Manjaro-Tools Maintenance list of packages (iso-profiles)
I’ve always used manjaro-tools (buildiso) but for some time now nothing wants to make it work why?
Image remove <<
Thanks for the suggestions
T+ = See you later
Please see this thread:
I’m guessing it has something to do with the URL it’s trying to use. I know matray also used it and that’s not working, since AFAIK the server for that URL no longer exists.
So try using/configuring it to use a different URL.
Please copy and paste text here, do not post screenshots of text. Please edit your post accordingly.
As referenced by @NGr you should edit the configuration found in
~/.config/manjaro-tools/manjaro-tools.conf
If you don’t have the file - copy from /etc/manjaro-tools
cp -r -i /etc/manjaro-tools ~/.config
First I apologize for my bad English already known by some here, everything comes from (google translate).
Thanks for the “tip”, as soon as I redo the installations of my 2 HDD’s that I thought of deleting after the old donkey, grateful :wink:
Excuse me as I answered above I messed up with archlinux and managed to erase my 2 HDD I am redoing the installations right now but I will remove the image in violation of the posting rules, again sorry @Yochanan
T+ = See you later
Show me, don’t tell me
Show Don’t Tell, Rush
Sorry i dont understand??
See Manjaro Tools (buildiso) broken
T+
I asked you to do something. Don’t tell me you’re going to do it, just do it. :wink:
Guys here is the output of
buildiso -f -p lxqt -b stable
Even if I leave it with manjaro.moson.eu or manjaro.moson.org the error persists
[pcmanjaro@pcmanjaro ~]$ buildiso -f -p lxqt -b stable
 --> Profile: [lxqt]
==> Start building [lxqt]
==> Cleaning up ...
  -> Deleting chroot [rootfs] (x86_64) ...
/usr/bin/btrfs
Delete subvolume (no-commit): '/var/lib/manjaro-tools/buildiso/lxqt/x86_64/rootfs'
  -> Deleting isoroot [iso] ...
 --> Loading Packages: [Packages-Root] ...
==> Prepare [Base installation] (rootfs)
Create subvolume '/var/lib/manjaro-tools/buildiso/lxqt/x86_64/rootfs'
 --> mirror: https://manjaro.moson.org//stable/$repo/$arch
==> Creating install root at /var/lib/manjaro-tools/buildiso/lxqt/x86_64/rootfs
  -> Installing packages to /var/lib/manjaro-tools/buildiso/lxqt/x86_64/rootfs
 core.db failed to download
error: failed retrieving file 'core.db' from manjaro.moson.org : Could not resolve host: manjaro.moson.org
warning: too many errors from manjaro.moson.org, skipping for the remainder of this transaction
error: failed to synchronize all databases (invalid url for server)
==> ERROR: Failed to install packages to new root
==> ERROR: Failed to install all packages
manjaro.moson.eu
[sudo] password for pcmanjaro:
 --> Profile: [lxqt]
==> Cleaning up ...
/usr/bin/btrfs
 --> mirror: https://manjaro.moson.eu/stable/$repo/$arch
error: failed retrieving file 'core.db' from manjaro.moson.eu : Could not resolve host: manjaro.moson.eu
warning: too many errors from manjaro.moson.eu, skipping for the remainder of this transaction
Thank’s
T+ = See you later
Neither of those mirrors appear to exist anymore. The thread I linked to had the answer, switch to
https://mirrors.manjaro.org/repo in your tools configuration
I read it now, but it’s for the documentation of those who may experience the problem, thank you very much @NGr Buildiso cant fetch packages from https://manjaro.moson.eu - #9 by linux-aarhus
And of course thank’s @linux-aarhus :wink:
T+ = See you later
The problem now is:
warning: sof-firmware-2.2.2-1 is up to date -- reinstalling
error: target not found: manjaro-documentation-en
warning: zlib-1:1.2.13-2 is up to date -- reinstalling
==> ERROR: A failure occurred in make_image_desktop().
    Aborting...
 --> overlayfs umount: [/var/lib/manjaro-tools/buildiso/lxqt/x86_64/desktopfs]
 --> umount overlayfs: [/var/lib/manjaro-tools/buildiso/lxqt/x86_64/desktopfs]
T+
You need to pull the latest changes and/or edit the file Packages-Desktop
:slight_smile: no the tools are not broken - your configuration and package list needs maintenance :slight_smile:
I discovered this, “changed title”, thanks again, again, for the many, many troubles he got me out of @linux-aarhus
[Solved]
T+ = See you later
You can use this snippet in your manjaro-tools.conf instead the url to the build_mirror
Translation
Você pode usar este trecho em seu manjaro-tools.conf em vez da url para o build_mirror
It has always been the intention to allow the iso builder to change the buildmirror.
This can be any active mirror from the mirror pool - but some will be better than others depending on the host and the location of the user.
Translation
Sempre foi a intenção permitir que o construtor iso altere o buildmirror.
Pode ser qualquer espelho ativo do pool de espelhos - mas alguns serão melhores que outros, dependendo do host e da localização do usuário.
The snippet parses the first mirror from your currrent mirrorlist and assign the result as the build_mirror to be used.
Then you don’t have to ever worry about your build_mirror
Translation
O trecho analisa o primeiro espelho de sua lista de espelhos atual e atribui o resultado como o build_mirror a ser usado.
Então você não precisa se preocupar com seu build_mirror
You are “one” of the best Linux professors I’ve had during these 15 or 18 years of using Linux, thanks Teacher @linux-aarhus
Translate:
Você é “um” dos melhores professores Linux que eu tive durante esses meus 15 ou 18 anos de uso do Linux, valeu Professor
T+ = See you later
I really appreciate the label - that is exactly what I try to do - educate - I am not perfect - nor am I a professor - just an advanced student :slight_smile:
Translation
Aprecio muito o rótulo - é exatamente isso que tento fazer - educar - não sou perfeito - nem sou professor - apenas um aluno avançado
