Hello everyone, I am having problems with my Manjaro KDE on my laptop and it is getting really annoying.
My laptop screen goes black after idling for around 15-20 minutes and stops responding until I hard reset it. I have tried REISUB/REISUO and it doesn’t work. I know that the laptop isn’t going to sleep because the power led which blinks in the sleep mode stays on as usual. The issue happens at least twice or thrice in a week and I can’t seem to reproduce it since I have no idea what triggers it. I am quite new to Linux and it is a little too soon for me to make sense of the logs.
I have tried using different kernels, but my touchpad doesn’t seem to work after waking from sleep in some of them and in others the problem persists.
I added deep sleep to grub options in case it was hybrid sleep that was causing the issue but it doesn’t seem to help.
GRUB_CMDLINE_LINUX_DEFAULT=“quiet apparmor=1 security=apparmor udev.log_priority=3 mem_sleep_default=deep”
output of inxi --admin --verbosity=7 --filter --no-host
Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=452a2695-e60d-45c2-af8c-6910f1c42ca7 rw quiet apparmor=1
sysrq_always_enabled=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 81YM v: IdeaPad 5 14ARE05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 14ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: DTCN23WW(V1.09)
date: 10/26/2020
ID-1: BAT1 charge: 41.5 Wh (77.0%) condition: 53.9/56.5 Wh (95.4%)
volts: 12.2 min: 11.6 model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31
0x39 0x43 0x33 0x50 0x5650
type: Li-ion serial: <filter> status: Discharging cycles: 32
RAM: total: 15.07 GiB used: 1.19 GiB (7.9%)
RAM Report:
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1397 high: 1401 min/max: 1400/2000 boost: disabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1397 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1394 8: 1401 bogomips: 31952
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b6ee class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 2.74 TiB used: 32.85 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105
temp: 29.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
rev: AL2QFXV7 temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD My Passport 25E1 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1015 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 32.85 GiB (7.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 452a2695-e60d-45c2-af8c-6910f1c42ca7
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: D9F9-D5EB
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 260 MiB fs: vfat
label: SYSTEM_DRV uuid: 3851-5BD4
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 97.66 GiB fs: ntfs
label: Windows-SSD uuid: 80E651F5E651EC42
ID-4: /dev/nvme1n1p4 maj-min: 259:7 size: 378.04 GiB fs: ntfs
label: Secondary uuid: 20E25E0FE25DEA14
ID-5: /dev/nvme1n1p5 maj-min: 259:8 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: 8A3C53053C52EBA7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Chicony Integrated Camera type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55a2 class-ID: ef00
Device-2: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: Western Digital My Passport (WD20NMVW)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 1058:25e1 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 250 Uptime: 1m wakeups: 118 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1254 lib: 339 flatpak: 0
Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10
output of journalctl -xe -p3 -b-1 -q --quiet --no-hostname
output of `journalctl -xe -p3 -b-1 -q --quiet --no-hostname`
[ 4.466] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 4.466] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 4.736] (II) Initializing extension MIT-SCREEN-SAVER
[ 4.790] (EE) AMDGPU(0): Failed to make import prime FD as pixmap: 22
[ 5.481] (EE) libinput: MSFT0002:00 04F3:317F Touchpad: Failed to create a device for /dev/input/mouse1
[ 5.481] (EE) PreInit returned 2 for "MSFT0002:00 04F3:317F Touchpad"
[ 3824.107] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: kernel bug: Touch jump detected and discarded.
[ 3993.539] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: kernel bug: Touch jump detected and discarded.
[ 3995.205] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: kernel bug: Touch jump detected and discarded.
[ 3995.762] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: kernel bug: Touch jump detected and discarded.
[ 3995.762] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: WARNING: log rate limit exceeded (5 msgs per 24h). Discarding future messages.
[ 3998.644] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 7522.733] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: invalid gesture event GESTURE_EVENT_PINCH in state GESTURE_STATE_NONE
[ 7523.180] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: invalid gesture event GESTURE_EVENT_PINCH in state GESTURE_STATE_NONE
[ 7523.887] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: invalid gesture event GESTURE_EVENT_PINCH in state GESTURE_STATE_NONE
[ 7526.844] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: invalid gesture event GESTURE_EVENT_PINCH in state GESTURE_STATE_NONE
[ 7526.935] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: invalid gesture event GESTURE_EVENT_PINCH in state GESTURE_STATE_NONE
[ 12382.897] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 13784.258] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: client bug: event processing lagging behind by 224ms, your system is too slow
[ 13919.549] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 16640.646] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 16753.224] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: invalid gesture event GESTURE_EVENT_PINCH in state GESTURE_STATE_NONE
[ 16758.461] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: invalid gesture event GESTURE_EVENT_PINCH in state GESTURE_STATE_NONE
[ 16759.024] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: invalid gesture event GESTURE_EVENT_PINCH in state GESTURE_STATE_NONE
[ 17759.317] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 17760.697] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 17771.478] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 17940.298] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 19362.298] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 23789.534] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
[ 23821.492] (EE) event8 - MSFT0002:00 04F3:317F Touchpad: libinput bug: tp_gesture_end in unknown gesture mode
Dec 16 16:51:07 systemd[1]: Failed to start pkgfile database update.
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ Defined-By: systemd
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 191 and the job result is failed.
Dec 16 16:51:16 kernel: scsi 0:0:0:1: Wrong diagnostic page; asked for 1 got 8
Dec 16 16:51:16 kernel: scsi 0:0:0:1: Failed to get diagnostic page 0x1
Dec 16 16:51:16 kernel: scsi 0:0:0:1: Failed to bind enclosure -19
Dec 16 16:51:16 kernel: sd 0:0:0:0: [sda] No Caching mode page found
Dec 16 16:51:16 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Dec 16 16:51:19 fingerprint-polkit-agent[1349]: Could not register listener "/fingerprintgui/PolicyKit1/AuthenticationAgent". Aborting.
Dec 16 22:37:54 kernel: ntfs3: Unknown parameter 'windows_names'
Dec 16 22:38:29 kernel: ntfs3: Unknown parameter 'windows_names'
Dec 16 22:39:16 kernel: ntfs3: Unknown parameter 'windows_names'
Dec 16 23:32:59 dolphin[22877]: inotify_add_watch(/home/altuser) failed: (Permission denied)
Dec 16 23:34:23 dolphin[22877]: inotify_add_watch(/lost+found) failed: (Permission denied)
Dec 17 00:01:09 kernel: ses 0:0:0:1: Wrong diagnostic page; asked for 1 got 8
Dec 17 00:01:09 kernel: ses 0:0:0:1: Failed to get diagnostic page 0x1
Dec 17 00:01:09 kernel: ses 0:0:0:1: Failed to bind enclosure -19
Dec 17 00:01:09 kernel: sd 0:0:0:0: [sda] No Caching mode page found
Dec 17 00:01:09 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Dec 17 00:01:11 kernel: ntfs3: Unknown parameter 'windows_names'
Dec 17 09:01:07 systemd-coredump[57162]: Process 1297 (plasmashell) of user 1000 dumped core.
