Firefox, plex media player, lutris crashes, spontanious system freezes
hi folks,
i am quite desperate with the 30.12.2020 update.
Before that almost everything runs quite decent and I said it was a good step leaving windows.
after fixing black screens, getting rid of the old 45xx nvidia config, I am still having issues.
doesnt matter if I use free or proprietary drivers.
firefox crashes on youtube, plex media player sometimes just looses all icons and video, lutris (overwatch) is not possible to play ranked, as it probably crash after 2-5 min
and every 2-5 days the entire system freezes.
so since all above was running prior 30.12.2020 update, i have a strong feeling this is related to the driver.
i tried using LTS kernel with free and nonfree drivers, i tried it with 5.10 kernen, free and nonfree driversā€¦
I just run out of knowledge on how to fix that.
as of now i am on 5.10 with proprietary drivers.
would someone be so kind to help me to get the system in a stable condition?
Start with posting output of:
inxi -Fxxxza --no-host
mhwd -l
sudo journalctl -p 3 -xb
cat /var/log/Xorg.0.log | grep -E "(EE)|(WW)|\error|\failed|\Time"
sudo dmesg -HT
uuups, sorry forgot to mention:
  • XFCE
  • ryzen 1700x
  • 16gb RAM
  • GTX1080TI OC
You need to read all of this document:
You need to provide the ā€˜System Informationā€™ for your computer. How to do this is clearly documented in the above post.
gary
[desktop@desktop-systemproductname ~]$ inxi -Fxxxza --no-host
  Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=8a48a37d-134c-4ddc-b970-66d3418fe5d4 rw quiet
  cryptdevice=UUID=deaf0408-5f57-4117-b296-bf8a3e8d4af2:luks-deaf0408-5f57-4117-b296-bf8a3e8d4af2
  root=/dev/mapper/luks-deaf0408-5f57-4117-b296-bf8a3e8d4af2 apparmor=1
  security=apparmor
  resume=/dev/mapper/luks-f35e49f2-2dff-4b80-b9de-7d3d5754f221
  udev.log_priority=3
  Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 5603 date: 07/28/2020
  ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 4.1/N/A
  model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
  status: Discharging
  Info: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen
  family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 L2 cache: 4 MiB
  bogomips: 95846
  Speed: 2515 MHz min/max: 1550/3000 MHz boost: enabled Core speeds (MHz):
  1: 2515 2: 1360 3: 1359 4: 1351 5: 1277 6: 3046 7: 2770 8: 2448 9: 1366
  10: 1370 11: 1277 12: 2724 13: 2783 14: 2503 15: 2277 16: 1365
  disabled, RSB filling
  Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK
  driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 09:00.0
  chip ID: 10de:1b06
  Display: x11 server: X.Org 1.20.10 driver: nvidia display ID: :0.0
  screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.0x22.5")
  s-diag: 1166mm (45.9")
  Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 164
  size: 596x335mm (23.5x13.2") diag: 684mm (26.9")
  OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
  direct render: Yes
  Device-1: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 09:00.1 chip ID: 10de:10ef
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 0b:00.3 chip ID: 1022:1457
  Device-3: Kingston HyperX 7.1 Audio type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:2 chip ID: 0951:16a4
  serial: <filter>
  Sound Server: ALSA v: k5.10.2-2-MANJARO
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
  port: e000 bus ID: 04:00.0 chip ID: 8086:1539
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.32 TiB used: 267.82 GiB (11.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
  size: 1.86 TiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: 42AZS6AC temp: 42.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500BX100SSD1
  size: 465.76 GiB block size: physical: 512 B logical: 512 B
  speed: 6.0 Gb/s serial: <filter> rev: MU02
  ID-1: / raw size: 1.85 TiB size: 1.82 TiB (98.38%)
  used: 267.82 GiB (14.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-deaf0408-5f57-4117-b296-bf8a3e8d4af2
  ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
  used: 480 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
  ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/dm-1 maj-min: 254:1
  mapped: luks-f35e49f2-2dff-4b80-b9de-7d3d5754f221
  System Temperatures: cpu: 40.5 C mobo: N/A gpu: nvidia temp: 63 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
  Processes: 350 Uptime: 1h 20m wakeups: 11 Memory: 15.63 GiB
  used: 8.05 GiB (51.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  clang: 11.0.0 Packages: 1309 pacman: 1304 lib: 391 flatpak: 0 snap: 5
  Shell: Bash v: 5.1.0 running in: xfce4-terminal inxi: 3.2.01
[desktop@desktop-systemproductname ~]$ mhwd -l
> 0000:09:00.0 (0300:10de:1b06) Display controller nVidia Corporation:
          video-nvidia            2020.11.30               false            PCI
    video-nvidia-390xx            2020.11.30               false            PCI
           video-linux            2018.05.04                true            PCI
[desktop@desktop-systemproductname ~]$ sudo journalctl -p 3 -xb
-- Journal begins at Fri 2020-11-13 17:50:21 CET, ends at Thu 2021-01-14 19:58:51 CET. --
Jan 14 18:21:52 desktop-systemproductname kernel:
Jan 14 18:22:19 desktop-systemproductname lightdm[1273]: gkr-pam: unable to locate daemon control file
Jan 14 18:22:23 desktop-systemproductname kernel: EXT4-fs error (device dm-0): ext4_validate_block_bitmap:390: comm pool-gnome-keyr: bg 800: bad block bitmap checksum
Jan 14 18:22:46 desktop-systemproductname pulseaudio[1375]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network conne>
[desktop@desktop-systemproductname ~]$ cat /var/log/Xorg.0.log | grep -E "(EE)|(WW)|\error|\failed|\Time"
