Ok i’ve reboot and … Same issue, the nvdia drivers break my system
so uninstall them:
sudo mhwd -r pci video-nvidia
and install the older ones:
sudo mhwd -i pci video-nvidia-470xx
reboot:
systemctl reboot
pay attention to the commands
How can’i block update of thé drivers if it works ?
if the 470 works you dont have to block anything…
Nope same issue
I try with 390xx ?
so uninstall them:
sudo mhwd -r pci video-nvidia-470xx
reboot:
systemctl reboot
im going to sleep so tomorrow we can try to troubleshoot it
Okay thanks you, i will try some thing toomorow too ^^ thanks you vert much
I found this on arch wiki:
Due to FS#74886/FS#74891, nvidia doesn’t boot on Linux 5.18 on systems with Intel CPUs. Until this is fixed, a workaround is disabling the Indirect Branch Tracking CPU security feature by setting the
ibt=off
kernel parameter from the bootloader. This security feature is responsible for mitigating a class of exploit techniques, but is deemed safe as a temporary stopgap solution
I try this when i Come back from work
you could try it, but you are not using 5.18, nor do you have it installed, and you tried booting with different kernels… the log from the startx
command above will provide more info … so when you are back copy the log from this command here:
cat /var/log/Xorg.0.log
use formatting, click this icon in the editor: </> and copy the log inside it
yes I will do that within the hour.
Oh, you’re right, I found that this morning and I thought I was in 5.18
so:
[ 6.800] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.801] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.801] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/0000:01:00.0/drm/card0
[ 6.805] (--) PCI:*(1@0:0:0) 10de:1407:10de:1407 rev 161, Mem @ 0xfd000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000dc00/128, BIOS @ 0x????????/131072
[ 6.805] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 6.805] (II) LoadModule: "glx"
[ 6.807] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.817] (II) Module glx: vendor="X.Org Foundation"
[ 6.817] compiled for 1.21.1.3, module version = 1.0.0
[ 6.817] ABI class: X.Org Server Extension, version 10.0
[ 6.819] (==) Matched modesetting as autoconfigured driver 0
[ 6.819] (==) Matched fbdev as autoconfigured driver 1
[ 6.819] (==) Matched vesa as autoconfigured driver 2
[ 6.819] (==) Assigned the driver to the xf86ConfigLayout
[ 6.819] (II) LoadModule: "modesetting"
[ 6.819] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 6.822] (II) Module modesetting: vendor="X.Org Foundation"
[ 6.822] compiled for 1.21.1.3, module version = 1.21.1
[ 6.822] Module class: X.Org Video Driver
[ 6.822] ABI class: X.Org Video Driver, version 25.2
[ 6.822] (II) LoadModule: "fbdev"
[ 6.822] (WW) Warning, couldn't open module fbdev
[ 6.822] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 6.822] (II) LoadModule: "vesa"
[ 6.822] (WW) Warning, couldn't open module vesa
[ 6.822] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 6.822] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 6.823] (II) modeset(0): using drv /dev/dri/card0
[ 6.823] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 6.823] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 6.823] (==) modeset(0): RGB weight 888
[ 6.823] (==) modeset(0): Default visual is TrueColor
[ 6.823] (II) Loading sub module "glamoregl"
[ 6.823] (II) LoadModule: "glamoregl"
[ 6.823] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 6.831] (II) Module glamoregl: vendor="X.Org Foundation"
[ 6.831] compiled for 1.21.1.3, module version = 1.0.1
[ 6.831] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.139] (II) modeset(0): glamor X acceleration enabled on NV126
[ 7.139] (II) modeset(0): glamor initialized
[ 7.139] (==) modeset(0): VariableRefresh: disabled
[ 7.139] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 7.174] (II) modeset(0): Output VGA-1 has no monitor section
[ 7.175] (II) modeset(0): Output DVI-D-1 has no monitor section
[ 7.242] (II) modeset(0): Output HDMI-1 has no monitor section
[ 7.277] (II) modeset(0): EDID for output VGA-1
[ 7.277] (II) modeset(0): Manufacturer: IVM Model: 6138 Serial#: 3046
[ 7.277] (II) modeset(0): Year: 2018 Week: 28
[ 7.277] (II) modeset(0): EDID Version: 1.3
[ 7.277] (II) modeset(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 7.277] (II) modeset(0): Sync: Separate
[ 7.277] (II) modeset(0): Max Image Size [cm]: horiz.: 53 vert.: 30
[ 7.277] (II) modeset(0): Gamma: 2.20
[ 7.278] (II) modeset(0): DPMS capabilities: Off; RGB/Color Display
[ 7.278] (II) modeset(0): First detailed timing is preferred mode
[ 7.278] (II) modeset(0): redX: 0.645 redY: 0.332 greenX: 0.315 greenY: 0.619
[ 7.278] (II) modeset(0): blueX: 0.151 blueY: 0.065 whiteX: 0.313 whiteY: 0.329
[ 7.278] (II) modeset(0): Supported established timings:
[ 7.278] (II) modeset(0): 720x400@70Hz
[ 7.278] (II) modeset(0): 640x480@60Hz
[ 7.278] (II) modeset(0): 640x480@75Hz