Found module linux-vdso.so.1 with build-id: fc0932250ec82a533fb89adf1ab0c5e4209ea233
Found module libcanberra-pulse.so with build-id: 400935cdf7789421d57f39ccd113eec132edfddc
Found module libgvfscommon.so with build-id: 90d1858292300e4e1ee3fbe84ab06079af840ec6
Found module libgvfsdbus.so with build-id: dcb9d652f2e5c65154517fe6934215ec6bd1c29c
Found module libqnmbearer.so with build-id: 15daf5dc2f7fa2d307de33e024a9fc8a10703423
Found module libqgenericbearer.so with build-id: 9729f696c8143bba233600621d6b8dd5c4a3876e
Found module libqconnmanbearer.so with build-id: 1b3841f6bb95441084391197a49052fc17cee3d4
Found module libnss_mymachines.so.2 with build-id: 24b44e3e03891e05120e170caf6224a9b0eda607
Found module libQt5QuickWidgets.so.5 with build-id: 40ef5bd18aebd12c92e079995c988e63d5225f4b
Found module libkactivitiessettingsplugin.so with build-id: 18391fd287908a3e4584bce2244974ec0e463d17
Found module libkactivitiesextensionplugin.so with build-id: a2fa1110bb0a93ee712fce405d9bbe8e86d41dbf
Found module libKF5NotifyConfig.so.5 with build-id: 7563c9112b20154283c8b74423818374b283d73e
Found module plasma_engine_notifications.so with build-id: f6734a21f35adb0d015bad5bfe44de76be7a9145
Found module KF5IdleTimeXcbPlugin0.so with build-id: 2401509a6cad3ed8ba465434d50a398f5dd95008
Found module libbluetoothplugin.so with build-id: e264bdb6a0b41e1677bedba4127fbd917d75d282
Found module libKF5BluezQt.so.6 with build-id: 039e82f2f89eecac336b4750cbec753b5be497f3
Found module libbluezqtextensionplugin.so with build-id: 5302765d961d5b86139e211018925260ac8ba2ca
Found module libchartscontrolsplugin.so with build-id: 8d51ad1b71ae578eaa15e258e8c4b30eff6020c0
Found module libplc4.so with build-id: e3d338de1e8d5ea2f98a87af9157b17f92278d83
Found module libplds4.so with build-id: a2dcd5d4a1d3dccbf591e36bcc8d84162751c0a8
Found module libnssutil3.so with build-id: 574aa171a088dc2392004b50b916c15d3b8095b8
Found module libnspr4.so with build-id: d737bfb932206eb128a493cc70cedd63714e814f
Found module libnss3.so with build-id: c3931ab467a56418fbbd73909a8d08cf5b5e99b6
Found module libsmime3.so with build-id: b89bb01939cae673024ba94c850bc89c947b8eb8
Found module libnm.so.0 with build-id: a0bc1368f9ddf4d8b4a6ccaee7fddd0f0f91fe2f
Found module libKF5Wallet.so.5 with build-id: 05ae577403d4e2084f2ccd8afa96dc564ce2ec15
Found module libplasmanm_editor.so with build-id: 286869f5bf614e980fd3a2226bdd9867ddb06b5c
Found module libKF5NetworkManagerQt.so.6 with build-id: 022dc619e564a9592b214570375c28552a334494
Found module libKF5ModemManagerQt.so.6 with build-id: f6ed4ff4ce5b6cf73f55ada3b87c57d6037517f7
Found module libplasmanm_internal.so with build-id: 71be8edfd725319417f772471b5e03b5d4bbaf20
Found module libplasmanm_qmlplugins.so with build-id: a653ebde9974ae94034bb144b503e4b71df71577
Found module libKF5IdleTime.so.5 with build-id: 8b62ba38a7fc4f94a8ee536dd7d2938e3bcefd78
Found module plasma_engine_powermanagement.so with build-id: ab84568258052ccf949ef00c4e3ef6912b902534
Found module libnightcolorcontrolplugin.so with build-id: e6f7783cf8a86f427394c918c3e309441bf4aa27
Found module libKF5SonnetCore.so.5 with build-id: 91ae70f6cfa87958fe331c03e43b3ab17cf67534
Found module libKF5SonnetUi.so.5 with build-id: 4eb744e6bf6a6960ebce71d1a570c5f02426409b
Found module libKF5TextWidgets.so.5 with build-id: ee154f671cf68ac5b6102621f4d914f44a9b8b1e
Found module plasma_engine_clipboard.so with build-id: 22d3d0cf13ee14398212d99679245b3cf757524f
Found module libZXing.so.1 with build-id: 1784157cbf3a53d06b94a9edde95cd9bb9b460a3
Found module libdmtx.so.0 with build-id: e82ca33e4f00507ed9886e4e182385bda8f33add
Found module libqrencode.so.4 with build-id: abf3bf609471dbc409c77b0406677af374595acd
Found module libKF5Prison.so.5 with build-id: a250c8c1dd6a5a03043729c0a58c03896c9ddfa8
Found module libprisonquickplugin.so with build-id: 09f7b3cae899aebfca7be3634ab4a33d64f70b71
Found module libqmlsettingsplugin.so with build-id: 075a0a17af0ffd280f1856f5342d92e4efe51df0
Found module libqmlfolderlistmodelplugin.so with build-id: 6cf34fc90c5f6c89708491b099db8acc0e8f81ce
Found module libdialogsprivateplugin.so with build-id: 922c2a0e3a1b6fe564bbb9bbd940474a57c11886
Found module libqca-qt5.so.2 with build-id: 86e480fbdffa835c6718c9c07e6ad636c746408f
Found module libkdeconnectcore.so.21 with build-id: 6f1558ec303a944d147a19395daac688a0dd8fef
Found module libkdeconnectinterfaces.so.21 with build-id: f0d902c52d1f0851e9d3520525880af795424670
Found module libkdeconnectdeclarativeplugin.so with build-id: c56734221f721ec5504ea61f1792736b02afac73
Found module libQuickCharts.so with build-id: 7a573bfa2f8217a324dd8b816c6686f1608fa1e7
Found module libnotificationmanagerplugin.so with build-id: ccb301631b07ef9b5214bfe1e0c57210dc3f418a
Found module libkcoreaddonsplugin.so with build-id: 11d1175c769a58abafd367c615afffa5abf27ccc
Found module plasma_engine_devicenotifications.so with build-id: 10a3d2c8f1aae01279996b698f9fb0d22c9193c3
Found module plasma_engine_soliddevice.so with build-id: b4f8fb9244cb7e40db092a26c8bfdf144e20fcb0
Found module plasma_engine_hotplug.so with build-id: 671f5c32116b2edb441c38a641f59f7fba11bdeb
Found module libkeyboardlayoutplugin.so with build-id: c11097f836efee429528047b287564eb81c8c171
Found module libpagerplugin.so with build-id: ed2aa5406f02e7f955dcde01f0ef416416434946
Found module libsqlite3.so.0 with build-id: 6514739218fd9adab53e2e53a63a7364f9e544b3
Found module libqsqlite.so with build-id: d0626c7b6c8b682121bea1eeee9baa3555d640de
Found module libpsl.so.5 with build-id: 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Found module libssh2.so.1 with build-id: a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Found module libnghttp2.so.14 with build-id: eca975f5266a67fc4895065727647e98ff99a128
Found module libstemmer.so.0 with build-id: aa44a40dfb223020ed8e49cd2d28fc3887128463
Found module libyaml-0.so.2 with build-id: 94fd2b16e4c311e4c8b041061dfdb9ca8f508e29
Found module libxmlb.so.2 with build-id: 02c3e8647a872e297806a4df98267b1150235ce7
Found module libcurl.so.4 with build-id: 209b680538eb5f3793e41677b991488fb83a4ae6
