you have also bbswitch, so remove it too:
sudo pacman --sysroot /mnt -R linux519-bbswitch linux519-rt-bbswitch linux519-rt linux519 linux519-nvidia-390xx linux519-rt-nvidia-390xx
rerun update again:
rerun update again:
Still no luck:
error: target not found: linux519-rt-bbswitch
so you have installed linux519-rt but not the bbswitch with it, interesting… so run the command without it:
sudo pacman --sysroot /mnt -R linux519-bbswitch linux519-rt linux519 linux519-nvidia-390xx linux519-rt-nvidia-390xx
Here are the results:
:: Do you want to remove these packages? [Y/n] Y
(1/1) Removing linux initcpios...
(1/5) removing linux519-rt-nvidia-390xx [#############################] 100%
(2/5) removing linux519-nvidia-390xx [#############################] 100%
(3/5) removing linux519-rt [#############################] 100%
(4/5) removing linux519-bbswitch [#############################] 100%
(5/5) removing linux519 [#############################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.0-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.0-x86_64.img
Found initrd fallback image: /boot/initramfs-6.0-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-rt-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
done
and why do you have installed all kernels, thats not needed…
Was my mistake, I’m largely new to Manjaro. Last time I had Linux exposure before the prior year was Linux Mint back in 2012, and Ubuntu before then. I’ve also rarely been on my PC much in the past 7 years because of my job as a truck driver, so haven’t had much time to learn and re-learn stuff.
thats ok… just rerun the update
Running now, fingers crossed…
Looks like it worked. It said the kernel was updated, as well as over 600 over items from the looks of it. I’m assuming I now close out the terminal and reboot the laptop?
Here’s one of the last messages, since there’s too much to copy/paste:
==> Warning:
-> Kernel has been updated. Modules of the current kernel
-> have been backed up so you can continue to use your
-> computer. However, the new kernel will only work
-> at next boot.
@brahma , it worked! Manjaro re-booted successfully! Thanks so much!
good, now remove these kernels, you dont need all of them:
sudo mhwd-kernel -r linux515-rt
sudo mhwd-kernel -r linux510
sudo mhwd-kernel -r linux54
sudo mhwd-kernel -r linux419
If you want to keep a bootable system, see:
And keep an eye on the Announcements > Stable Updates section, there are announcements when updating, along with a list of possible gotchas.
