I was trying to install Samba to share files with my Mac over my LAN but gave up as it was proving to be too complicated. I’ve since deleted what I’ve installed for Samba.
Since then I haven’t been able to shutdown or reboot, when I initiate the process either through the GUI or using systemctl
in the terminal it shows some error messages and then just hangs.
Here is the output from inxi
Kernel: 5.15.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=7fb251a7-2170-4018-afb2-783ec65b3af6 rw quiet
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 17 9720 v: N/A
Mobo: Dell model: 0KNF8J v: A00 serial: <superuser required> UEFI: Dell
v: 1.6.0 date: 04/14/2022
ID-1: BAT0 charge: 55.0 Wh (59.1%) condition: 93.1/95.1 Wh (98.0%)
volts: 11.4 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly serial: <filter>
status: discharging
RAM: total: 31.04 GiB used: 2.14 GiB (6.9%)
RAM Report:
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 586 high: 943 min/max: 400/4679:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 521 2: 447 3: 543 4: 486
5: 564 6: 491 7: 501 8: 574 9: 672 10: 943 11: 491 12: 499 13: 537 14: 583
15: 558 16: 579 17: 642 18: 774 19: 617 20: 700 bogomips: 107560
arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 bus-ID: 0000:01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 0c45:6732 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: Sharp 0x1518 built: 2021 res: 1920x1200 hz: 60
dpi: 133 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
ratio: 16:10 modes: 1920x1200
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound Server-1: ALSA v: k5.15.48-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IP v6: <filter> type: noprefixroute scope: global
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 8.87 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 36308229 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 634.77 GiB size: 623.73 GiB (98.26%) used: 8.75 GiB (1.4%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 7fb251a7-2170-4018-afb2-783ec65b3af6
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 117.6 MiB (60.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: 14D8-2F08
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 298.49 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.01 GiB fs: ntfs
label: WINRETOOLS uuid: BE4A28054A27B8D3
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 17.84 GiB fs: ntfs label: Image
uuid: AC1428211427ED50
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.43 GiB fs: ntfs
label: DELLSUPPORT uuid: A258AB9558AB672F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-9:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-3: 1-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Message: No sensor data found. Is lm-sensors configured?
Processes: 427 Uptime: 12m wakeups: 1529 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 918 lib: 282 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.19
I also did a journalctl --boot=-1 --priority=3 | tail --lines=100
and got the following:
Jun 21 17:04:30 michael-xps179720 kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Jun 21 17:04:36 michael-xps179720 kernel: soundwire sdw:3:025d:0714:01: Probe not complete, timed out
Jun 21 17:04:36 michael-xps179720 kernel: soundwire sdw:3:025d:0714:01: Update Slave status failed:-110
Jun 21 17:04:36 michael-xps179720 kernel: soundwire sdw:1:025d:1316:01: Probe not complete, timed out
Jun 21 17:04:36 michael-xps179720 kernel: soundwire sdw:1:025d:1316:01: Update Slave status failed:-110
Jun 21 17:04:36 michael-xps179720 kernel: soundwire sdw:2:025d:1316:01: Probe not complete, timed out
Jun 21 17:04:36 michael-xps179720 kernel: soundwire sdw:2:025d:1316:01: Update Slave status failed:-110
Jun 21 17:04:36 michael-xps179720 kernel: soundwire sdw:0:025d:0711:01: Probe not complete, timed out
Jun 21 17:04:36 michael-xps179720 kernel: soundwire sdw:0:025d:0711:01: Update Slave status failed:-110
Jun 21 17:04:38 michael-xps179720 kernel: dell_smm_hwmon: unable to get SMM Dell signature
Jun 21 17:04:38 michael-xps179720 systemd-udevd[463]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Jun 21 17:04:39 michael-xps179720 kernel: sof_sdw sof_sdw: snd_soc_register_card failed -517
Jun 21 17:04:58 michael-xps179720 lightdm[1340]: gkr-pam: unable to locate daemon control file
Jun 21 17:05:39 michael-xps179720 kernel: ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-110)
Jun 21 17:07:30 michael-xps179720 kernel: watchdog: watchdog0: watchdog did not stop!
Would appreciate the help on this. At the moment I’m just manually turning the laptop off by holding the power button for about 15 seconds which I appreciate is not good for the computer.
UPDATE: Have also just noticed that the sound is also not working now. Could it be to do with the latest Manjaro update?
