Manjaro v19.04 for rpi3 dropping wired connection
So I just installed 19.04 on my rpi3, and my wired connection is constantly dropping. I was using raspbian, and everything was working fine, so I know it's not a hardware issue. I've double checked the version and I'm sure I downloaded the correct one. It's constantly getting connection established/connection lost, every second or two. I installed 19.02 a few months ago and got the same thing, so I switched, but I can't stand raspbian, so I'd like to get this version working.
Any suggestions are greatly appreciated
First thing, test installing different kernels with Manjaro Settings Manager. If it is an r8168 Realtek NIC then switch to the r8169 kernel module instead of using the r8168 driver.
This is hard to do by guesswork. Some system specs would be helpful.
Please post the text output (not a pic) of:
inxi -Fxxxz
Only 1 kernel is available for the Raspberry Pi. :slight_smile:
Here ya go
  Host: hermes Kernel: 5.0.7-1-MANJARO-ARM aarch64 bits: 64
  compiler: gcc v: 8.2.1 Desktop: LXQt 0.14.1 tk: Qt 5.12.2
  info: lxqt-panel wm: Openbox 3.6.1 dm: SDDM
  Distro: Manjaro ARM
  Type: ARM Device System: Raspberry Pi 3 Model B
  details: N/A serial: <filter>
  Device-1: hidpp_battery_0
  model: Logitech Wireless Touch Keyboard K400 Plus
  serial: <filter> charge: 100% (should be ignored)
  rechargeable: yes status: Discharging
  Topology: Quad Core model: N/A variant: cortex-a53
  bits: 64 type: MCP arch: ARMv8 rev: 4
  features: Use -f option to see features bogomips: 0
  Speed: N/A min/max: N/A
  Core speeds (MHz): No speed data found for 4 cores.
  Device-1: bcm2835-hdmi driver: vc4_hdmi v: N/A
  bus ID: N/A chip ID: brcm:3f902000
  Device-2: bcm2835-vc4 driver: vc4_drm v: N/A bus ID: N/A
  chip ID: brcm:soc
  Display: x11 server: X.org 1.20.4 driver: fbturbo
  resolution: <xdpyinfo missing>
  Message: Unable to show advanced data. Required tool
  glxinfo missing.
  Device-1: bcm2835-hdmi driver: vc4_hdmi bus ID: N/A
  Sound Server: ALSA v: k5.0.7-1-MANJARO-ARM
  Device-1: mmc-pwrseq-simple driver: pwrseq_simple v: N/A
  port: N/A bus ID: N/A
  chip ID: mmc-pwrseq-simple:wifi-pwrseq
  Device-2: Standard Microsystems SMSC9512/9514 Fast
  Ethernet Adapter
  type: USB driver: smsc95xx bus ID: 1-1.1:3
  chip ID: 0424:ec00
  IF: eth0 state: up speed: 100 Mbps duplex: full
  mac: <filter>
  IF-ID-1: wlan0 state: down mac: <filter>
  Local Storage: total: 29.72 GiB used: 3.53 GiB (11.9%)
  ID-1: /dev/mmcblk0 vendor: SanDisk model: SL32G
  size: 29.72 GiB serial: <filter> scheme: MBR
  ID-1: / size: 29.11 GiB used: 3.46 GiB (11.9%) fs: ext4
  dev: /dev/mmcblk0p2
  ID-2: /boot size: 93.8 MiB used: 71.1 MiB (75.8%)
  fs: vfat dev: /dev/mmcblk0p1
  System Temperatures: cpu: 45.1 C mobo: N/A
  Processes: 140 Uptime: 1h 14m Memory: 903.3 MiB
  used: 518.8 MiB (57.4%) Init: systemd v: 241 Compilers:
  gcc: N/A Shell: bash v: 5.0.2 running in: qterminal
  inxi: 3.0.32
Dooooh, that's pretty limiting.
Thanks for the info, my bad.
Since the update of systemd n some other packages which were pushed few days ago.
My Wi-Fi and lan is connected to the router but cannot browser?
I am getting the dhcp ip address from router to the device on both Wi-Fi and lan but still no connection?
What would be the case?
Just tested it with my house wifi and it works fine but with office wifi and lan it doesnt let me browse :frowning:
This topic was automatically closed after 90 days. New replies are no longer allowed.