[ 7.278] (II) modeset(0): 800x600@60Hz
[ 7.278] (II) modeset(0): 800x600@75Hz
[ 7.278] (II) modeset(0): 832x624@75Hz
[ 7.278] (II) modeset(0): 1024x768@60Hz
[ 7.278] (II) modeset(0): 1024x768@75Hz
[ 7.278] (II) modeset(0): 1280x1024@75Hz
[ 7.278] (II) modeset(0): 1152x864@75Hz
[ 7.278] (II) modeset(0): Manufacturer's mask: 0
[ 7.278] (II) modeset(0): Supported standard timings:
[ 7.278] (II) modeset(0): #0: hsize: 1152 vsize 720 refresh: 60 vid: 113
[ 7.278] (II) modeset(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 7.278] (II) modeset(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 7.278] (II) modeset(0): #3: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 7.278] (II) modeset(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 7.278] (II) modeset(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 7.278] (II) modeset(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 7.278] (II) modeset(0): Supported detailed timing:
[ 7.278] (II) modeset(0): clock: 148.5 MHz Image Size: 531 x 299 mm
[ 7.278] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 7.278] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 7.278] (II) modeset(0): Serial No: 1156282843046
[ 7.278] (II) modeset(0): Ranges: V min: 55 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 185 MHz
[ 7.278] (II) modeset(0): Monitor name: PL2483H
[ 7.278] (II) modeset(0): EDID (in hex):
[ 7.278] (II) modeset(0): 00ffffffffffff0026cd3861e60b0000
[ 7.278] (II) modeset(0): 1c1c010368351e782a0ef5a555509e26
[ 7.278] (II) modeset(0): 105054a56b80710081408180a940b300
[ 7.278] (II) modeset(0): 9500d1c00101023a801871382d40582c
[ 7.278] (II) modeset(0): 4500132b2100001e000000ff00313135
[ 7.278] (II) modeset(0): 36323832383433303436000000fd0037
[ 7.278] (II) modeset(0): 4c1e5312000a202020202020000000fc
[ 7.278] (II) modeset(0): 00504c32343833480a202020202000ab
[ 7.278] (II) modeset(0): Not using default mode "1600x1200" (bad mode clock/interlace/doublescan)
[ 7.278] (II) modeset(0): Not using default mode "1440x810" (bad mode clock/interlace/doublescan)
[ 7.278] (II) modeset(0): Not using default mode "1600x900" (bad mode clock/interlace/doublescan)
[ 7.278] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 7.278] (II) modeset(0): Not using default mode "1920x1200" (bad mode clock/interlace/doublescan)
[ 7.278] (II) modeset(0): Printing probed modes for output VGA-1
[ 7.278] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 7.278] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[ 7.278] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 7.278] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 7.278] (II) modeset(0): Modeline "1600x1200"x65.0 175.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (81.2 kHz d)
[ 7.278] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 7.278] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 7.278] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 7.278] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 7.278] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 7.278] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 7.278] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 7.278] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 7.278] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 7.278] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 7.278] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 7.278] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 7.278] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 7.278] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 7.278] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 7.278] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 7.278] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 7.278] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 7.278] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 7.278] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 7.278] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 7.278] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 7.278] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 7.278] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 7.278] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 7.278] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 7.278] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 7.278] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 7.278] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 7.279] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 7.279] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 7.279] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 7.279] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 7.279] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 7.279] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 7.279] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 7.279] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 