Manjaro Won't Auto-Sleep
Hello friends. I have a minor nuisance of a problem that I was kinda hoping would resolve itself after some kernel or driver update, but it’s been a number of months now and it’s still here so I’m asking for help. Sorry if this is a bit scattered, I’m trying to include whatever relevant info I can.
My computer cannot put itself into sleep mode. It works just fine if I tell it to sleep, but when I leave it inactive it can’t do it. Usually it seems to go to sleep and then instantly wake itself again, but other times not even that will happen and it will just stay on forever. Sometimes after a “flicker”, a floating application window on my second monitor will have been moved to the top of the screen, or my second monitor will no longer have a desktop background (just black) but fix itself after a few seconds.
My current settings are to dim the screen after 3 minutes, and enter sleep at 4 minutes. I’ve tried various ways of changing this and nothing worked there.
I tried journalctl --since "2 min ago" --grep=sleep right after one of these flickers and I get
Apr 01 14:06:57 kitt-sys kernel: ACPI: PM: Waking up from system sleep state S3
Apr 01 14:06:57 kitt-sys systemd-sleep[18688]: System returned from sleep operation 'suspend'.
Apr 01 14:06:58 kitt-sys systemd[1]: Stopped target Sleep.
Apr 01 14:06:58 kitt-sys ModemManager[973]: <msg> [sleep-monitor-systemd] system is resuming
Apr 01 14:06:58 kitt-sys NetworkManager[793]: <info>  [1711994818.6145] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Apr 01 14:06:58 kitt-sys NetworkManager[793]: <info>  [1711994818.6146] device (enp5s0): state change: activated -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
this is not a hardware issue as I don’t have any other input issues with my peripherals, and this is not a problem on my windows boot
and here is the full output of inxi -v8azy
  Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=b372f6d7-b299-4755-bfeb-f9b21ff8ab3c rw quiet apparmor=1
    security=apparmor resume=UUID=e8af64ed-62a4-40f2-b41d-f3e0ce63bfe1
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASRock model: X570 Phantom Gaming 4S
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: P4.10 date: 06/23/2021
  System RAM: total: 16 GiB available: 15.54 GiB used: 8.1 GiB (52.1%)
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3600C16-8GVKC serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: no module installed
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
    desc: 2x16 MiB
  Speed (MHz): avg: 2315 high: 3600 min/max: 2200/4208 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 2196
    3: 2200 4: 2195 5: 2200 6: 2194 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
    12: 2195 bogomips: 86277
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
    process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 0c:00.0
    chip-ID: 1002:731f class-ID: 0300
  Device-2: ARC USB2.0_CAM1 driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 05a3:2053
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1717 s-dpi: 96 s-size: 1013x453mm (39.88x17.83")
    s-diag: 1110mm (43.69")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-right
    model: Acer SB220Q serial: <filter> built: 2020 res: 1920x1080 hz: 75
    dpi: 102 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green: x: 0.322 y: 0.612
    blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
    size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-l
    model: ViewSonic VA1655-FHD serial: <filter> built: 2022 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.584 y: 0.365 green: x: 0.349
    y: 0.580 blue: x: 0.161 y: 0.141 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080, 1600x1200, 1680x1050, 1400x1050, 1600x900, 1280x1024,
    1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 16.0.6 DRM 3.54 6.6.19-1-MANJARO) device-ID: 1002:731f
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv v: 24.0.2-manjaro1.1
    device-ID: 1002:731f surfaces: xcb,xlib
  Device-1: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
    driver: snd_emu10k1 v: kernel bus-ID: 04:00.0 chip-ID: 1102:0008
    class-ID: 0401
  Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab38
