Hi, i am new to linux and I got manjaro yesterday. I recently got a dual-monitor setup and I am having some problems. The second monitor connects and works great but for some reason manjaro’s display configuration things that the monitor is short when in reality it is almost as tall as my primary HD monitor.
Any fix for this?
Output for hwinfo --monitor
20: None 00.0: 10002 LCD Monitor
[Created at monitor.125]
Unique ID: rdCR.CypCFsUS2i4
Parent ID: VCu0.wJIUTVdwtH6
Hardware Class: monitor
Model: “LG ELECTRONICS LG IPS FULLHD”
Vendor: GSM “LG ELECTRONICS”
Device: eisa 0x5ab8 “LG IPS FULLHD”
Serial ID: “”
Resolution: 720x400@70Hz
Resolution: 640x480@60Hz
Resolution: 640x480@75Hz
Resolution: 800x600@60Hz
Resolution: 800x600@75Hz
Resolution: 1024x768@60Hz
Resolution: 1024x768@75Hz
Resolution: 1280x1024@75Hz
Resolution: 1152x864@75Hz
Resolution: 1280x1024@60Hz
Resolution: 1920x1080@60Hz
Year of Manufacture: 2014
Week of Manufacture: 1
Detailed Timings #0:
Horizontal: 1920 2008 2052 2200 (+88 +132 +280) +hsync
Vertical: 1080 1084 1089 1125 (+4 +9 +45) +vsync
Frequencies: 148.50 MHz, 67.50 kHz, 60.00 Hz
Driver Info #0:
Max. Resolution: 1920x1080
Vert. Sync Range: 56-75 Hz
Hor. Sync Range: 30-83 kHz
Bandwidth: 148 MHz
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #9 (VGA compatible controller)
21: None 00.0: 10002 LCD Monitor
Unique ID: rdCR.wWS0KIChKF7
Parent ID: _Znp._z_vTxnAFi7
Model: “V196HQL”
Vendor: ACR
Device: eisa 0x033d “V196HQL”
Serial ID: “LY0SS0018504”
Resolution: 640x480@67Hz
Resolution: 640x480@72Hz
Resolution: 800x600@56Hz
Resolution: 800x600@72Hz
Resolution: 832x624@75Hz
Resolution: 1024x768@70Hz
Resolution: 1280x720@60Hz
Resolution: 1280x960@60Hz
Resolution: 1366x768@60Hz
Week of Manufacture: 43
Horizontal: 1366 1436 1579 1792 (+70 +213 +426) +hsync
Vertical: 768 771 774 798 (+3 +6 +30) +vsync
Frequencies: 85.50 MHz, 47.71 kHz, 59.79 Hz
Driver Info #0:
Max. Resolution: 1280x1024
Vert. Sync Range: 56-76 Hz
Hor. Sync Range: 31-83 kHz
Bandwidth: 85 MHz
Attached to: #17 (Display controller)
