Manjaro wont fully install
Hello, I am trying to install manjaro onto my virtual machine. I have it installed but whenever i run the install manjaro linux file on the desktop everything goes perfectly fine and when it tells me to reboot I restart the vm and it still isnt fully installed
Try unmount the ISO in VM first. It could be it’s set up to run the ISO first.
Thank you I will try this
How do you know that?
Likely, what @Storm said needs to be done - depending on what VM software you use.
This is usually taken care of automatically in virt-manager and Gnome Boxes.
Not necessarily in VirtualBox.
after installation: shut down, remove ISO from the configuration, reboot
