you could try the normal version iso, not the minimal, and also use ventoy to flash the iso
At the moment I flash the ISO using the CLI on my Mac: sudo dd bs=4m if=manjaro-xfce-21.2.6-minimal-220416-linux515.iso of=/dev/disk4
That should do the job shouldn’t it?
with this i cant help you, i have no idea how to flash using dd…
Ok, I have no reason to suspect that that’s causing the issues. I’ve been reading around in some other threads and I’m thinking the issue might be to do with the Nvidia driver and that I should try to manually install it. I’m still trying to wrap my head around it all though.
