I just installed Manjaro Sway but it doesn’t have “manjaro-sway” repository, it really doesn’t have that repository anymore or should I add it?
As I understand it, the Sway repository is specifically for aarch64
, but if you’re using an x86-64
machine, then you should stick with the standard repositories.
It’s the x86_64 version, the Sway community edition.
I remember that before the repositories came by default: core, extra, community, multilib and manjaro-sway
But now it only has: core, extra, community, multilib