Found module libappstream.so.4 with build-id: 6f3271913cc4e9e81b9ee3ec94ddde6d046f382d
Found module libKF5ThreadWeaver.so.5 with build-id: d043058ab3602d1703662d09140870f1da44891c
Found module libKF5PeopleBackend.so.5 with build-id: 6060a678185e4dae06eb6637e2f84822a47a23db
Found module libKF5People.so.5 with build-id: d2892f63e4f1d49f7c244fb07af4ed3fc9eae658
Found module libAppStreamQt.so.2 with build-id: 21bb5bbd874ea15471790f780bb192ca46a13dca
Found module libKF5Runner.so.5 with build-id: 6d789e4710a3c1deddf4e4a618572c7aa110fdec
Found module libKF5PeopleWidgets.so.5 with build-id: cbca9099865ca214ecc9c8141207b4abcf916042
Found module libkickerplugin.so with build-id: f02e9e795461735e30d03388106a54bae72b66f8
Found module libopus.so.0 with build-id: 649d3ddab8764d7caf73648004a35cb13e23a5e1
Found module libFLAC.so.8 with build-id: e568dc3d434723c72d6d302eb0b2559f27e91faa
Found module libvorbisenc.so.2 with build-id: 28ed815b8b1d322e6bf2bfdce4b0af2789b74335
Found module libasyncns.so.0 with build-id: 6acff139d56b5139ce5eb50a66c62b215e1d332d
Found module libsndfile.so.1 with build-id: 72d5531e74ed3e9afe49e95e449c40cb8984a258
Found module libgmodule-2.0.so.0 with build-id: 34cabbd12d9baf397a0255f174e4c96165bc329b
Found module libpulsecommon-15.0.so with build-id: a2e110b7a0b3bb46e42515afd55a61d78185835b
Found module libgobject-2.0.so.0 with build-id: 3e451709a0a5772b9550d3a4c28dcb37a87028fa
Found module libgio-2.0.so.0 with build-id: b3348994e4d526d182becc32821aa3dbe9797149
Found module libpulse.so.0 with build-id: 10bd0ce0cfbb9405cee189faa1830cf34cab61a8
Found module libpulse-mainloop-glib.so.0 with build-id: d9dc4a43a3739575dc1d789cc602d4e3a066979f
Found module libplasma-volume-declarative.so with build-id: ebbd69c20a1d4b78dc7ae16e37a60323207ed96a
Found module plasma_engine_mpris2.so with build-id: f057e8b95c2a6437582ce64f562ba63057bacde1
Found module libKF5Screen.so.7 with build-id: 2cc0ca3b8d4d9311032f17fcac803a2f858ffc5d
Found module libKSysGuardFormatter.so.1 with build-id: 2047633c133c2942231f55cb8d721ce19669820b
Found module libnotificationmanager.so.1 with build-id: 304ea1c646d1ac7b2e28a80d522bc3b5abe88eea
Found module libprocesscore.so.9 with build-id: a4223a7ab7ff52be1b79ebf3f5e0da65887c05f0
Found module libKF5ActivitiesStats.so.1 with build-id: ab75419da41463ef06abe0d7c47a8c9640bec237
Found module libtaskmanagerplugin.so with build-id: aa1908041658f5da3e5e3884a726176aef1752c8
Found module plasma_engine_time.so with build-id: 6b1b0c1856a930b2b16fad8442549ec97c1b34c8
Found module libmodelsplugin.so with build-id: 883605c3d4382cab8313f866adb7515d4e7a0637
Found module libKF5CalendarEvents.so.5 with build-id: eed425dc06c5e09ff2d57a59cb01c81f6bc8d7a7
Found module libcalendarplugin.so with build-id: c933d8be4ea85ad6cad3e63c1fef5adeb9000bec
Found module libdigitalclockplugin.so with build-id: ee3885596910c4e833c1c612d5a070df8202604d
Found module libspa-journal.so with build-id: b326235d0d3cdf7960d81c85c255ceb1a7e9f536
Found module libspa-support.so with build-id: 1eb6638aeb61fb72f244ef0cc3442e2aa22998f9
Found module libpipewire-0.3.so.0 with build-id: 2ef062f025e19926ef385bda58e4174130126737
Found module libtaskmanagerplugin.so with build-id: ba9306913c08b8b371ab660c796cf631aec575ea
Found module libkconfigplugin.so with build-id: 5af40cd8a0f81cd077195eab4aec906584373da0
Found module libcontainmentlayoutmanagerplugin.so with build-id: 1d65a07d35135335bab48680eddb779e76c6c5e6
Found module libfolderplugin.so with build-id: af0b72b900c70f080ef9ca3c70cab86e1a58c638
Found module libdesktopplugin.so with build-id: 9ae088729633fcff60401ded25ce8afe51674797
Found module wallpaper_images.so with build-id: 505511ad915c1d851321c1d58cadf98a0be28eb3
Found module libqtgraphicaleffectsprivate.so with build-id: 190dc8b89a36b3687646b8390489e7cce3a9b0c2
Found module libplasma_wallpaper_imageplugin.so with build-id: cd41887c655e67210f6cfa64ec0d4fffa7644892
Found module libqtgraphicaleffectsplugin.so with build-id: 78832273d88e4fd39919012344561ff0f995e074
Found module plasma_wallpaper.so with build-id: 6741371b33dfeae26b75cf47839108bb29c90492
Found module libepoxy.so.0 with build-id: b6357fc6b748c512f90339433d74502b9d0621dc
Found module libkquickcontrolsaddonsplugin.so with build-id: 19114e48df37ffe06b78019e0127c0f30162a550
Found module org.kde.desktop.so with build-id: c3a4cfa62d56b9e8fb9a14a9179f170b06625120
Found module libqqc2desktopstyleplugin.so with build-id: 636c76294a3627542cba45b8e34a151c1cd2128a
Found module libKF5Kirigami2.so.5 with build-id: 78a340d8f60b678375a04ff1d60e3e662ca69466
Found module libkirigamiplugin.so with build-id: 28403f37437c8da020e6059cd3fdc7409c9c1e12
Found module libqtquicktemplates2plugin.so with build-id: 9ff7d478c548702da9e6150c5b1750a9a4befca0
Found module libwidgetsplugin.so with build-id: 718cd75e832143e1175dcbfd0dd812e0c71c2897
Found module libnotesplugin.so with build-id: a20e5037ad7692f939100ed272cc577c11413239
Found module libplasmaextracomponentsplugin.so with build-id: 0ae936674372720453bf6bef687d86c134c0202e
Found module libdraganddropplugin.so with build-id: 7851779ab6ab25d53fc0dd0ebb4f721479a3643e
Found module libqmlplugin.so with build-id: 0565bbf9a51dcebc60829fc8d13fa55a540674c0
Found module libdialogplugin.so with build-id: fea6727d47ac086b9a6da7605116df7bae19f12e
Found module libwindowplugin.so with build-id: f0fba2a0c0f25ce393f40ebdf5339a0c0168992c
Found module libqquicklayoutsplugin.so with build-id: ca879841890b95294417fc1d5efd4c0da7d36220
Found module libqtquickcontrols2plugin.so with build-id: fbfe3e0e6604f38746b14e768f6c8290c5eeb384
Found module libwebp.so.7 with build-id: 87e81472aa7ff3ed1061cfc13d6960dbe00c35ab
Found module libwebpdemux.so.2 with build-id: b7d359c460bcb828b2ab4f34adfa8673af8a657b
Found module libwebpmux.so.3 with build-id: 4e17ff5fa40f00cda51d08d9edd48d442d3044e2
Found module libqwebp.so with build-id: 0aa3bb06c8b9370b0f026c56246f8153fdd5be41
Found module libqwbmp.so with build-id: 3ca3d2ff12c56b6e0f99311277f983e093f112cf
Found module libtiff.so.5 with build-id: e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Found module libqtiff.so with build-id: dda51dc7321967c46c7279ad1b5c142093cc71f8
