Manjaro wallpapers by muser (vol. 1)
artwork
wallpaper
#45
Manjaro-Architect logo
#46
So you are willing to take requests? Because I’m trying to theme a Manjaro background off of the background I’m using for Windows.
https://goo.gl/images/mYkvXw
That’s the background I’m using. Something similar to that with the logo being white and the colors being in the stripes. I hope that’s not too much of a bother. Thank you!
#49
Ok, so it’s not exactly the same but this what I came up with so far (I left out the corners because I don’t think that really suits the main theme).
Let me know if you’d like the stripes more weathered or any other modifications.
#50
That looks awesome! Is there anyway you could make the stripes the color of Manjaro? Like green and turquoise and such? And maybe a bit more weathered? If that’s too much work then don’t worry about it.
#52
The size is perfect. And leaving out the corner lines was an awesome choice. Thank you so much man. I really like your work
#53
I am now also interested in this wallpaper…
May I propose an edition with a greyish (numix?) bg color ? And/or possibly texture ?
#54
Downloaded this one. Thanks!
#55
Ok, so this is with more weather and more Manjaro colours.
I used manjaro-green and maia-green at the top and bottom, orange from the default wallpaper and some blue to balance it all out.
#56
Here it is, with grey textured backround. Is this something you had in mind?
I had to scale it down because it got bigger than 1MB, you can find the full resolution version here: https://app.box.com/v/mwallpapers
#57
That looks awesome. Thank you so so much!
#58
I lost the xcf so one last version before moving on.
Smaller stripes and centered logo
I ended up downloading the grey textured one. It looks great on my desktop. Thank you so much.
#60
Yep thats what I meant :smiley:
#61
Two more for LXDE (fyi @Thanos_Apostolou)
#62
@muser Thx for the wallpapers! The package lxde-wallpapers is already in the unstable branch. The wallpapers included by now, which are located at /usr/share/backgrounds, are these (I changed the names in some in order to make sure they are unique):
Inspired by one of the April screenshots.
Dark version, no branding.
Light version
#64
More of the “branches” theme (no branding to keep it simple).
Blue-dark
Blue-darker
Purple-light
#65
Ribbons (there is no logo here, either, or is there?)
#66
Hey, with a fourth ribbon you could have a type of Manjaro logo in the middle. And you could highlight it with a circle around it. Maybe that’s worth a try?
Like your backgrounds a lot! Thx!
