Hi
I’m new to linux altogether and today is my first day to try manjaro. I’ve been getting boot device not found after manual partition installation. Its working fine with erase and install but I wanted to do a manual partition so that I can keep data on home.I’m doing UEFI installation with fat32 boot/efi with flags set to boot and swap, root and home.So I wanted to know where am I doing wrong as other distros are working like this.
EDIT: So I fixed the problem. The problem for me was there was no esp flag option for boot/efi. I had to manually do that through gpart and then install it. Now its booting normally
I meant in general - is that your boot manager? do you use one from another distro, or install it during manjaro install? or use another bootloader entirely? is this all klingon to you?
You will need some kind of grub or similar boot manager, and you will need to select the ESP ofr use (not format!), as you seem to know how to do … but you must install/overwrite grub with manjaro grub … this will allow you to boot your OS’s … and manjaro uses a patched grub thats works with it - it can boot other distros, but generally other distros grub will not boot manjaro easily.