Found module libqsvg.so with build-id: 329838a55e40bafc041f8f3c10c6f672eca51051
Found module libQt5Pdf.so.5 with build-id: 63fd654cf69ca1b1d195ddf59d1cae8ab647d08a
Found module libqpdf.so with build-id: 723f2a276b8172eb6aae3859ae78b58bc9be3e41
Found module liblcms2.so.2 with build-id: 92d69ecb51e7b4dee5a17936b6ac947a2a2042a5
Found module libmng.so.2 with build-id: 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
Found module libqmng.so with build-id: 13f764a4374591ed00ba81f145d8481ce9d58534
Found module libqjpeg.so with build-id: 650f4fbd34a38d2944c5129eca60199545ff51e5
Found module libjasper.so.4 with build-id: 062fa02a47172a8bf53b976a67eea42a61f37f0f
Found module libqjp2.so with build-id: 7ec36ae483b0b05dd01001ebcf311122418ab32f
Found module libqico.so with build-id: 64a41b997f0cad89c5f7079835cdb4fef89b8ef6
Found module libqicns.so with build-id: 05cd7e5790337687254a7ca1c23bfe17495068bd
Found module libqgif.so with build-id: d93f9967ef07903e9a07599bd0a581d270320ce6
Found module kimg_xcf.so with build-id: 8ab2b95cda64b84d19fa485edda03bc3b5a6eaa1
Found module kimg_tga.so with build-id: f81b8c7cdba495dbb64d37416f626140a52d0881
Found module kimg_rgb.so with build-id: 97e6e107998cd456627accb3cfa65d5345f6a88f
Found module kimg_ras.so with build-id: 400761fe5e52dc644b91bd714b7553ec9e135faa
Found module kimg_psd.so with build-id: e3ab324ac7879458e2f8174d1847c8bc9e96ea6b
Found module kimg_pic.so with build-id: 518320e60594839d40f9b0c79865c38fc544fffa
Found module kimg_pcx.so with build-id: 1c2bae65ba6e588cf3f636399e0412ba9fb8d91a
Found module kimg_ora.so with build-id: 977d866616142d07cc77f2768530a07b7c3eb35e
Found module kimg_kra.so with build-id: 30c4320ead4523f668c6242b821cac4f7ecfd37e
Found module libmvec.so.1 with build-id: 9aa05e22565568b778a97933527b3c64bdb8418b
Found module libx265.so.199 with build-id: 22130b9b0d2aa957b148b0fdeb27e3fd04f0fb58
Found module libde265.so.0 with build-id: d1ea0fbd83f7dd3dd2b0ce3d356006d305093d7a
Found module libheif.so.1 with build-id: 5edeb8cfd3e472f2ead12893189f124bfe2c10a9
Found module kimg_heif.so with build-id: 623ebed8507ba33b65131d9ba32066b8dce569cc
Found module kimg_hdr.so with build-id: e1a2e57a27c955969aecab7054ffcda7efba4b47
Found module libIlmThread-3_1.so.30 with build-id: 7a7f351560123573af9fc37c94f7089df23d56e4
Found module libIex-3_1.so.30 with build-id: 1c58fcdc2df582117ed00e5565fbd3c999b1817e
Found module libImath-3_1.so.29 with build-id: a2269e67bc2a5374323c805477c863fda4a17259
Found module libOpenEXR-3_1.so.30 with build-id: cf4ea6ee92a2067f6b7cd7d1676512ba9a3d94f5
Found module kimg_exr.so with build-id: 7a6696890cfa52706b92228525ffead19bfb6386
Found module kimg_eps.so with build-id: 47964576cc611f2e09c1b29383c4b512348e9675
Found module libjpeg.so.8 with build-id: 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
Found module libyuv.so with build-id: c7a5e1943921367b12460b618d38ce4afd1e6caf
Found module libaom.so.3 with build-id: 17c2d78932dffd790b290358a144c2b0ef5ddd17
Found module libSvtAv1Enc.so.0 with build-id: 3ebe5abcc88d5855fde0b2645844f80f03982902
Found module librav1e.so.0 with build-id: 2e9e70e2433e4d2955a870f2de730172729fbe4f
Found module libdav1d.so.5 with build-id: 82862181dbe48302fde94240f68e17fb6f9a03c7
Found module libavif.so.13 with build-id: cdc4233bc1ff2e9b419e9bf8aaf8b5a94cf0bd87
Found module kimg_avif.so with build-id: c927fbe031a461d96316a6f2d58182b4e83e5dec
Found module kimg_ani.so with build-id: d89a24de917cc2b2826a14ce25fe39089d6e7f91
Found module libKF5ItemModels.so.5 with build-id: b35828612072f492331e0cd6f51c935d530b85ff
Found module libtaskmanager.so.6 with build-id: fe9b4aa1c6038c8eed6f1e75600b6dca544fed73
Found module libactivityswitcherextensionplugin.so with build-id: 8d16856251c0ad5d2ed3f4924763baf7ba494d56
Found module libkwindowsystem.so with build-id: d117eb276885cbd03151faac3296fb3c193cdceb
Found module libplasmacomponentsplugin.so with build-id: 11a308f675be770a7adb54752c47534b614dea73
Found module libOpenGL.so.0 with build-id: 2d49f4adf705b15174dce3aa0177b3ba9198e9a2
Found module libEGL.so.1 with build-id: 473944aea0e3dbc5d595dee647702a3cdc0aed78
Found module libxcb-composite.so.0 with build-id: 94fff40466ef37eb5973997211aa68f9beb81d15
Found module libxcb-damage.so.0 with build-id: 14ba8de82d16adadd150a1d0ae3e8ac2119ccc8a
Found module libcorebindingsplugin.so with build-id: 12c0d70827dfdf9d6ba4b4fc870abd0bfc8799fa
Found module libqtquickcontrolsplugin.so with build-id: 3ef88990746f7eeea9679032d3ce8a04bc4c2ab5
Found module libQt5QmlWorkerScript.so.5 with build-id: ce9e840d5204cdd05fbcb5c5e197ff91198015be
Found module libqtquick2plugin.so with build-id: 29a8def585c0f6cb864fbb851dae2bb8594b4e36
Found module plasma_applet_notifications.so with build-id: 904078ed70d0bc9e50e2edf350d189c1b361c8cb
Found module org.kde.plasma.private.systemtray.so with build-id: 13e54351c6bb6b1d5fe1fff3a0d9facba7cf106a
Found module plasma_containmentactions_switchactivity.so with build-id: 0b9c71c24775739f64ff4c4804fcf562fb238ab9
Found module plasma_containmentactions_contextmenu.so with build-id: 2116f28ced7fdec58a3c2b83694451642557d7de
Found module plasma_containmentactions_paste.so with build-id: 54f0739034a1c01c00c308879609bc5e65d66c91
Found module org.kde.plasma.systemtray.so with build-id: 66d6ba79225be28ca21e704681356922eeab0afb
Found module org.kde.plasma.panelspacer.so with build-id: 3a79635e70f6c45956b8fccefda6b661f84935e5
Found module plasma_appletscript_declarative.so with build-id: 4aea290c511aadf5b6ebddf7b240a4f24e8fb0b0
Found module plasma_layouttemplate.so with build-id: c53f631eaafb78a83987f27224673c32e5c86231
Found module plasma_applet.so with build-id: f27b872115367b2852c500f3ae28b21bb572620b
Found module libxcb-res.so.0 with build-id: b825f66a75478fd00eeb4c57ecb0ac7792e00f5e
Found module KF5WindowSystemX11Plugin.so with build-id: 7aff4935a5964dc07d29efd673915749e8fe39ed
Found module plasma_shell.so with build-id: 7408f7be71e0a8097ff0a945dac4c3ccec5f3425
