Unrecognised xattr prefix system.posix_acl_default
Unrecognised xattr prefix system.posix_acl_access
or that in the context:
❯ buildiso -p kde -f -b unstable -k linux519 -v
--> Profile: [kde]
==> Start building [kde]
==> Cleaning up ...
-> Deleting chroot [desktopfs] (x86_64) ...
==> Adding package '/var/lib/manjaro-tools/buildiso/kde/x86_64/mhwdfs/opt/mhwd/pkg/zfs-dkms-2.1.5-1-x86_64.pkg.tar.zst'
-> Computing checksums...
-> Creating 'desc' db entry...
-> Creating 'files' db entry...
==> Adding package '/var/lib/manjaro-tools/buildiso/kde/x86_64/mhwdfs/opt/mhwd/pkg/zfs-utils-2.1.5-1-x86_64.pkg.tar.zst'
==> Creating updated database file '/var/lib/manjaro-tools/buildiso/kde/x86_64/mhwdfs/opt/mhwd/pkg/mhwd.db.tar.gz'
--> Configuring mhwd db ...
-> Disabling Nvidia 390xx driver
-> Disabling Nvidia 390xx Bumblebee driver
-> Disabling Nvidia driver
-> Disabling Nvidia AMD Prime driver
-> Disabling Nvidia Intel Prime driver
-> Disabling Nvidia 470xx driver
-> Disabling Nvidia 470xx AMD Prime driver
-> Disabling Nvidia 470xx Intel Prime driver
-> Disabling rt3562sta driver
-> Disabling r8168 driver
--> overlayfs umount: [/var/lib/manjaro-tools/buildiso/kde/x86_64/mhwdfs]
--> umount overlayfs: [/var/lib/manjaro-tools/buildiso/kde/x86_64/mhwdfs]
-> Cleaning [mhwdfs]
==> Done [drivers repository] (mhwdfs)
==> Prepare [/iso/boot]
--> overlayfs mount: [/var/lib/manjaro-tools/buildiso/kde/x86_64/bootfs]
-> Copying initcpio ...
==> Starting build: 5.19.2-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [miso_shutdown]
-> Running build hook: [miso]
-> Running build hook: [miso_loop_mnt]
-> Running build hook: [miso_pxe_common]
==> WARNING: Possibly missing firmware for module: softing_cs
==> WARNING: Possibly missing firmware for module: bnx2x
==> WARNING: Possibly missing firmware for module: bna
==> WARNING: Possibly missing firmware for module: liquidio
==> WARNING: Possibly missing firmware for module: mlxsw_spectrum
==> WARNING: Possibly missing firmware for module: nfp
==> WARNING: Possibly missing firmware for module: qed
-> Running build hook: [miso_pxe_http]
-> Running build hook: [miso_pxe_nbd]
-> Running build hook: [miso_pxe_nfs]
-> Running build hook: [miso_kms]
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating xz-compressed initcpio image: /boot/initramfs.img
--> overlayfs umount: [/var/lib/manjaro-tools/buildiso/kde/x86_64/bootfs]
--> umount overlayfs: [/var/lib/manjaro-tools/buildiso/kde/x86_64/bootfs]
==> Done [/iso/boot]
==> Prepare [/iso/boot/grub]
-> Building core.img ...
-> Building bootx64.efi ...
-> Set menu_show_once=1 in '/var/lib/manjaro-tools/buildiso/kde/iso/boot/grub/grubenv'
-> Creating fat image of 4M ...
--> mount: [/var/lib/manjaro-tools/buildiso/kde/mnt/efiboot]
--> umount: [/var/lib/manjaro-tools/buildiso/kde/mnt/efiboot]
==> Done [/iso/boot/grub]
--> Time prepare_images: 7.40 minutes
==> Start [Build ISO]
-> Removing '/etc/pacman.d/gnupg' folder from /var/lib/manjaro-tools/buildiso/kde/x86_64/rootfs
==> Generating SquashFS image for /var/lib/manjaro-tools/buildiso/kde/x86_64/rootfs
-> Creating SquashFS image, this may take some time...
-> Creating md5sum ...
--> Time make_sfs: 12.08 minutes
==> Generating SquashFS image for /var/lib/manjaro-tools/buildiso/kde/x86_64/desktopfs
Perhaps those warnings could be missed in the output while images auto-created, but could add unexpected behavior during or after installation. Please review.
Thanks!
