Updated today (31 Dec 2020), had to move on to 5.9 or 5.10 kernel, and of course, update the nVidia drivers.
I figured out how to get nVidia’s proprietary drivers installed (I do wish to play graphically intense games), but the NVIDIA X Server Settings tool did not recognize my monitors as being 1440p displays, as they did before.
I read that I may modify /etc/X11/mhwd.d/nvidia.conf to add this line to help:
Option "ModeValidation" "AllowNonEdidModes"
This helped me gain 2048x1152, but still does not meet the upper limit of what my HPN HP 32 QHD monitors can do.
The nvidia.conf.nvidia-xconfig-original file did not have this line.
I’ve heard that sometimes nVidia has trouble reading the EDID modes properly from a monitor, and I wonder if there is something one may do to correct this.
From this command:
xrandr --verbose | edid-decode
I get the following output:
edid-decode (hex):
00 ff ff ff ff ff ff 00 22 0e 0c 36 01 01 01 01
2b 1d 01 03 80 47 28 78 2a f8 a5 a6 56 4e a1 25
0d 50 54 a1 08 00 d1 c0 a9 c0 81 c0 d1 00 b3 00
95 00 81 80 a9 40 56 5e 00 a0 a0 a0 29 50 30 20
35 00 c5 8f 21 00 00 1a 00 00 00 fd 00 26 4c 18
70 22 00 0a 20 20 20 20 20 20 00 00 00 fc 00 48
50 20 33 32 20 51 48 44 0a 20 20 20 00 00 00 ff
00 43 4e 4b 39 34 33 31 4d 43 53 0a 20 20 01 10
02 03 2a f1 49 10 1f 04 13 03 12 02 11 01 23 09
07 07 83 01 00 00 67 03 0c 00 10 00 00 44 68 1a
00 00 01 01 26 4b ed e2 00 2b 02 3a 80 18 71 38
2d 40 58 2c 45 00 c5 8f 21 00 00 1e 02 3a 80 d0
72 38 2d 40 10 2c 45 80 c5 8f 21 00 00 1e d9 76
00 a0 a0 a0 34 50 30 20 35 00 c5 8f 21 00 00 1a
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6d
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: HPN
Model: 13836
Serial Number: 16843009
Made in: week 43 of 2019
Basic Display Parameters & Features:
Digital display
Maximum image size: 71 cm x 40 cm
Gamma: 2.20
DPMS levels: Off
RGB color display
First detailed timing is the preferred timing
Color Characteristics:
Red : 0.6513, 0.3388
Green: 0.3066, 0.6289
Blue : 0.1464, 0.0527
White: 0.3134, 0.3291
Established Timings I & II:
IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz
DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz
DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz
DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz
Standard Timings:
DMT 0x52: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz
DMT 0x53: 1600x900 60.000 Hz 16:9 60.000 kHz 108.000 MHz (RB)
DMT 0x55: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz
DMT 0x45: 1920x1200 59.885 Hz 16:10 74.556 kHz 193.250 MHz
DMT 0x3a: 1680x1050 59.954 Hz 16:10 65.290 kHz 146.250 MHz
DMT 0x2f: 1440x900 59.887 Hz 16:10 55.935 kHz 106.500 MHz
DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz
DMT 0x33: 1600x1200 60.000 Hz 4:3 75.000 kHz 162.000 MHz
Detailed Timing Descriptors:
DTD 1: 2560x1440 59.951 Hz 16:9 88.787 kHz 241.500 MHz (709 mm x 399 mm)
Hfront 48 Hsync 32 Hback 80 Hpol P
Vfront 3 Vsync 5 Vback 33 Vpol N
Display Range Limits:
Monitor ranges (GTF): 38-76 Hz V, 24-112 kHz H, max dotclock 340 MHz
Display Product Name: 'HP 32 QHD'
Display Product Serial Number: 'CNK9431MCS'
Extension blocks: 1
Checksum: 0x10
Block 1, CTA-861 Extension Block:
Revision: 3
Underscans IT Video Formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 1
Video Data Block:
VIC 16: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz
VIC 31: 1920x1080 50.000 Hz 16:9 56.250 kHz 148.500 MHz
VIC 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz
VIC 19: 1280x720 50.000 Hz 16:9 37.500 kHz 74.250 MHz
VIC 3: 720x480 59.940 Hz 16:9 31.469 kHz 27.000 MHz
VIC 18: 720x576 50.000 Hz 16:9 31.250 kHz 27.000 MHz
VIC 2: 720x480 59.940 Hz 4:3 31.469 kHz 27.000 MHz
VIC 17: 720x576 50.000 Hz 4:3 31.250 kHz 27.000 MHz
VIC 1: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz
Audio Data Block:
Linear PCM:
Max channels: 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 24 20 16
Speaker Allocation Data Block:
FL/FR - Front Left/Right
Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
Source physical address: 1.0.0.0
Maximum TMDS clock: 340 MHz
Vendor-Specific Data Block (AMD), OUI 00-00-1A:
01 01 26 4b ed '..&K.'