Found module plasma_lookandfeel.so with build-id: d14f3ef84f2ee1c90ef2a21c79519beb71ef5afc
Found module libnss_files.so.2 with build-id: 1a36dfc01d3a1010b2ee79766a24a8090a3266d5
Found module libxml2.so.2 with build-id: 6e67981c9b7528a3502824bf183423a0a02e1075
Found module libncursesw.so.6 with build-id: 859adb8b03a5655151b4da104bc4b326a0d4bc8c
Found module libedit.so.0 with build-id: 4b0babfcad161c2ad0af6e59e2493258db23a331
Found module libvulkan.so.1 with build-id: 3d98807d94dc94c0f97c89da76c24bba96a6c46c
Found module libdrm_nouveau.so.2 with build-id: ee16fa6a4d0bd08f5448cfc046ccb76b49aaa8a3
Found module libdrm_amdgpu.so.1 with build-id: 30d019987d514b23115b47d6b47c1e45c18fdbaf
Found module libelf.so.1 with build-id: 4300a0a24ac790c27ac0fe1fd5253729905ce708
Found module libdrm_radeon.so.1 with build-id: 5d1615e0467d0a34a5a82cbd4ebc84851e116307
Found module libsensors.so.5 with build-id: dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Found module libLLVM-13.so with build-id: 82982c299d46219d0eab8ee9cb8bb7365483453b
Found module radeonsi_dri.so with build-id: 485271131aae5a573f803418b6bbb1f58d034acb
Found module libxshmfence.so.1 with build-id: 8876d9ccf620858795724ca24b9e567585a77cec
Found module libxcb-present.so.0 with build-id: 68f5465258750e2397b1333b3ffc01ee33caa4e1
Found module libxcb-dri3.so.0 with build-id: 9407a2480e09dc5a1dd9d9a0652fa8d32b328c91
Found module libXxf86vm.so.1 with build-id: 01e8243d0c6c971fa9e743e6e53d606b1cb76f6e
Found module libxcb-dri2.so.0 with build-id: 2dd6e65129a809dab828a1d26215a3f7a363fcc8
Found module libdrm.so.2 with build-id: 457a1a1bd25f1d5541a10d3f16c5dc1440d77c7d
Found module libglapi.so.0 with build-id: 57828fb70af7c1f2aa70b096d748851a1fd39a9c
Found module libGLX_mesa.so.0 with build-id: bb74869736f072e29ec6a9709f74c0c77ec58233
Found module libxcb-glx.so.0 with build-id: 8ad115382ad874165523dc5b4488c99d73bbc3c4
Found module libqxcb-glx-integration.so with build-id: c50ee6e2389cbc752234a3e0153821ca5c141f7c
Found module libKF5Style.so.5 with build-id: 0ed8715b4deb2e96f710e2c65a950bb463b852c6
Found module libbreezecommon5.so.5 with build-id: 05c959663a9368be8fb4b25d3286e4ea80cf34ab
Found module breeze.so with build-id: 6f4b37e983a3ef2a327aaaf5942dd625af5a3555
Found module libcomposeplatforminputcontextplugin.so with build-id: c62f6a764ff2c7500d0ba10ad7838cc122cdb62d
Found module libQt5QuickTemplates2.so.5 with build-id: df09d36058107f30056e6c79eaa682e9d9e4f2c2
Found module libKF5Bookmarks.so.5 with build-id: 08739160e3ce71f2b79ec47898d0363ba166ec88
Found module libQt5QuickControls2.so.5 with build-id: a5978d717db15098905b6e50b7c83cd507df4c77
Found module libKF5KIOFileWidgets.so.5 with build-id: 73b5850ada6a2aa825c5d849079063b87d0d2f2f
Found module KDEPlasmaPlatformTheme.so with build-id: 3baa77b1afd2a615b29c4f42739493f0c1d582de
Found module libXfixes.so.3 with build-id: 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Found module libXrender.so.1 with build-id: 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Found module libXcursor.so.1 with build-id: eb6315bcd7526aaf51b0a1307efdc587cea0a152
Found module libuuid.so.1 with build-id: 832a09e0d9568cc6dbe699472218ea2f79dc0f34
Found module libxcb-util.so.1 with build-id: 4188ebc629b472b560849c5792a69c1803c3d1a4
Found module libxkbcommon-x11.so.0 with build-id: 821e1e75e92f3aaa96d19ed31fe98dbbd4d34627
Found module libICE.so.6 with build-id: af53458a64fe1e62a4d95606f7b03c210b2b098c
Found module libSM.so.6 with build-id: ac7b055fd3f16b4f29373285ab04ed52eebb632d
Found module libxcb-xinput.so.0 with build-id: 6403174c48f05f40cf7c168beb86f2886b9f09c1
Found module libxcb-xkb.so.1 with build-id: fce20d2101f3e5439923e9283c489c2cad4420c3
Found module libxcb-xinerama.so.0 with build-id: b328103ce7502d94fd3a4e2e8773978a9aa84adc
Found module libxcb-xfixes.so.0 with build-id: a6b197ace5b9b59f913f5969eb419a88d1194f47
Found module libxcb-sync.so.1 with build-id: dda14591103b01b1311906053bf1ca9e82ade35c
Found module libxcb-render.so.0 with build-id: a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Found module libxcb-render-util.so.0 with build-id: c64fb28ea20a320a9754273d9ea3af85f6f74b17
Found module libxcb-shm.so.0 with build-id: fb797f299a446f559a95afcc168227482cc800d1
Found module libxcb-image.so.0 with build-id: ee7f8577926fe7c1d6972036c2f8e6f727e43b1b
Found module libxcb-icccm.so.4 with build-id: 73f1e12d76af383aa969a60279ed5ed922045f47
Found module libX11-xcb.so.1 with build-id: 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Found module libQt5XcbQpa.so.5 with build-id: 1faa9fbbd961134122bbf8a60c0bf2b1e58bb216
Found module libqxcb.so with build-id: 840fc6ab5aef9669dfcbf5bd8a034f173cc8c0a2
Found module libbrotlicommon.so.1 with build-id: f68934f94312f770550ebc6c5acfd6359b098b07
Found module libexpat.so.1 with build-id: 8850138eae6d9d4d43c5c4b2ac48393bc4279037
Found module libbrotlidec.so.1 with build-id: f871e6f204ab8d48099915126ba01be989a8000f
Found module libgpg-error.so.0 with build-id: 3801187d42c4955bd93c605451430cdf1b164e63
Found module libgmp.so.10 with build-id: e58d34ab389d1b649c24195c2d145e3ff2e58290
Found module libhogweed.so.6 with build-id: 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Found module libnettle.so.8 with build-id: 9a878e513c02007598fcf1e2e286c2203f13536e
Found module libunistring.so.2 with build-id: 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Found module libidn2.so.0 with build-id: 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Found module libp11-kit.so.0 with build-id: f97c44b297b54185bbe3eb6ed6dab5d8967f1532
Found module libogg.so.0 with build-id: ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Found module libvorbis.so.0 with build-id: ad0a6c1af8f219b4e314090b6e8847223d424cbe
Found module libxkbcommon.so.0 with build-id: 1f1bc7527e57c886c3df5803068122e1971d4724
Found module libfontconfig.so.1 with build-id: 1103a641395c7d3b42e49b793d3a9ea927c77bf6
Found module libwayland-cursor.so.0 with build-id: ca6839778a1490fdd8e3d8aadc9604afa19ab8ea
Found module libacl.so.1 with build-id: 35319ea4baa70564deddffb113c0961002bc394c
