Manjaro swapping agressively
I have an 8GB ram and swappiness set to 1, but still I see swap being used at pretty much normal RAM usage.
My inxi -Fazy
  Kernel: 5.11.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=76839173-ded3-47ed-b743-7d503298909d rw quiet apparmor=1
  security=apparmor resume=UUID=0eb2fb6f-7b97-4079-afe0-7595022800e5
  udev.log_priority=3
  Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8575 v: 21.16 serial: <filter> UEFI: AMI v: F.21
  date: 11/13/2020
  ID-1: BAT0 charge: 46.8 Wh (100.0%) condition: 46.8/46.8 Wh (100.0%)
  volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial: N/A
  status: Full
  Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
  microcode: DE cache: L2: 12 MiB
  bogomips: 62431
  Speed: 1142 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 1142 2: 3989
  3: 3101 4: 2252 5: 1331 6: 1444 7: 964 8: 800 9: 800 10: 800 11: 800 12: 800
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
  vendor: Hewlett-Packard driver: nvidia v: 460.80
  alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
  class-ID: 0300
  Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
  bus-ID: 1-6:3 chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
  bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Sound Server-1: ALSA v: k5.11.19-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.27 running: no
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
  port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
  Local Storage: total: 1.14 TiB used: 62.23 GiB (5.3%)
  model: PC SN720 SDAPNTW-256G-1006 size: 238.47 GiB block-size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
  serial: <filter> rev: 10112006 temp: 44.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
  rotation: 7200 rpm serial: <filter> rev: A3T0 scheme: GPT
  ID-1: / raw-size: 40 GiB size: 39.12 GiB (97.80%) used: 15.02 GiB (38.4%)
  fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 82.2 MiB (32.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 196.95 GiB size: 192.86 GiB (97.92%)
  used: 47.06 GiB (24.4%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
  Kernel: swappiness: 1 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 10 GiB used: 66.9 MiB (0.7%) priority: -2
  dev: /dev/nvme0n1p6 maj-min: 259:6
  System Temperatures: cpu: 66.0 C mobo: N/A
  Processes: 302 Uptime: 2h 30m wakeups: 2 Memory: 7.58 GiB
  used: 4.13 GiB (54.5%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 Packages: pacman: 1368 lib: 432 Shell: Bash v: 5.1.8
  running-in: yakuake inxi: 3.3.04
I made my swap partition on an Nvme SSD ( which I read later is a pretty bad thing to do) and hence want it to activate when absolutely needed ( so as to not activate OOM).
You can use ZRam instead of swap. It compresses a part of RAM inside the RAM itself. While it consumes some CPU cycles, it would be faster than a HDD or SSD based swap.
Quote:
Swap is not generally about getting emergency memory
You can try zswap or zram for compressed swap in ram:
https://wiki.archlinux.org/title/Zswap
https://wiki.archlinux.org/title/Improving_performance#Zram_or_zswap
Is it possible to bring the 10GB I allocated to swap back to Root?
This happened during a game. While I have plenty of RAM left, and swappiness set to 10, still large amount of swap is being used.
The system will page out as the memory contention increases. Swappiness of 10 ain’t gonna prevent that.
Zswap solved it for me, thanks!
