Manjaro-xfce-17.0.5-stable-x86_64.iso sha1sum ERROR no correct formated sha1 checksum line found
#1
Hello,
i downloaded manjaro-xfce-17.0.5-stable-x86_64.iso
at 01.10.2017 and today.
booth files gave an error at:
sha1sum -c manjaro-xfce-17.0.5-stable-x86_64.iso
sha1sum: manjaro-xfce-17.0.5-stable-x86_64.iso: keine korrekt formatierte SHA1‐Prüfsummenzeile gefunden
Maybe you’ll check your servers again?
regards LinuxFreak
#2
You have to download the sha1 file too.
And perform your command on that file.
#3
I see,
For check “iso” file:
sha1sum manjaro-xfce-17.0.5-stable-x86_64.iso
And here for “sha1sum” file:
sha1sum -c manjaro-xfce-17.0.5-stable-x86_64.iso.sha1
#4
actually this command will compute the sha1 sum of the file defined in the sha1 file… and check with the sum given in the file.
the first command only compute the sha1 sum of the given file and output it
#5
Ahh ok,
i jumped over the manual…
**sha1sum -c manjaro-xfce-17.0.5-stable-x86_64.iso.sha1 **
manjaro-xfce-17.0.5-stable-x86_64.iso: OK
did it.
thanks LF
#6