Found module libresolv.so.2 with build-id: c915c72668282861a813f7ea3c0780f37b681dc0
Found module libkeyutils.so.1 with build-id: ac405ddd17be10ce538da3211415ee50c8f8df79
Found module libkrb5support.so.0 with build-id: adf65240a4d2aba772d7a0772b4d015469934113
Found module libcom_err.so.2 with build-id: eb61ef71c8b97846db759fb89a115405cff6dd30
Found module libk5crypto.so.3 with build-id: eb8220b8f36675aac769450be4cb6bb7f97ec38a
Found module libkrb5.so.3 with build-id: 72d26767c5cb1097db75a5f5bff88860233c902b
Found module libpcre.so.1 with build-id: 845483dd0acba86de9f0313102bebbaf3ce52767
Found module libicudata.so.70 with build-id: e1dcc2a88cfaafed882d09c90c668af0eed4efed
Found module libcap.so.2 with build-id: 7ab63cdf1c7435ae6910ccd518a92dc4f6a9b5b6
Found module liblz4.so.1 with build-id: e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Found module libgraphite2.so.3 with build-id: 47761dc11e553f519cde97ed9ee985be12ccdae2
Found module libfreetype.so.6 with build-id: 26c5f833068ff72660d1975cbc2074c3eb47fad8
Found module libGLX.so.0 with build-id: 0f40ceaa036edc65147e9559b94e0219472493fc
Found module libGLdispatch.so.0 with build-id: 195b34c1bb271f3b1162c897cfbcfb859e656b93
Found module libusbmuxd-2.0.so.6 with build-id: fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Found module libgcrypt.so.20 with build-id: db45f5d5e0f7af1e77324fea1885f974619ad268
Found module libtasn1.so.6 with build-id: ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Found module libgnutls.so.30 with build-id: 8c87466eacaec0041a370df713d0fd200358c94c
Found module libblkid.so.1 with build-id: f03a24e92c9852272bd0049b5bcb7ed6cf0e664f
Found module librt.so.1 with build-id: 75484da2d6f1515189eefa076e0a40328834cd16
Found module libXi.so.6 with build-id: 16603be937a02a7e61b0b0395d064be7efd86f49
Found module libXext.so.6 with build-id: d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Found module libltdl.so.7 with build-id: 64bc54a40a0b6e4209a2c712364b4ae653c3f5b2
Found module libtdb.so.1 with build-id: bec061530310665480ee91395b4eb0a937750a03
Found module libvorbisfile.so.3 with build-id: 0010b21da05e318b42e718d90738febf58028141
Found module libQt5WaylandClient.so.5 with build-id: c14a9317925fb7c8b54f7f558e0c82916311bdfe
Found module libKF5AuthCore.so.5 with build-id: 371c3caa7e0ebbe205bff247efc254cef7702a15
Found module libKF5Codecs.so.5 with build-id: b2538310c211c8cbd21a237f79146f7d873ae966
Found module liblzma.so.5 with build-id: 8b615460aa230708c5183f16bede67aa0437d95e
Found module libbz2.so.1.0 with build-id: 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Found module libKF5Completion.so.5 with build-id: 933266310c3ff666a937173ccb299510aa6449fc
Found module libKF5JobWidgets.so.5 with build-id: db7a844750e469a3f1e210ed5b1c3fbe9d7a561b
Found module libKF5KIOCore.so.5 with build-id: 5aa3e085344190dcc91e4d46e2da9dd4e5a9e477
Found module libcrypto.so.1.1 with build-id: 6d23f0a3f354825868d044684fad31d482cc9210
Found module libssl.so.1.1 with build-id: 959cd8f1dd43fc31aeb93caac4eda87c907ef18b
Found module libgssapi_krb5.so.2 with build-id: e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Found module libffi.so.8 with build-id: f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Found module ld-linux-x86-64.so.2 with build-id: 040cc3dd10461562f177df39e3be2f3704258c3c
Found module libglib-2.0.so.0 with build-id: d4aa102e545015a506c3ee06398676b70f65bcbc
Found module libzstd.so.1 with build-id: 4b10444c1560ebc574af4d5f488b7408b22d450e
Found module libpcre2-16.so.0 with build-id: 195fbccafbcff538ce13805ba687514fb614c5ed
Found module libdl.so.2 with build-id: 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Found module libicuuc.so.70 with build-id: 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Found module libicui18n.so.70 with build-id: 95af755fca990df26753a7d720b8e3ae24270e42
Found module libdouble-conversion.so.3 with build-id: 6a30e0c0fd0f44981fe07c57be207d763f88e830
Found module libsystemd.so.0 with build-id: 65e1ee509d2099c477c39e7af6a539f1a5c1072d
Found module libmd4c.so.0 with build-id: 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Found module libharfbuzz.so.0 with build-id: 5d9b408e95d3c98a95333fdd413b8b64a7757631
Found module libz.so.1 with build-id: 81bf6e728a6d6f5b105b0f8b25f6c614ce10452a
Found module libpng16.so.16 with build-id: 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Found module libGL.so.1 with build-id: 8b3028bab286029945569a0dfcf695f0f61d9c3b
Found module libdbus-1.so.3 with build-id: 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Found module libxcb-keysyms.so.1 with build-id: 333e5eb4075795f947c924a2085f17e2e2ae7147
Found module libgcc_s.so.1 with build-id: 7f8508bb914546ada778809b64b99d234337d835
Found module libpthread.so.0 with build-id: 07c8f95b4f3251d08550217ad8a1f31066229996
Found module libm.so.6 with build-id: 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Found module libQt5QmlModels.so.5 with build-id: bb287a9d391c98bf3393f095e115482bf1635d8e
Found module libKF5ItemViews.so.5 with build-id: 84c3e8bb9ecf21b0aa8820e068f7b0901909a925
Found module libKF5WidgetsAddons.so.5 with build-id: b2741e1222e3774014b87cd706b650df2e7cfc04
Found module libQt5PrintSupport.so.5 with build-id: b23f59d936e79737edac8c29c48a91eee1f20150
Found module libplist-2.0.so.3 with build-id: b4dd02ee2d5938fd2bfa34070014f4d30a21abd6
Found module libimobiledevice-1.0.so.6 with build-id: b7197d5ba7e40162e4d3f4eb92b4b589b8e5fe1e
Found module libmount.so.1 with build-id: ff9a1d99d35cf640d0bfdaba294854372672c29b
Found module libudev.so.1 with build-id: acbf653b3eb124c3c7bc2b41d628358c2b5bdaea
Found module libQt5Xml.so.5 with build-id: ec415d2e364d2b174ad5f9813ab2926098221a37
Found module libdbusmenu-qt5.so.2 with build-id: 346cd54093968d3de9e61cc329e9512d248dce18
Found module libXtst.so.6 with build-id: 96411faea62997274e362f263e65082e601a787b
Found module libX11.so.6 with build-id: e9192497aa39fab51358826d1a1b5fb77edc5081
Found module libQt5TextToSpeech.so.5 with build-id: 99b56b543380180d6f5c8c984f01d80487672cff
Found module libcanberra.so.0 with build-id: 379ed64f9d1408a83806cd5d94dc5bb903765615