7.279] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 7.279] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 7.279] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 7.279] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 7.279] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 7.279] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 7.279] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 7.279] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 7.279] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 7.279] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 7.279] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 7.279] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 7.279] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 7.279] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 7.279] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 7.279] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 7.279] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 7.279] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 7.279] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 7.279] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 7.279] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 7.279] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 7.279] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 7.279] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 7.279] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 7.279] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 7.279] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 7.279] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 7.279] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 7.279] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 7.279] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 7.279] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 7.279] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 7.279] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 7.280] (II) modeset(0): EDID for output DVI-D-1
[ 7.348] (II) modeset(0): EDID for output HDMI-1
[ 7.349] (II) modeset(0): Manufacturer: SNC Model: 2360 Serial#: 16843009
[ 7.349] (II) modeset(0): Year: 2019 Week: 37
[ 7.349] (II) modeset(0): EDID Version: 1.3
[ 7.349] (II) modeset(0): Digital Display Input
[ 7.349] (II) modeset(0): Max Image Size [cm]: horiz.: 52 vert.: 29
[ 7.349] (II) modeset(0): Gamma: 2.20
[ 7.349] (II) modeset(0): DPMS capabilities: Off
[ 7.349] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 7.349] (II) modeset(0): First detailed timing is preferred mode
[ 7.349] (II) modeset(0): redX: 0.643 redY: 0.342 greenX: 0.317 greenY: 0.628
[ 7.349] (II) modeset(0): blueX: 0.148 blueY: 0.064 whiteX: 0.313 whiteY: 0.329
[ 7.349] (II) modeset(0): Supported established timings:
[ 7.349] (II) modeset(0): 720x400@70Hz
[ 7.349] (II) modeset(0): 640x480@60Hz
[ 7.349] (II) modeset(0): 640x480@67Hz
[ 7.349] (II) modeset(0): 640x480@72Hz
[ 7.349] (II) modeset(0): 640x480@75Hz
[ 7.349] (II) modeset(0): 800x600@56Hz
[ 7.349] (II) modeset(0): 800x600@60Hz
[ 7.349] (II) modeset(0): 800x600@72Hz
[ 7.349] (II) modeset(0): 800x600@75Hz
[ 7.349] (II) modeset(0): 832x624@75Hz
[ 7.349] (II) modeset(0): 1024x768@60Hz
[ 7.349] (II) modeset(0): 1024x768@70Hz
[ 7.349] (II) modeset(0): 1024x768@75Hz
[ 7.349] (II) modeset(0): 1280x1024@75Hz
[ 7.349] (II) modeset(0): Manufacturer's mask: 0
[ 7.349] (II) modeset(0): Supported standard timings:
[ 7.349] (II) modeset(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 7.349] (II) modeset(0): #1: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 7.349] (II) modeset(0): #2: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 7.349] (II) modeset(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 7.349] (II) modeset(0): #4: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 7.349] (II) modeset(0): Supported detailed timing:
[ 7.349] (II) modeset(0): clock: 148.5 MHz Image Size: 521 x 293 mm
[ 7.349] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 7.349] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 7.349] (II) modeset(0): clock: 85.5 MHz Image Size: 521 x 293 mm
[ 7.349] (II) modeset(0): h_active: 1360 h_sync: 1424 h_sync_end 1536 h_blank_end 1792 h_border: 0
[ 7.349] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 795 v_border: 0
[ 7.349] (II) modeset(0): Ranges: V min: 50 V max: 76 Hz, H min: 15 H max: 83 kHz, PixClock max 175 MHz
[ 7.349] (II) modeset(0): Monitor name: SKP_E5-24
[ 7.349] (II) modeset(0): clock: 74.2 MHz Image Size: 521 x 293 mm
[ 7.349] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 7.349] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 7.349] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 7.349] (II) modeset(0): clock: 27.0 MHz Image Size: 521 x 293 mm
[ 7.349] (II) modeset(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 7.349] (II) modeset(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 7.349] (II) modeset(0): Number of EDID sections to follow: 1