[    12.307] Current Operating System: Linux desktop-systemproductname 5.10.2-2-MANJARO #1 SMP PREEMPT Tue Dec 22 08:14:42 UTC 2020 x86_64
[    12.307] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 14 18:21:54 2021
[    12.311] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[    12.312] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[    12.312] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    12.312] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    12.312] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    12.312] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    12.316] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    13.368] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    13.538] (WW) NVIDIA(0): Option "NoLogo" is not used
[    13.540] (II) Initializing extension MIT-SCREEN-SAVER
[   170.688] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 12ms, your system is too slow
[   769.381] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 35ms, your system is too slow
[   769.382] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[   769.382] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[   774.066] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 11ms, your system is too slow
[   905.229] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 11ms, your system is too slow
[   954.898] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 12ms, your system is too slow
[   954.898] (EE) event9  - Logitech G Pro : WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  1269.200] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 13ms, your system is too slow
[  1303.300] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[  1303.300] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
[  1327.100] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 37ms, your system is too slow
[  1488.224] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 40ms, your system is too slow
[  1536.875] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 12ms, your system is too slow
[  1555.233] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[  2939.558] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[  2947.528] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[  2967.179] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[  2967.179] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
[  2986.114] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-6ms), your system is too slow
[  3068.647] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 21ms, your system is too slow
[  3068.647] (EE) event2  - Dell Dell Universal Receiver: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  3128.559] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
[  3362.524] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-3ms), your system is too slow
[  3362.524] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-16ms), your system is too slow
[  3398.825] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[  3452.656] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[  3458.185] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[  3491.720] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[  3512.050] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[  3512.050] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
[  3598.898] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[  3666.156] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[  3680.365] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[  3680.365] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[  3732.136] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-14ms), your system is too slow
[  3732.136] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-27ms), your system is too slow
[  3743.546] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[  3753.483] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-8ms), your system is too slow
[  3753.483] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
[  3917.429] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-1ms), your system is too slow
[  3917.429] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-14ms), your system is too slow
[  3945.965] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 15ms, your system is too slow
[  3954.826] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[  4003.175] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[  4020.082] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 35ms, your system is too slow
[  4021.754] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 27ms, your system is too slow
[  4025.272] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 25ms, your system is too slow
[  4059.253] (EE) event9  - Logitech G Pro : client bug: event processing lagging behind by 36ms, your system is too slow
[  4059.253] (EE) event9  - Logitech G Pro : WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  4103.794] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-9ms), your system is too slow
[  4103.794] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-22ms), your system is too slow
[  4110.025] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-4ms), your system is too slow
[  4110.025] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-17ms), your system is too slow
[  4118.122] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-7ms), your system is too slow
[  4118.122] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-20ms), your system is too slow
[  4143.905] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-3ms), your system is too slow
[  4143.905] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-16ms), your system is too slow
[  4194.225] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-7ms), your system is too slow
