System: Laptop running Manjaro KDE.
`inxi` output
Kernel: 5.16.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=e4a9d033-af86-4b2d-9348-790ea195522f rw quiet
udev.log_priority=3 pci=nocrs
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: G7 7588 v: N/A
Mobo: Dell model: 0FDMYT v: A00 serial: <superuser required> UEFI: Dell
v: 1.15.0 date: 11/13/2020
ID-1: BAT0 charge: 22.1 Wh (55.8%) condition: 39.6/56.0 Wh (70.7%)
volts: 14.9 min: 15.2 model: Samsung SDI DELL W7NKD7B type: Li-ion
serial: <filter> status: Discharging
RAM: total: 31.05 GiB used: 4.55 GiB (14.6%)
RAM Report:
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 809 high: 870 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 840 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 870 10: 800 11: 800 12: 800 bogomips: 52815
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: nvidia
v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c20 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0bda:5652 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.5
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Dell
driver: alx v: kernel port: 3000 bus-ID: 3c:00.0 chip-ID: 1969:e0a1
class-ID: 0200
IF: enp60s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 1.82 TiB used: 1.16 TiB (63.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR010 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: GPT
ID-1: / raw-size: 465.61 GiB size: 457.3 GiB (98.22%)
used: 345.8 GiB (75.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: e4a9d033-af86-4b2d-9348-790ea195522f
ID-2: /run/media/mark/DATA raw-size: 931.5 GiB size: 931.5 GiB (100.00%)
used: 839.9 GiB (90.2%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: DATA
uuid: 3E6C45656C451953
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
uuid: E3CE-4CB1
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 464.97 GiB fs: ntfs label: N/A
uuid: 0C6A95396A95210E
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 652 MiB fs: ntfs label: N/A
uuid: 9C00B3F500B3D50C
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-5:2 info: Realtek Integrated_Webcam_HD type: Video
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 25.0 C pch: 42.0 C mobo: N/A
Processes: 298 Uptime: 11m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1892 lib: 503
Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.12
Whenever I log in, while connected to an external display, the widgets/taskbar/wallpapers on the monitors are swapped (taskbar that is normall on the main display is on the secondary display, as are desktop widgets, and the wallpapers have swapped displays).
If I login while not connected to an external display, the same thing happens, but there’s not secondary monitor with my taskbar/widgets.
It originally happened when I connected a third display (which has not been an issue before).
