Manjaro System repair / integrity check?
We actually promote Manjaro, rather than Arch. The Manjaro Live installer is probably more in keeping. :slight_smile:
Hello,
i use your instruction and become an result, but what i must to to fix every point in the result, i didn’t know.
the Results:
sudo paccheck --files --file-properties --db-files --quiet --sha256sum
catfish: '/usr/lib/python3.12/site-packages/catfish_lib/__pycache__/catfishconfig.cpython-312.pyc' modification time mismatch (expected 2024-04-06 21:23:59)
catfish: '/usr/lib/python3.12/site-packages/catfish_lib/__pycache__/catfishconfig.cpython-312.pyc' size mismatch (expected 3.15 K)
catfish: '/usr/lib/python3.12/site-packages/catfish_lib/__pycache__/catfishconfig.cpython-312.pyc' sha256sum mismatch (expected 5d7035efa1933bcd31845ea6cbcc7ad4b4c4da68d1eb6cef361c761d44dd4a98)
cups: '/etc/cups/classes.conf' permission mismatch (expected 644)
cups: '/etc/cups/printers.conf' permission mismatch (expected 644)
cups: '/etc/cups/subscriptions.conf' permission mismatch (expected 644)
filesystem: '/root' permission mismatch (expected 750)
firefox: '/usr/lib/firefox/distribution/distribution.ini' modification time mismatch (expected 2024-10-14 12:20:19)
firefox: '/usr/lib/firefox/distribution/distribution.ini' size mismatch (expected 176.00 B)
firefox: '/usr/lib/firefox/distribution/distribution.ini' sha256sum mismatch (expected 80e0667f8db562df7fe0ccc01a21a0c42427f38713491f478df3b50903161836)
ghc-libs: '/usr/lib/ghc-9.2.8/lib/package.conf.d/package.cache' modification time mismatch (expected 2024-02-25 21:08:22)
ghc-libs: '/usr/lib/ghc-9.2.8/lib/package.conf.d/package.cache' size mismatch (expected 175.81 K)
ghc-libs: '/usr/lib/ghc-9.2.8/lib/package.conf.d/package.cache' sha256sum mismatch (expected dcc1d9e7b71e236a7fc4fd580e15bc86c7141dccd97340d36cf0cffd3e9bd52a)
grub: '/etc/grub.d/30_uefi-firmware' missing file
warning: grub: '/etc/grub.d/30_uefi-firmware' read error (No such file or directory)
java-runtime-common: '/usr/lib/jvm/default' symlink target mismatch (expected /dev/null)
java-runtime-common: '/usr/lib/jvm/default' modification time mismatch (expected 2023-01-19 13:33:57)
java-runtime-common: '/usr/lib/jvm/default-runtime' symlink target mismatch (expected /dev/null)
java-runtime-common: '/usr/lib/jvm/default-runtime' modification time mismatch (expected 2023-01-19 13:33:57)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.alias' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.alias' size mismatch (expected 1.55 M)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.alias.bin' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.alias.bin' size mismatch (expected 1.51 M)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.builtin.alias.bin' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.builtin.bin' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.dep' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.dep' size mismatch (expected 830.72 K)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.dep.bin' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.dep.bin' size mismatch (expected 1.06 M)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.devname' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.softdep' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.symbols' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.symbols' size mismatch (expected 703.01 K)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.symbols.bin' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.symbols.bin' size mismatch (expected 858.00 K)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.weakdep' modification time mismatch (expected 2024-10-08 03:45:34)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.alias' sha256sum mismatch (expected 6ae77ed0d1bd3808c2e6088ed008a3f48aac8d7f60e877ecaf15509a8811d7dc)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.alias.bin' sha256sum mismatch (expected 8e06e2c0d9f54c003c467cb9cb6fea8b1a32cc724acfd0f090c034e50b318c00)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.dep' sha256sum mismatch (expected 1f66276f62455ac9f878e8cc23f7a18977ae2b0af7c5f373bea5c4b99a8efe16)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.dep.bin' sha256sum mismatch (expected 75fe19813d1c62606750d0b70de0f143bd5b4903f73eab829552326fdfa20c45)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.symbols' sha256sum mismatch (expected 111840f6bdeff3ef7f6968c7dadb035a6d0f6bdda8e8b1238a40969a39ac0ec1)