[  4223.991] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-6ms), your system is too slow
[  4223.991] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-19ms), your system is too slow
[  4420.983] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-1ms), your system is too slow
[  4420.983] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-14ms), your system is too slow
[  4472.135] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[  4472.135] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-13ms), your system is too slow
[  4489.061] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-6ms), your system is too slow
[  4520.691] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[  4520.691] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[  4529.993] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-6ms), your system is too slow
[  4529.994] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-19ms), your system is too slow
[  4835.526] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[  4866.144] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-6ms), your system is too slow
[  4877.806] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[  4914.506] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-8ms), your system is too slow
[  4914.506] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-22ms), your system is too slow
[  5018.329] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-11ms), your system is too slow
[  5071.135] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 22ms, your system is too slow
[  5099.102] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 22ms, your system is too slow
[  5102.430] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 27ms, your system is too slow
[  5115.221] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 22ms, your system is too slow
[  5123.581] (EE) event2  - Dell Dell Universal Receiver: client bug: event processing lagging behind by 18ms, your system is too slow
[  5123.581] (EE) event2  - Dell Dell Universal Receiver: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  5195.417] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[  5245.492] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
[  5247.833] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[  5734.262] (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-4ms), your system is too slow
[  5734.262] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-17ms), your system is too slow
[  5773.571] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-9ms), your system is too slow
[  5789.289] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-11ms), your system is too slow
[  5859.863] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[  5882.505] (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
desktop@desktop-systemproductname ~]$ sudo dmesg -HT
[Do Jan 14 18:21:42 2021] Linux version 5.10.2-2-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Tue Dec 22 08:14:42 UTC 2020
[Do Jan 14 18:21:42 2021] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=8a48a37d-134c-4ddc-b970-66d3418fe5d4 rw quiet cryptdevice=UUID=deaf0408-5f57-4117-b296-bf8a3e8d4af2:luks-deaf0408-5f57-4117-b296-bf8a3e8d4af2 root=/dev/mapper/luks-deaf0408-5f57-4117-b296-bf8a3e8d4af2 apparmor=1 security=apparmor >
[Do Jan 14 18:21:42 2021] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[Do Jan 14 18:21:42 2021] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[Do Jan 14 18:21:42 2021] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[Do Jan 14 18:21:42 2021] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[Do Jan 14 18:21:42 2021] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[Do Jan 14 18:21:42 2021] BIOS-provided physical RAM map:
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x0000000000100000-0x0000000009e0ffff] usable
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x0000000009e10000-0x0000000009ffffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x000000000a200000-0x000000000a20afff] ACPI NVS
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x000000000a20b000-0x000000000affffff] usable
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x000000000b020000-0x00000000d1553fff] usable
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000d1554000-0x00000000d1572fff] ACPI data
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000d1573000-0x00000000da57afff] usable
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000da57b000-0x00000000da6e2fff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000da6e3000-0x00000000da6f0fff] ACPI data
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000da6f1000-0x00000000da7fbfff] usable
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000da7fc000-0x00000000dabbffff] ACPI NVS
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000dabc0000-0x00000000db660fff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000db661000-0x00000000db708fff] type 20
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000db709000-0x00000000ddffffff] usable
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000de000000-0x00000000dfffffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fd100000-0x00000000fd1fffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[Do Jan 14 18:21:42 2021] BIOS-e820: [mem 0x0000000100000000-0x000000041f37ffff] usable
[Do Jan 14 18:21:42 2021] NX (Execute Disable) protection: active
[Do Jan 14 18:21:42 2021] efi: EFI v2.60 by American Megatrends
[Do Jan 14 18:21:42 2021] efi: ACPI 2.0=0xd1554000 ACPI=0xd1554000 SMBIOS=0xdb5ce000 SMBIOS 3.0=0xdb5cd000 ESRT=0xd7e9a818 MEMATTR=0xd7c42018
[Do Jan 14 18:21:42 2021] SMBIOS 3.1.1 present.