[ 7.349] (II) modeset(0): EDID (in hex):
[ 7.349] (II) modeset(0): 00ffffffffffff004dc3602301010101
[ 7.349] (II) modeset(0): 251d010380341d782aa725a45751a026
[ 7.349] (II) modeset(0): 105054bfef008180a9c0b300950081c0
[ 7.349] (II) modeset(0): 010101010101023a801871382d40582c
[ 7.349] (II) modeset(0): 450009252100001e662150b051001b30
[ 7.349] (II) modeset(0): 4070360009252100001e000000fd0032
[ 7.349] (II) modeset(0): 4c0f5311000a202020202020000000fc
[ 7.349] (II) modeset(0): 00534b505f45352d32340a202020016e
[ 7.349] (II) modeset(0): 020322724f0102030405060790111213
[ 7.349] (II) modeset(0): 1415169f230907078301000065030c00
[ 7.349] (II) modeset(0): 1000011d8018711c1620582c25000925
[ 7.349] (II) modeset(0): 2100009e011d007251d01e206e285500
[ 7.349] (II) modeset(0): 09252100001e8c0ad08a20e02d10103e
[ 7.349] (II) modeset(0): 96000925210000180000000000000000
[ 7.349] (II) modeset(0): 00000000000000000000000000000000
[ 7.349] (II) modeset(0): 00000000000000000000000000000048
[ 7.349] (II) modeset(0): Not using default mode "1440x810" (bad mode clock/interlace/doublescan)
[ 7.349] (II) modeset(0): Not using default mode "1600x900" (bad mode clock/interlace/doublescan)
[ 7.349] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 7.349] (II) modeset(0): Printing probed modes for output HDMI-1
[ 7.349] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 7.349] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 7.349] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 7.349] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 7.350] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 7.350] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 7.350] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 7.350] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 7.350] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 7.350] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 7.350] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 7.350] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 7.350] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 7.350] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 7.350] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 7.350] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "1360x768"x60.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 7.350] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 7.350] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 7.350] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 7.350] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 7.350] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 7.350] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 7.350] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 7.350] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 7.350] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 7.350] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 7.350] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 7.350] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 7.350] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 7.350] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 7.350] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 7.350] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 7.350] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 7.350] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 7.350] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 7.350] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 7.350] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 7.350] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 7.350] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 7.350] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 7.350] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.350] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 7.350] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 7.350] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 7.350] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 7.350] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 7.350] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 7.350] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 7.350] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 7.350] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 7.350] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 7.350] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 7.350] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 7.350] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 7.350] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 7.350] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 7.350] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 7.350] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 7.350] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 7.350] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 7.350] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 7.350] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 7.350] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 7.350] (II) modeset(0): Output VGA-1 connected
