When prompting for the luks password, Plymouth tries to show the keyboard layout, but with the Manjaro theme it gets it wrong, showing “No” for “Us”.
This is a known theming bug that was solved long ago on Debian: Bug #2061676 “plymouth luks input prompt displays wrong keyboard...” : Bugs : kubuntu-settings package : Ubuntu. Most likely the keymap render image in the theme is out-of-date.
Can you confirm which version of plymouth-theme-manjaro you have installed?
Are you missing some configuration?
What is the content of
/etc/mkinitcpio.conf?
/etc/locale.conf?
/etc/vconsole.conf?
It is plymouth-theme-manjaro 2.2-5 [Installed]
I dobt. Switching from the manjaro to the spinner theme fixes the issue. The /usr/share/plymouth/themes/manjaro/keymap-render.png is visibly different from the one in spinner and might be the problem.
In fact, copying /usr/share/plymouth/themes/spinner/keymap-render.png into /usr/share/plymouth/themes/manjaro/keymap-render.png is enough to fix the issue. The file appears to be stale in the manjaro theme package.
Moderator edit: Merged consecutive replies
Users should not be modifying files in the system belonging to a package. The next time plymouth-theme-manjaro is updated, it will overwrite that file from the package.
If there’s an issue with plymouth-theme-manjaro, we can take a look and see what needs to be changed.
Fixed with plymouth-theme-manjaro 2.2-7.
Right, but that was a just quick test to see where the issue was, that I completed cleaned up right after and that I did in order to provide feedback on where the issue was. Sorry if I gave the impression of suggesting it to other users.
Nice to read. Looking forward to the next update.
