I’m having an issue on Manjaro KDE where the SDDM Login screen resolution is very low, to the point that I can barely login and am unable to see the buttons to restart/shutdown/logout etc; it’s like it’s at 600x400 or something, instead of 1920x1080.
GRUB is fine and at 1920x1080 and the new Boot Splash Screen (Manjaro) seems to be the correct resolution as well.
I have 2 sometimes 3 monitors turned on and set at a time, all set to 1920x1080.
This seems to be something new, since installing a fresh copy of Manjaro, although this is an AMD card instead of a Nvidia, but not sure that matters or not?
A few things I’ve tried:
- Set DPI as shown here: SDDM - ArchWiki in
/etc/sddm.conf.d/dpi.conf
[X11]
ServerArguments=-nolisten tcp -dpi 96
xdpyinfo | grep resolution
resolution: 96x96 dots per inch
- Tried changing
EnableHiDPI=false
to true in/etc/sddm.conf
- Tried several times to set to “Apply Plasma Settings” under Settings > Startup and Shutdown > Login Screen (SDDM) (this randomly seemed to work at least once)
- Changed the theme from Breath to Breeze and back.
- Changed the background image to one that was 1920x1080
Not sure what else to try and would appreciate any suggestions, thanks!
Uranos 23.0.4
manjaro-kde-23.0.1-230911-linux65.iso
KDE Plasma Version: 5.27.8
KDE Frameworks Version: 5.110.0
Qt Version: 5.15.11
Kernel Version: 6.5.5-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 × AMD Ryzen 7 5800X 8-Core Processor
Memory: 15.5 GiB of RAM
Graphics Processor: AMD Radeon RX 570 Series
Manufacturer: Micro-Star International Co., Ltd
Product Name: MS-7B86
System Version: 3.0
inxi -Fazy
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
root=UUID=0b139373-48b7-42a3-916c-d23b0d064a4f rw rootflags=subvol=@ quiet
splash resume=UUID=2e044274-d1a5-4f84-8868-e1e2718f555c
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7B86 v: 3.0
serial: <superuser required>
Mobo: Micro-Star model: B450 GAMING PLUS MAX (MS-7B86) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.J0
date: 08/16/2023
Device-1: hid-98:5a:eb:bf:ae:bd-battery model: Apple Keyboard serial: N/A
charge: N/A status: discharging
Device-2: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: discharging
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2546 high: 3599 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2920 5: 2880 6: 2200 7: 2200 8: 3599 9: 2875 10: 2200 11: 2200
12: 2879 13: 2200 14: 2200 15: 2200 16: 3586 bogomips: 121663
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-1,DP-2 off: HDMI-A-1
empty: DP-3,DVI-D-1 bus-ID: 26:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 54.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right model: Asus VH236H
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: left model: Acer S241HL
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 note: disabled size-res: N/A
modes: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (polaris10
LLVM 16.0.6 DRM 3.54 6.5.5-1-MANJARO) device-ID: 1002:67df memory: 3.91 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 570 Series (RADV POLARIS10) driver: mesa radv
v: 23.1.9-manjaro1.1 device-ID: 1002:67df surfaces: xcb,xlib
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 26:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: active tools: pw-cli
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-1e535cdc2933 state: down mac: <filter>
IF-ID-2: br-5713bcfbe4f7 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 0a12:0001 class-ID: fe01
Local Storage: total: 2.72 TiB used: 1.49 TiB (54.8%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: B1D2 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000BEKT-00KA9T0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10JMVW-11AJGS2 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1007 scheme: GPT
ID-1: / raw-size: 914.12 GiB size: 914.12 GiB (100.00%)
used: 326.69 GiB (35.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 914.12 GiB size: 914.12 GiB (100.00%)
ID-4: /var/log raw-size: 914.12 GiB size: 914.12 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.1 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 36.0 C mobo: 36.0 C gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): fan-1: 821 fan-2: 4017 fan-3: 4639 fan-4: 603 fan-5: 1221
fan-6: 1147 gpu: amdgpu fan: 207
Processes: 435 Uptime: 29m wakeups: 3 Memory: total: 16 GiB
available: 15.54 GiB used: 8.2 GiB (52.8%) Init: systemd v: 254
Packages: 1629 pm: pacman pkgs: 1617 libs: 454 tools: pamac,yay pm: flatpak
pkgs: 12 Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.30
