Great release, working very fine here, thanks :smiley:
Absolutely amazing everything is in order thanks for all the hard work
Yes @banjo you’re right.
I installed the update. now i moved from Fringella to Gellivera
LSB Version: n/a
Distributor ID: ManjaroLinux
Description: Manjaro Linux
Release: 17.0
Codename: Gellivara
Thank you
Big improvement in nvidia, on certain machines in the past, I had a few issues with apps not launching and various stickiness after installing the nvidia driver, but a lot of that is starting to subside. On my current machine, everything themes well and works on the first click.
Well, have you find a solution for it? Honestly after upgrade everything seems to push my cpu so hard & it always hit 100% of usage unlike 16.10…Also the memory from 8-13% now eating up to 55%. Is there a way to solve it?
Failed to mount /home
I get this installing 17.0 and 16.10.3 in a VM using BTRFS for /home.
If i use BTRFS for the root partition it is complete unable to boot.
Hmm. Use ext4 or some other file format. Works like a charm.
I know, cause the “old” installation was on ext4.
But why dos BTRFS not work?
Can it be, that something from the updated VirtualBox is atm the problem?
I did not reboot after that update, so maybe something might be struck…
So it is a BTRFS problem…
I was not able to get a running VM if i used BTRFS for /home or /.
I always got “Device could not be mounted”.
Is this a bug or just a problem of VirtualBox?
Thanks for your help.
Phil and team, I’m a little late to the party but want to say thank you for a very good-looking and well-organized release. I only installed Manjaro XFCE 17.0.1 yesterday evening but so far I like what I see very much.
