Manjaro wallpapers by muser (vol. 1)
artwork
wallpaper
#107
If you want i can make it for you but you have to give me a reference image because i have searched in google that album cover and there are lots of versions wich i don’t really know if the image is from the original cover or if you want something different.
#108
I made two versions. Is something like this you had in mind?
#109
I didn’t want to encourage anything that might get cause a copyright problem
…but having seen so many variations on an image search, another tribute should be no problem
Front cover
Rear cover
Inner
The front cover shows white light changed to coloured stripes by a prism, and back to white on rear cover.
The triangle section on the stripes on @muser design was the bit that reminded me of the original inner design with the green stripe looking like an ECG heartbeat trace. like the concept that Manjaro combines the colours to white
#110
Aha, a Pink Floyd fan, aren’t you?
#111
Actually I did those on nikgnomic’s request. :slight_smile:
They are based on the album cover you posted but I didn’t want them to look too similar, either.
#112
I know, it’s just to show others who might not know the Pink Floyd album.
And for a bright, modern twist:
http://www.chungcugoldenland.info/data/out/282/47555425-4k-wallpaper-dark.jpg
#114
wow - now i am spoilt for choice - thanks to all
Perfect!!! Just what I was looking for for my login screen! :relaxed:
Made this to go with the Vertex-Maia theme
with matching whiskermenu icon
Appmenu/whiskermenu icons
#117
I like circles. But I also like what you did with minifying/unifying the the icon :slight_smile:
[interesting also - makes me think of an upside-down μ, like from μtorrent - maybe it makes it μltra metal.]
#119
Something more simple, but still along the Vertex-maia line
#120
#121
would be awesome without the logo also
#123
Thank you. I appreciate that.
#124
Simple grey
#125
Some Arch versions (fyi @Annoyingduck)
#126
Dude, I’m amazed… Thank you for all your work!!
I use the default wallpaper of KDE and would love to see if you did a Wallpaper that maintained the colours, but in a little (only a little!) bit darker, and more minimalistic way. (Branded)
I downloaded lots of your WPs! You’re work is great, I’ll be stepping by every week I guess, hehehe