[ 7.350] (II) modeset(0): Output DVI-D-1 disconnected
[ 7.350] (II) modeset(0): Output HDMI-1 connected
[ 7.350] (II) modeset(0): Using spanning desktop for initial modes
[ 7.350] (II) modeset(0): Output VGA-1 using initial mode 1920x1080 +0+0
[ 7.350] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +1920+0
[ 7.351] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.351] (==) modeset(0): DPI set to (96, 96)
[ 7.351] (II) Loading sub module "fb"
[ 7.351] (II) LoadModule: "fb"
[ 7.351] (II) Module "fb" already built-in
[ 7.376] (==) modeset(0): Backing store enabled
[ 7.376] (==) modeset(0): Silken mouse enabled
[ 7.380] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 7.380] (==) modeset(0): DPMS enabled
[ 7.380] (II) modeset(0): [DRI2] Setup complete
[ 7.380] (II) modeset(0): [DRI2] DRI driver: nouveau
[ 7.380] (II) modeset(0): [DRI2] VDPAU driver: nouveau
[ 7.380] (II) Initializing extension Generic Event Extension
[ 7.380] (II) Initializing extension SHAPE
[ 7.381] (II) Initializing extension MIT-SHM
[ 7.381] (II) Initializing extension XInputExtension
[ 7.381] (II) Initializing extension XTEST
[ 7.381] (II) Initializing extension BIG-REQUESTS
[ 7.381] (II) Initializing extension SYNC
[ 7.381] (II) Initializing extension XKEYBOARD
[ 7.381] (II) Initializing extension XC-MISC
[ 7.382] (II) Initializing extension SECURITY
[ 7.382] (II) Initializing extension XFIXES
[ 7.382] (II) Initializing extension RENDER
[ 7.382] (II) Initializing extension RANDR
[ 7.382] (II) Initializing extension COMPOSITE
[ 7.382] (II) Initializing extension DAMAGE
[ 7.382] (II) Initializing extension MIT-SCREEN-SAVER
[ 7.383] (II) Initializing extension DOUBLE-BUFFER
[ 7.383] (II) Initializing extension RECORD
[ 7.383] (II) Initializing extension DPMS
[ 7.383] (II) Initializing extension Present
[ 7.383] (II) Initializing extension DRI3
[ 7.383] (II) Initializing extension X-Resource
[ 7.383] (II) Initializing extension XVideo
[ 7.383] (II) Initializing extension XVideo-MotionCompensation
[ 7.383] (II) Initializing extension GLX
[ 7.390] (II) AIGLX: Loaded and initialized nouveau
[ 7.390] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 7.390] (II) Initializing extension XFree86-VidModeExtension
[ 7.390] (II) Initializing extension XFree86-DGA
[ 7.390] (II) Initializing extension XFree86-DRI
[ 7.390] (II) Initializing extension DRI2
[ 7.394] (II) modeset(0): Damage tracking initialized
[ 7.394] (II) modeset(0): Setting screen physical size to 1016 x 285
[ 7.493] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 7.493] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.493] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.493] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.493] (II) LoadModule: "libinput"
[ 7.494] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.499] (II) Module libinput: vendor="X.Org Foundation"
[ 7.499] compiled for 1.21.1.3, module version = 1.2.1
[ 7.499] Module class: X.Org XInput Driver
[ 7.499] ABI class: X.Org XInput driver, version 24.4
[ 7.499] (II) Using input driver 'libinput' for 'Power Button'
[ 7.499] (**) Power Button: always reports core events
[ 7.499] (**) Option "Device" "/dev/input/event1"
[ 7.509] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.509] (II) event1 - Power Button: device is a keyboard
[ 7.510] (II) event1 - Power Button: device removed
[ 7.529] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 7.529] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.529] (**) Option "xkb_layout" "fr"
[ 7.555] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.555] (II) event1 - Power Button: device is a keyboard
[ 7.556] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 7.556] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.556] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.556] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.556] (II) Using input driver 'libinput' for 'Power Button'
[ 7.556] (**) Power Button: always reports core events
[ 7.556] (**) Option "Device" "/dev/input/event0"
[ 7.557] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 7.557] (II) event0 - Power Button: device is a keyboard
[ 7.557] (II) event0 - Power Button: device removed
[ 7.586] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 7.586] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 7.586] (**) Option "xkb_layout" "fr"
[ 7.587] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 7.587] (II) event0 - Power Button: device is a keyboard
[ 7.588] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[ 7.588] (II) No input driver specified, ignoring this device.
