Hello,
My problem is a bit confusing, and I don’t know where to search.
The issue is simple: manjaro sometimes suspends on its own, while I’m using it. The session locks itself, and before I have enough time to unlock it, the computer goes into suspend. I have no idea what causes it, and I don’t know where to search; since the problem appears randomly, I can’t even try to find out if an application is causing it.
I couldn’t find anyone else with the same issues, and I’m getting a bit desperate because although relatively uncommon, you can understand that it’s really annoying.
My computer isn’t a laptop by the way, so it’s not a “closed lid” problem as I could find online…
Thanks in advance for any help or advice.
