Hello, I’ve been trying to get NVIDIA vulkan drivers to work for the past two days now. I started on 5.9, and downgraded to 5.4 LTE with no effect.
~ >>> inxi -G
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 455.45.01
Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
~ >>> ls /usr/share/vulkan/icd.d/
intel_icd.i686.json nvidia_icd.json
~ >>> glxinfo -B [130]
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 4096 MB
Total available memory: 4096 MB
Currently available dedicated video memory: 3831 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GTX 1050 Ti/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 455.45.01
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6.0 NVIDIA 455.45.01
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 455.45.01
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
~ >>> pacman -Qs nvidia
local/egl-wayland 1.1.5+2+g9c9c4c6-1
EGLStream-based Wayland external platform
local/lib32-libvdpau 1.4-1
Nvidia VDPAU library
local/lib32-nvidia-455xx-utils 455.45.01-1
NVIDIA drivers utilities (32-bit)
local/lib32-opencl-nvidia-450xx 450.80.02-1
OpenCL implemention for NVIDIA (32-bit)
local/libvdpau 1.4-1
local/linux54-nvidia-455xx 455.45.01-4 (linux54-extramodules)
NVIDIA drivers for linux.
local/mhwd-nvidia-340xx 340.108-1
MHWD module-ids for nvidia 340.108
local/mhwd-nvidia-390xx 390.132-1
MHWD module-ids for nvidia 390.132
local/mhwd-nvidia-418xx 418.113-1
MHWD module-ids for nvidia-418xx 418.113
local/mhwd-nvidia-430xx 430.64-1.0
MHWD module-ids for nvidia-430xx 430.64
local/mhwd-nvidia-435xx 435.21-1.0
MHWD module-ids for nvidia 435.21
local/mhwd-nvidia-440xx 440.100-1
MHWD module-ids for nvidia 440.100
local/mhwd-nvidia-450xx 450.80.02-1
MHWD module-ids for nvidia 450.80.02
local/mhwd-nvidia-455xx 455.45.01-1
MHWD module-ids for nvidia 455.45.01
local/nvidia-455xx-utils 455.45.01-1
local/xf86-video-nouveau 1.0.16-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
~ >>> pacman -Qs vulkan
local/lib32-vulkan-icd-loader 1.2.158-1
Vulkan Installable Client Driver (ICD) Loader (32-bit)
local/lib32-vulkan-intel 20.2.3-1
Intel's Vulkan mesa driver (32-bit)
local/spirv-tools 2020.4-1 (vulkan-devel)
API and commands for processing SPIR-V modules
local/vkd3d-valve 1.1-2
D3D12 to Vulkan translation library (Valve version)
local/vulkan-headers 1:1.2.160-1 (vulkan-devel)
Vulkan header files
local/vulkan-icd-loader 1.2.158-1
local/vulkan-tools 1.2.159-1 (vulkan-devel)
Vulkan Utilities and Tools
~ >>> vkcube
vkEnumerateInstanceExtensionProperties failed to find the VK_KHR_surface extension.
Do you have a compatible Vulkan installable client driver (ICD) installed?
Please look at the Getting Started guide for additional information.
AFAIK, I have all the prerequisites for vulkan. Yet, it doesn’t work.
Help greatly appreciated