Video Capability Data Block:
YCbCr quantization: No Data
RGB quantization: No Data
PT scan behavior: Always Underscanned
IT scan behavior: Always Underscanned
CE scan behavior: Supports both over- and underscan
DTD 2: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (709 mm x 399 mm)
Hfront 88 Hsync 44 Hback 148 Hpol P
Vfront 4 Vsync 5 Vback 36 Vpol P
DTD 3: 1920x1080 50.000 Hz 16:9 56.250 kHz 148.500 MHz (709 mm x 399 mm)
Hfront 528 Hsync 44 Hback 148 Hpol P
DTD 4: 2560x1440 74.971 Hz 16:9 111.857 kHz 304.250 MHz (709 mm x 399 mm)
Vfront 3 Vsync 5 Vback 44 Vpol N
Checksum: 0x6d
I feel I must be close to some kind of solution, but I haven’t quite figured out how to get this EDID recognized properly.
I’ve tried using some output from cvt for the desired resolution and incorporating that into the nvidia.conf file, or using xrandr to do stuff with it, but it doesn’t work… when I try to use the 2560x1440 mode with the monitor, I get an error:
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 45
Current serial number in output stream: 46
(And for the curious:)
Screen 0: minimum 8 x 8, current 4096 x 1152, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 connected primary 2048x1152+2048+0 (normal left inverted right x axis y axis) 710mm x 400mm
1920x1080 60.00 + 59.94 59.93 50.00
2048x1152 59.91*
1920x1200 59.95
1680x1050 59.95 59.88
1600x1200 60.00
1600x900 60.00 59.95 59.82
1440x900 59.89
1440x810 59.97
1400x1050 74.76 59.98
1400x900 59.96 59.88
1368x768 59.88 59.85
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.91 59.81 59.97
1280x720 60.00 59.94 59.86 59.74 50.00 60.00 59.99
1152x864 75.00
1024x768 75.03 70.07 60.00 60.04
1024x576 59.90 59.82 59.96 59.95
960x720 75.00 60.00
960x600 60.00 59.93
960x540 59.82 59.63 59.99 59.96
928x696 75.00 60.05
896x672 75.05 60.01
864x486 59.92 59.57
840x525 60.01 59.88
832x624 74.55
800x600 75.00 72.19 60.32 56.25 75.00 70.00 65.00 60.00
800x450 59.95 59.82
720x576 50.00
720x480 59.94
720x405 59.51 58.99
700x525 74.76 59.98
700x450 59.96 59.88
684x384 59.88 59.85
640x512 75.02 60.02
640x480 75.00 72.81 59.93 59.94 60.00
640x400 59.98 59.88
640x360 59.86 59.83
576x432 75.00
512x384 75.03 70.07 60.00
512x288 60.00 59.92
480x270 59.82 59.63
432x243 59.92 59.57
416x312 74.66
400x300 75.12 72.19 60.32 56.34
360x202 59.51 59.13
320x240 75.00 72.81 60.05
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 connected 2048x1152+0+0 (normal left inverted right x axis y axis) 710mm x 400mm
2048x1152 59.91*
1920x1200 59.95
1600x1200 60.00
1440x900 59.89
1440x810 59.97
1280x960 60.00
1152x864 75.00
960x720 75.00 60.00
960x600 60.00 59.93
928x696 75.00 60.05
896x672 75.05 60.01
864x486 59.92 59.57
840x525 60.01 59.88
832x624 74.55
800x450 59.95 59.82
720x576 50.00
720x480 59.94
720x405 59.51 58.99
700x525 74.76 59.98
700x450 59.96 59.88
684x384 59.88 59.85
640x512 75.02 60.02
640x400 59.98 59.88
640x360 59.86 59.83
576x432 75.00
512x288 60.00 59.92
480x270 59.82 59.63
432x243 59.92 59.57
416x312 74.66
360x202 59.51 59.13
USB-C-0 disconnected (normal left inverted right x axis y axis)
2560x1440_60.00 (0x288) 312.250MHz -HSync +VSync
h: width 2560 start 2752 end 3024 total 3488 skew 0 clock 89.52KHz
v: height 1440 start 1443 end 1448 total 1493 clock 59.96Hz
So… any ideas?