    class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: ASRock
    bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: ARC USB2.0_CAM1 driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
  Device-5: JMTek LLC. TKGOU PnP USB Microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-4:2 chip-ID: 0c76:1467 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.39 TiB used: 429.38 GiB (30.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
    model: SPCC M.2 PCle SSD size: 953.87 GiB block-size: physical: 512 B
    fw-rev: S1111A0L temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 0502 scheme: MBR
  ID-1: / raw-size: 745.02 GiB size: 732.26 GiB (98.29%)
    used: 429.34 GiB (58.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: Manjaro uuid: b372f6d7-b299-4755-bfeb-f9b21ff8ab3c
    used: 27 MiB (9.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: F15D-490C
  ID-1: swap-1 type: partition size: 17.12 GiB used: 10.8 MiB (0.1%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: e8af64ed-62a4-40f2-b41d-f3e0ce63bfe1
  ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 190.64 GiB fs: ntfs label: N/A
    uuid: 040C99250C991332
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 780 MiB fs: ntfs label: N/A
    uuid: 0470F34470F33B4E
  ID-4: /dev/sda1 maj-min: 8:1 size: 277.34 GiB fs: ext4 label: Sawtooth
    uuid: 8fddbfdb-487f-4e9b-b545-fd4fe821d0ff
  ID-5: /dev/sda2 maj-min: 8:2 size: 188.41 GiB fs: ntfs label: backitt
    uuid: 53B249F7414E9E87
  Device-1: 1-1:2 info: Cooler Master SK650 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 2516:008d class-ID: 0300
  Device-2: 1-2:3 info: Holtek E-Signal LUOM G10 Mechanical Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 04d9:a09f class-ID: 0300
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-6:2 info: ARC USB2.0_CAM1 type: video,audio
    chip-ID: 05a3:2053 class-ID: 0102 serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-4:2 info: JMTek LLC. TKGOU PnP USB Microphone type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
    chip-ID: 0c76:1467 class-ID: 0300 serial: <filter>
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 6-1:2 info: Seagate RSS LLC Expansion Portable type: mass storage
    driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 144mA chip-ID: 0bc2:2321 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 46.9 C mobo: N/A gpu: amdgpu temp: 55.0 C
    mem: 60.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 819
  Packages: pm: pacman pkgs: 2196 libs: 489 tools: pamac,trizen pm: flatpak
    pkgs: 0
    1: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    3: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    4: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    5: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    6: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    7: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    8: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 319
  1: cpu: 13.0% command: Discord pid: 35316 mem: 387.5 MiB (2.4%)
  2: cpu: 6.1% command: Discord pid: 35230 mem: 303.3 MiB (1.9%)
  3: cpu: 1.4% command: firefox pid: 2184 mem: 863.3 MiB (5.4%)
  4: cpu: 1.1% command: Xorg pid: 1112 mem: 123.8 MiB (0.7%)
  5: cpu: 1.0% command: kwin_x11 pid: 1484 mem: 224.8 MiB (1.4%)
  Memory top: 5 of 319
  1: mem: 1225.5 MiB (7.7%) command: plasmashell pid: 1547 cpu: 0.0%
  2: mem: 863.3 MiB (5.4%) command: firefox pid: 2184 cpu: 1.4%
  3: mem: 693.1 MiB (4.3%) command: firefox pid: 2379 cpu: 0.1%
  4: mem: 634.2 MiB (3.9%) command: firefox pid: 2364 cpu: 0.2%
  5: mem: 604.4 MiB (3.7%) command: steamwebhelper pid: 4460 cpu: 0.8%
  Processes: 319 Power: uptime: 1d 8h 1m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: yakuake inxi: 3.3.33
Can you search in your log if you find the string dcn32_determine_det_override?
~ >>> journalctl --grep=dcn32_determine_det_override --since "10 days ago"
-- Boot 5848d65fa0714441b8151e0349ebf8ed --
-- Boot fd01668a7771449a81f62ef3c44fab25 --
-- Boot b581245e2a6940c6ac94154a24d16d15 --
-- Boot 9c9d5beb7d3f416997464bf74caba1fb --
-- Boot 7bc16883e09148cb9e6f53d413ff4cc5 --
-- No entries --
seems not
The newest kernel update has finally fixed this for me. Here’s hoping it won’t break again!
