Manjaro Wall in 1920 x 1080 HD
wallpaper
#1
“gimped” this wall… thanks for view and / or download :slight_smile:
https://dl.dropboxusercontent.com/u/38232687/Walls/manjaro-lightsup-my-desktop.png
#2
eye of soron :innocent:
#3
Eye of pacman :grin: The all-seeing package manager.haha
#4
Very nice @rvc. Is there any easy way you can change the green to a blue?
#5
BLUE
DUALTONE
Thanks #rvc.
#7
you r welcome mate :slight_smile:
#8
BLUE ver-2
#9
Thanks again @rvc. That is even better.
#10
yea… felt so, so i posted… :slight_smile: glad you like :slight_smile:
#11
Do you have to start from scratch each time or is there an easy way to just adjust the color via a wheel or RGB setting?
#12
nope, got the xcf, tell me if u wish to play around… will send you over the xcf
#13
That sounds interesting. How do I get to xcf?
#14
open in gimp and play as you like :slight_smile:
#15
OK. I will give it a try.
#16
version1
version2
version3
version4
Are all these available in a file?
#20
can download and use / modify… let me know if you need the xcf [raw file]