Found module libKF5GuiAddons.so.5 with build-id: af80033ed20c6c909932a298fd4ac97529a26e67
Found module libKF5ConfigWidgets.so.5 with build-id: 81da74cea4888b2d614a36ea6081414302039142
Found module libKF5Archive.so.5 with build-id: 6869e314aa925521dd543919c3e228167b75b718
Found module libQt5Svg.so.5 with build-id: 891060da424e72ee00134ea2d255e93ab598fe06
Found module libKF5KIOGui.so.5 with build-id: cfdce7550ac314a72592a90385f3dec4684144f7
Found module libKF5KIOWidgets.so.5 with build-id: 4507167915e3016cc5502c013457acd9796f3dd4
Found module libQt5Sql.so.5 with build-id: db7dd541b764efbbfc989c706877e46c8ac97423
Found module libXdmcp.so.6 with build-id: 8ca0792d23c8b8b4c0864297512349292bea5955
Found module libQt5Network.so.5 with build-id: dc30f8fde38dd374353bbcd6913def6b85f89f97
Found module libXau.so.6 with build-id: 1c67764663e07bec24d8951e5fd93f4d165979ff
Found module libwayland-client.so.0 with build-id: d274361e7aa57c9b63504a039e063322450cbb9c
Found module libKF5IconThemes.so.5 with build-id: c90dadb2e3326ebb2509d3195b14bac1c5ed6c24
Found module libxcb-shape.so.0 with build-id: f1b3376c4534fab0469feb1cd19f022ff98df533
Found module libc.so.6 with build-id: 4b406737057708c0e4c642345a703c47a61c73dc
Found module libstdc++.so.6 with build-id: 8ab0e57054dd1dcba681f217016afc6a4e639783
Found module libQt5Core.so.5 with build-id: 87a27d6e8cecefe08870b44f38ab8fa082e49dff
Found module libQt5Gui.so.5 with build-id: e905f297ea8ee46b63c26adc2f9de3e4ef02e17a
Found module libQt5X11Extras.so.5 with build-id: e41614d2e35852f913bf00633d635cfbf5a90dce
Found module libQt5DBus.so.5 with build-id: eec55e409fa44577508e4ea9512ecaa9bd668b65
Found module libKF5ConfigCore.so.5 with build-id: 32ef3a065088f03759c1cd16354052b7410c6641
Found module libKF5CoreAddons.so.5 with build-id: 3a0313b69c1d014878c4573783cefa145f2c1912
Found module libKF5I18n.so.5 with build-id: d1468fda0ad2324329c5f9121b768d7bab671601
Found module libQt5Widgets.so.5 with build-id: 7055bce61834a27af80ad5e536750b0977893ba0
Found module libKF5WindowSystem.so.5 with build-id: 4465afe9665b61e245c8dcffff5587a9d11c535b
Found module libKF5ConfigGui.so.5 with build-id: 8fd1d1fd2356943cb1749239824688aebac8c308
Found module libQt5Qml.so.5 with build-id: 9e41eb2dc21904fbdbed2aab03156a996251265a
Found module libKF5DBusAddons.so.5 with build-id: c9bc9df340b4d9506b9ddb1769d0da6b62d2c298
Found module libKF5Service.so.5 with build-id: 7bfb428df3b56c590ab0a9e5dde5c60d28799df5
Found module libQt5Quick.so.5 with build-id: 8f6ab7ac0916394ecb43278f683f6b25b47b4e26
Found module libKF5GlobalAccel.so.5 with build-id: 265987e75a045e1eb0c354cdb673a91ce8a3c290
Found module libKF5XmlGui.so.5 with build-id: 33c4be53cd9397cfef349b726e1bedc4b8156189
Found module libKF5Crash.so.5 with build-id: e971aff373671fdcdddc701a87d8abc24a64f6eb
Found module libKF5Solid.so.5 with build-id: 69636b1588f5fad85cf65a193611615a74ae4e84
Found module libKF5Package.so.5 with build-id: 1480e9a7eb6f759ba1e5eb5c46adbd534d7d94e8
Found module libKF5Declarative.so.5 with build-id: a25c4aaf57592b54101b7312f54fc7f3b0fac21f
Found module libKF5Notifications.so.5 with build-id: e56492935d5ab822db6f9d0a40038da0798552d8
Found module libKF5Plasma.so.5 with build-id: 82b95cef591cbe344a44c5e0e83258ed5b768954
Found module libxcb-randr.so.0 with build-id: b6c1c7d4b28863b55ade251813db7f246b7ffe8b
Found module libxcb.so.1 with build-id: 0d1ef11740a5daad2ee331e812a51aa6574af222
Found module libKUserFeedbackCore.so.1 with build-id: 495f85a1827b1732a0dfa93532a4101dafc11ac1
Found module libkworkspace5.so.5 with build-id: 055050df1cd3c06586e858466a5ea1e100aa5803
Found module libKF5WaylandClient.so.5 with build-id: e507c814b8f28253281208693c91d5ddba8a5d80
Found module libKF5QuickAddons.so.5 with build-id: eb6a32208ba1ba05b0f1ad7dd2e3363c461b2b8f
Found module libKF5Activities.so.5 with build-id: 0a0c93cf38bf6cf3afb02e718ac69e4e2c7205b5
Found module libKF5PlasmaQuick.so.5 with build-id: 9e994f17be1ef520670ff187fa40f709c8a02126
Found module plasmashell with build-id: 7c30ad40616cd378b65c3c5c018b27b097cea030
Stack trace of thread 1297:
#0 0x00007f2197c32d22 raise (libc.so.6 + 0x3cd22)
#1 0x00007f219a120064 _ZN6KCrash19defaultCrashHandlerEi (libKF5Crash.so.5 + 0x5064)
#2 0x00007f2197c32da0 __restore_rt (libc.so.6 + 0x3cda0)
#3 0x00007f219982f8fe n/a (libQt5Qml.so.5 + 0x2c68fe)
#4 0x00007f21997d47d7 n/a (libQt5Qml.so.5 + 0x26b7d7)
#5 0x00007f21997d60ab _ZN17QQmlVMEMetaObject8metaCallEP7QObjectN11QMetaObject4CallEiPPv (libQt5Qml.so.5 + 0x26d0ab)
#6 0x00007f2199707e55 n/a (libQt5Qml.so.5 + 0x19ee55)
#7 0x00007f21322997f3 n/a (n/a + 0x0)
#8 0x00007f219972ccdd n/a (libQt5Qml.so.5 + 0x1c3cdd)
#9 0x00007f21996bfed9 n/a (libQt5Qml.so.5 + 0x156ed9)
#10 0x00007f2199869612 n/a (libQt5Qml.so.5 + 0x300612)
#11 0x00007f2199869aba n/a (libQt5Qml.so.5 + 0x300aba)
#12 0x00007f21982cb0a7 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2f10a7)
#13 0x00007f2198f8dff6 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x15aff6)
#14 0x00007f219829d20a _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2c320a)
#15 0x00007f21982a03b9 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x2c63b9)
#16 0x00007f21982f7518 n/a (libQt5Core.so.5 + 0x31d518)
#17 0x00007f219655e4dc g_main_context_dispatch (libglib-2.0.so.0 + 0x544dc)
#18 0x00007f21965b2799 n/a (libglib-2.0.so.0 + 0xa8799)
#19 0x00007f219655bbc1 g_main_context_iteration (libglib-2.0.so.0 + 0x51bc1)
#20 0x00007f21982f6b2a _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x31cb2a)
#21 0x00007f219829babb _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2c1abb)
#22 0x00007f21982a42a8 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2ca2a8)
#23 0x000055d498751132 n/a (plasmashell + 0x1e132)
#24 0x00007f2197c1db25 __libc_start_main (libc.so.6 + 0x27b25)
#25 0x000055d49875126e n/a (plasmashell + 0x1e26e)
Stack trace of thread 22330:
#0 0x00007f21970438ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f219703d270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007f218a6c088c n/a (radeonsi_dri.so + 0x1c888c)
