So I followed the Arch Linux where I have to hold shift or else the grub menu won’t open, and it didn’t work. Now I can’t even boot into manjaro, let alone know how to reverse what I did. I tried booting into manjaro temporarily, but then it just boots into windows. Someone please help because I need it. Thanks
Hi @ub404
Behavior changed after grub menu has been more customized on last updates, idk which one.
Type ESC instead of SHIFT
I think their problem is boot is broken after their attempt to implement ‘silent boot’ configurations …
Nothing has changed You can either…
or hold
