Manjaro v17.0.2 released
stable
release-final
release-announcement
#23
All the official ISOs and most community edition have it installed as manjaro-documentation, yes.
Where installed It also has a desktop launcher in the live environment.
#32
I just installed Manjaro KDE from new iso on my T520, works great. Thank you guys.
#33
Congratulations on another flawlessy easy release. Easy to use, easy to install, and easy to update.
#34
Manjaro KDE Plasma works surprisingly acceptable in very old hardware, a ~10yo laptop (pentium d dual core), the ones with win vista.
It takes a couple of minutes to boot up and 1-3 seconds to open things but overall, once they load up, everything’s smooth.
Good work Philm and Manjaro Team!
#35
Gtk applications in KDE take a long time to show (15+ seconds) after pressing menu icon or start from terminal. Terminal output reveals errors/warnings, as stated in my reply to this thread:
#36
Smooth :thumbsup:
#37
so that’s why my manjaro KDE doesn’t have a plymouth. Why, then, it was removed?Is there some bug issues?
#38
Is it flickering only during boot? Cause as what I’ve experienced its a hardware part of flickering…
#39
Yes, only during boot
#40
yes, all our install media drop Plymouth service . Maintain Plymouth have more cons than pro . You can Always reinstall if you want it … Plymouth is an old project of Fedora and not needed now with modern system or …
#41
so upon start up its all black already…after grub?
Instead of seeing this image?
#42
In modern pc with ssd the blank screen appear only for 3/5 sec :wink:
In my i5 7200 with a normal HD Gnome boot in +/- 10 sec ( login screen ) .
With Plymouth the time increase and not in all situation but sometime plymouth service not quit fine …
#43
Yes, then return back to plymouth screen. it doesn’t matter plymouth is on or off. During boot I have flickering (screen suddenly turns off - shows blank screen, then turns on)
#44
I think, the problem is related to systemd-backlight@backlight:intel_backlight.service or all Intel graphics services which are enabled on boot, because my grub screen brightness is too high, after flickering the screen brightness becomes lower ( which I set this in Gnome Desktop)
#45
A post was merged into an existing topic: Joyful July (2017) Screenshots
#49
I thank everyone for their Hard works. It’s a great distro and has much to commend it.