#3 0x00007f218a6b9f68 n/a (radeonsi_dri.so + 0x1c1f68)
#4 0x00007f2197037259 start_thread (libpthread.so.0 + 0x9259)
#5 0x00007f2197cf45e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 7986:
Stack trace of thread 22278:
Stack trace of thread 1569:
Stack trace of thread 7216:
#2 0x00007f21980afa1c _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xd5a1c)
#3 0x00007f2199cb2017 n/a (libQt5Quick.so.5 + 0x204017)
#4 0x00007f2199cb456b n/a (libQt5Quick.so.5 + 0x20656b)
#5 0x00007f21980a940b n/a (libQt5Core.so.5 + 0xcf40b)
#6 0x00007f2197037259 start_thread (libpthread.so.0 + 0x9259)
#7 0x00007f2197cf45e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 1566:
#0 0x00007f2197ce9b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f21965b2729 n/a (libglib-2.0.so.0 + 0xa8729)
#2 0x00007f219655bbc1 g_main_context_iteration (libglib-2.0.so.0 + 0x51bc1)
#3 0x00007f21982f6b2a _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x31cb2a)
#4 0x00007f219829babb _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2c1abb)
#5 0x00007f21980a81b6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xce1b6)
#6 0x00007f2199bf9e9b n/a (libQt5Quick.so.5 + 0x14be9b)
#7 0x00007f21980a940b n/a (libQt5Core.so.5 + 0xcf40b)
#8 0x00007f2197037259 start_thread (libpthread.so.0 + 0x9259)
#9 0x00007f2197cf45e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 22358:
#2 0x00007f219655da63 g_main_loop_run (libglib-2.0.so.0 + 0x53a63)
#3 0x00007f212bd48268 n/a (libgio-2.0.so.0 + 0x103268)
#4 0x00007f219658cce1 n/a (libglib-2.0.so.0 + 0x82ce1)
#5 0x00007f2197037259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f2197cf45e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 7215:
Stack trace of thread 31579:
Stack trace of thread 1364:
#1 0x00007f219a38f63b n/a (libxcb.so.1 + 0xc63b)
#2 0x00007f219a39137b xcb_wait_for_event (libxcb.so.1 + 0xe37b)
#3 0x00007f2192fcb768 n/a (libQt5XcbQpa.so.5 + 0x62768)
#4 0x00007f21980a940b n/a (libQt5Core.so.5 + 0xcf40b)
Stack trace of thread 15578:
#6 0x00007f21980a940b n/a (libQt5Core.so.5 + 0xcf40b)
#7 0x00007f2197037259 start_thread (libpthread.so.0 + 0x9259)
#8 0x00007f2197cf45e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 1423:
Stack trace of thread 1428:
Stack trace of thread 1422:
Stack trace of thread 1424:
Stack trace of thread 1492:
#6 0x00007f2199892509 n/a (libQt5Qml.so.5 + 0x329509)
Stack trace of thread 1643:
Stack trace of thread 22331:
Stack trace of thread 1421:
Stack trace of thread 1425:
Stack trace of thread 1427:
Stack trace of thread 1426:
Stack trace of thread 31578:
Stack trace of thread 1431:
Stack trace of thread 1384:
#6 0x00007f2198c41b0c n/a (libQt5DBus.so.5 + 0x15b0c)
Stack trace of thread 1617:
Stack trace of thread 7987:
Stack trace of thread 1570:
Stack trace of thread 1642:
Stack trace of thread 22357:
#3 0x00007f219655bc12 n/a (libglib-2.0.so.0 + 0x51c12)
Stack trace of thread 1579:
#0 0x00007f2197cec323 pselect (libc.so.6 + 0xf6323)
#1 0x00007f2195947524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
#2 0x00007f21959488a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
#3 0x00007f2197037259 start_thread (libpthread.so.0 + 0x9259)
#4 0x00007f2197cf45e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 1618:
Stack trace of thread 1419:
Stack trace of thread 31577:
#1 0x00007f212be38ae4 n/a (libpulse.so.0 + 0x33ae4)
#2 0x00007f212be224b9 pa_mainloop_poll (libpulse.so.0 + 0x1d4b9)
#3 0x00007f212be2c709 pa_mainloop_iterate (libpulse.so.0 + 0x27709)
#4 0x00007f212be2c7c1 pa_mainloop_run (libpulse.so.0 + 0x277c1)
#5 0x00007f212be3cc9e n/a (libpulse.so.0 + 0x37c9e)
#6 0x00007f212bbbe403 n/a (libpulsecommon-15.0.so + 0x5c403)
Stack trace of thread 1429:
Stack trace of thread 1430:
>░░ Subject: Process 1297 (plasmashell) dumped core
░░ Documentation: man:core(5)
░░ Process 1297 (plasmashell) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Dec 17 12:48:51 kernel: ses 0:0:0:1: Wrong diagnostic page; asked for 1 got 8
Dec 17 12:48:51 kernel: ses 0:0:0:1: Failed to get diagnostic page 0x1
Dec 17 12:48:51 kernel: ses 0:0:0:1: Failed to bind enclosure -19
Dec 17 12:48:52 kernel: sd 0:0:0:0: [sda] No Caching mode page found
Dec 17 12:48:52 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Dec 17 12:48:54 kernel: ntfs3: Unknown parameter 'windows_names'
Dec 17 20:23:34 kernel: ses 0:0:0:1: Wrong diagnostic page; asked for 1 got 8
Dec 17 20:23:34 kernel: ses 0:0:0:1: Failed to get diagnostic page 0x1
Dec 17 20:23:34 kernel: ses 0:0:0:1: Failed to bind enclosure -19
Dec 17 20:23:34 kernel: sd 0:0:0:0: [sda] No Caching mode page found
Dec 17 20:23:34 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Dec 17 20:24:26 kernel: ntfs3: Unknown parameter 'windows_names'
Dec 17 21:29:20 kernel: amdgpu 0000:05:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
Dec 17 21:29:20 kernel: ACPI Error: Aborting method \_SB.A011 due to previous error (AE_AML_LOOP_TIMEOUT) (20210730/psparse-529)
Dec 17 21:29:20 kernel: ACPI Error: Aborting method \_SB.A025 due to previous error (AE_AML_LOOP_TIMEOUT) (20210730/psparse-529)
Dec 17 21:29:20 kernel: ACPI Error: Aborting method \_SB.ALIB due to previous error (AE_AML_LOOP_TIMEOUT) (20210730/psparse-529)
Dec 17 21:29:20 kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.VPC0.MCBT due to previous error (AE_AML_LOOP_TIMEOUT) (20210730/psparse-529)
Dec 17 21:29:20 kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.VPC0.DYTC due to previous error (AE_AML_LOOP_TIMEOUT) (20210730/psparse-529)
Dec 17 21:29:20 kernel: amdgpu 0000:05:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
Dec 17 21:29:20 kernel: amdgpu 0000:05:00.0: amdgpu: Failed to SetDriverDramAddr!
Dec 17 21:29:20 kernel: amdgpu 0000:05:00.0: amdgpu: Failed to setup smc hw!
Dec 17 21:29:20 kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <smu> failed -62
Dec 17 21:29:20 kernel: amdgpu 0000:05:00.0: amdgpu: amdgpu_device_ip_resume failed (-62).
Dec 17 21:29:20 kernel: PM: dpm_run_callback(): pci_pm_resume+0x0/0xe0 returns -62
Dec 17 21:29:20 kernel: amdgpu 0000:05:00.0: PM: failed to resume async: error -62