[Do Jan 14 18:21:42 2021] DMI: System manufacturer System Product Name/ROG STRIX B350-F GAMING, BIOS 5603 07/28/2020
[Do Jan 14 18:21:42 2021] tsc: Fast TSC calibration failed
[Do Jan 14 18:21:42 2021] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[Do Jan 14 18:21:42 2021] e820: remove [mem 0x000a0000-0x000fffff] usable
[Do Jan 14 18:21:42 2021] last_pfn = 0x41f380 max_arch_pfn = 0x400000000
[Do Jan 14 18:21:42 2021] MTRR default type: uncachable
[Do Jan 14 18:21:42 2021] MTRR fixed ranges enabled:
[Do Jan 14 18:21:42 2021]   00000-9FFFF write-back
[Do Jan 14 18:21:42 2021]   A0000-BFFFF write-through
[Do Jan 14 18:21:42 2021]   C0000-FFFFF write-protect
[Do Jan 14 18:21:42 2021] MTRR variable ranges enabled:
[Do Jan 14 18:21:42 2021]   0 base 000000000000 mask FFFF80000000 write-back
[Do Jan 14 18:21:42 2021]   1 base 000080000000 mask FFFFC0000000 write-back
[Do Jan 14 18:21:42 2021]   2 base 0000C0000000 mask FFFFE0000000 write-back
[Do Jan 14 18:21:42 2021]   3 disabled
[Do Jan 14 18:21:42 2021]   4 disabled
[Do Jan 14 18:21:42 2021]   5 disabled
[Do Jan 14 18:21:42 2021]   6 disabled
[Do Jan 14 18:21:42 2021]   7 disabled
[Do Jan 14 18:21:42 2021] TOM2: 0000000420000000 aka 16896M
[Do Jan 14 18:21:42 2021] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[Do Jan 14 18:21:42 2021] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[Do Jan 14 18:21:42 2021] last_pfn = 0xde000 max_arch_pfn = 0x400000000
[Do Jan 14 18:21:42 2021] esrt: Reserving ESRT space from 0x00000000d7e9a818 to 0x00000000d7e9a850.
[Do Jan 14 18:21:42 2021] e820: update [mem 0xd7e9a000-0xd7e9afff] usable ==> reserved
[Do Jan 14 18:21:42 2021] check: Scanning 1 areas for low memory corruption
[Do Jan 14 18:21:42 2021] Using GB pages for direct mapping
[Do Jan 14 18:21:42 2021] Secure boot could not be determined
[Do Jan 14 18:21:42 2021] RAMDISK: [mem 0x36781000-0x373b7fff]
[Do Jan 14 18:21:42 2021] ACPI: Early table checksum verification disabled
[Do Jan 14 18:21:42 2021] ACPI: RSDP 0x00000000D1554000 000024 (v02 ALASKA)
[Do Jan 14 18:21:42 2021] ACPI: XSDT 0x00000000D1554098 0000AC (v01 ALASKA A M I    01072009 AMI  00010013)
[Do Jan 14 18:21:42 2021] ACPI: FACP 0x00000000D15609C0 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[Do Jan 14 18:21:42 2021] ACPI: DSDT 0x00000000D15541E0 00C7DD (v02 ALASKA A M I    01072009 INTL 20120913)
[Do Jan 14 18:21:42 2021] ACPI: FACS 0x00000000DABA8E00 000040
[Do Jan 14 18:21:42 2021] ACPI: APIC 0x00000000D1560AD8 00015E (v03 ALASKA A M I    01072009 AMI  00010013)
[Do Jan 14 18:21:42 2021] ACPI: FPDT 0x00000000D1560C38 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[Do Jan 14 18:21:42 2021] ACPI: FIDT 0x00000000D1560C80 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[Do Jan 14 18:21:42 2021] ACPI: SSDT 0x00000000D1560D20 0000FC (v02 ALASKA CPUSSDT  01072009 AMI  01072009)
This does not look good.
Also, you seem to have full disk encryption, maybe this is slowing down your system and causes the issue. Do you really need full disk encryption? If not I would recommend backing up and re-installing without encryption.
Or wait until someone joins with more knowledge in encryption.