linux610: '/usr/lib/modules/6.10.13-3-MANJARO/modules.symbols.bin' sha256sum mismatch (expected 8f9de6e1c5728bcaf9082b026ea9f31aebe0d90e4c6627c37db6b5b796a2e312)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.alias' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.alias' size mismatch (expected 1.56 M)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.alias.bin' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.alias.bin' size mismatch (expected 1.52 M)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.builtin.alias.bin' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.builtin.bin' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.dep' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.dep' size mismatch (expected 837.96 K)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.dep.bin' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.dep.bin' size mismatch (expected 1.07 M)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.devname' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.softdep' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.symbols' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.symbols' size mismatch (expected 710.66 K)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.symbols.bin' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.symbols.bin' size mismatch (expected 866.83 K)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.weakdep' modification time mismatch (expected 2024-10-08 12:18:59)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.alias' sha256sum mismatch (expected 371ea35906edafd9bd1933e8ab352e3e362c7c37b15a4b5e0f6c90771d1c6e56)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.alias.bin' sha256sum mismatch (expected d7b2246d022e81ced0c2961d3110d6f20c338867d182355788d543c2af2a40c5)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.dep' sha256sum mismatch (expected bbec83ee0c3e12b4aa11d0747c59fce92424b7e66473d786ae206c4ef166c108)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.dep.bin' sha256sum mismatch (expected 24cf046da265f3493784298628d8904321ae6621fc4d31a9c7d5fcd528d61495)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.symbols' sha256sum mismatch (expected 175b5e62aa377d3100ca79cd81126694dacc143b6b47af9da08aed33e33882d0)
linux611: '/usr/lib/modules/6.11.2-4-MANJARO/modules.symbols.bin' sha256sum mismatch (expected 5fa6b6a4175a50737813151b080a48e9900d81a4a4208987dc5bf169d78de7f1)
manjaro-zsh-config: '/root' permission mismatch (expected 750)
manjaro-zsh-config: '/root/.zshrc' permission mismatch (expected 640)
networkmanager: '/usr/lib/NetworkManager/conf.d/20-connectivity.conf' modification time mismatch (expected 2024-10-10 23:17:37)
networkmanager: '/usr/lib/NetworkManager/conf.d/20-connectivity.conf' size mismatch (expected 58.00 B)
networkmanager: '/usr/lib/NetworkManager/conf.d/20-connectivity.conf' sha256sum mismatch (expected 983b35fc1846785932135c4fcda467a5d790b86bc50599ebafa8fe064ba53489)
nodejs-nopt: '/usr/bin/nopt' permission mismatch (expected 755)
pacman-mirrors: '/usr/share/pacman-mirrors/mirrors.json' modification time mismatch (expected 2024-07-03 18:57:49)
pacman-mirrors: '/usr/share/pacman-mirrors/mirrors.json' size mismatch (expected 21.31 K)
pacman-mirrors: '/usr/share/pacman-mirrors/mirrors.json' sha256sum mismatch (expected 541279697d398765bb3302209de8fc8033fb9f8799b3d7bd59c99bf09d6c8827)
shadow: '/usr/bin/groupmems' permission mismatch (expected 750)
shadow: '/usr/bin/groupmems' GID mismatch (expected 0/root)
snapd: '/var/lib/snapd/cache' permission mismatch (expected 755)
snapd: '/var/lib/snapd/cookie' permission mismatch (expected 755)
systemd: '/var/log/journal' GID mismatch (expected 0/root)
thunderbird: '/usr/lib/thunderbird/distribution/distribution.ini' modification time mismatch (expected 2024-10-11 10:58:16)
thunderbird: '/usr/lib/thunderbird/distribution/distribution.ini' size mismatch (expected 152.00 B)
thunderbird: '/usr/lib/thunderbird/distribution/distribution.ini' sha256sum mismatch (expected bc3aae2cc00dc9806f54606f98d967366a2ba7223f6a3ad1c658a653ebff5569)
vlc: '/usr/lib/vlc/plugins/plugins.dat' modification time mismatch (expected 2024-09-12 23:21:57)
vlc: '/usr/lib/vlc/plugins/plugins.dat' size mismatch (expected 300.40 K)
vlc: '/usr/lib/vlc/plugins/plugins.dat' sha256sum mismatch (expected 4471b745c7ea25bfab7c090b8dc907dfd006a166252a9e01e730dcee4a42015c)
Greetings from Germany
Heiko
It’s fine.
You don’t need to do anything.
Except perhaps:
ask the autor (or look at the script)
how it determines the things it expects to see.
It’s mostly complaints about mtime not matching expectations
and some permission being different - again:
not wrong, but different than expected
Some checksum mismatches, but again:
you should know where the expected values come from
in order to gauge what a mismatch means.
On second look:
this is the reason
Thanks.
Bye
Heiko