[ 7.588] (II) This device may have been added with another device file.
[ 7.589] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 7.589] (II) No input driver specified, ignoring this device.
[ 7.589] (II) This device may have been added with another device file.
[ 7.589] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[ 7.589] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 7.590] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[ 7.590] (II) No input driver specified, ignoring this device.
[ 7.590] (II) This device may have been added with another device file.
[ 7.590] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[ 7.591] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event16)
[ 7.591] (II) No input driver specified, ignoring this device.
[ 7.591] (II) This device may have been added with another device file.
[ 7.591] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event2)
[ 7.591] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 7.591] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.591] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 7.591] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 7.591] (**) dakai PS/2+USB Keyboard: always reports core events
[ 7.591] (**) Option "Device" "/dev/input/event2"
[ 7.593] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 7.593] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 7.593] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 7.613] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:0E6A:02C0.0001/input/input2/event2"
[ 7.613] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard" (type: KEYBOARD, id 8)
[ 7.613] (**) Option "xkb_layout" "fr"
[ 7.614] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 7.614] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 7.616] (II) config/udev: Adding input device dakai PS/2+USB Keyboard Consumer Control (/dev/input/event3)
[ 7.616] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 7.616] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 7.616] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 7.616] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 7.616] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 7.616] (**) Option "Device" "/dev/input/event3"
[ 7.617] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 7.617] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 7.617] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 7.636] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: needs a virtual subdevice
[ 7.636] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 7.636] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard Consumer Control" (type: MOUSE, id 9)
[ 7.636] (**) Option "AccelerationScheme" "none"
[ 7.636] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 7.636] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 7.636] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 7.638] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 7.638] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 7.639] (II) config/udev: Adding input device dakai PS/2+USB Keyboard System Control (/dev/input/event4)
[ 7.639] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 7.639] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 7.639] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 7.639] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard System Control'
[ 7.639] (**) dakai PS/2+USB Keyboard System Control: always reports core events
[ 7.639] (**) Option "Device" "/dev/input/event4"
[ 7.640] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 7.640] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 7.640] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 7.666] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input4/event4"
[ 7.666] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard System Control" (type: KEYBOARD, id 10)
[ 7.666] (**) Option "xkb_layout" "fr"
[ 7.668] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 7.668] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 7.669] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event5)
[ 7.669] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 7.669] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.669] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 7.669] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 7.669] (**) dakai PS/2+USB Keyboard: always reports core events
[ 7.669] (**) Option "Device" "/dev/input/event5"
[ 7.671] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 7.671] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 7.672] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 7.696] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input6/event5"
[ 7.696] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard" (type: KEYBOARD, id 11)
[ 7.696] (**) Option "xkb_layout" "fr"
[ 7.698] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 7.698] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 7.699] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event6)
[ 7.699] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[ 7.699] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[ 7.699] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[ 7.699] (**) USB OPTICAL MOUSE : always reports core events
[ 7.700] (**) Option "Device" "/dev/input/event6"
[ 7.757] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 7.758] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 7.758] (II) event6 - USB OPTICAL MOUSE : device removed
[ 7.793] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.0/0003:4E53:5406.0003/input/input7/event6"
[ 7.793] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE " (type: MOUSE, id 12)
[ 7.793] (**) Option "AccelerationScheme" "none"
[ 7.793] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[ 7.793] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[ 7.793] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[ 7.853] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 7.853] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 7.856] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 7.856] (II) No input driver specified, ignoring this device.
[ 7.856] (II) This device may have been added with another device file.
[ 7.858] (II) config/udev: Adding input device USB OPTICAL MOUSE Keyboard (/dev/input/event7)
[ 7.858] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 7.858] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.858] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 7.858] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 7.858] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 7.858] (**) Option "Device" "/dev/input/event7"
[ 7.862] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 7.862] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 7.863] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 7.889] (II) libinput: USB OPTICAL MOUSE Keyboard: needs a virtual subdevice
[ 7.889] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 7.889] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE Keyboard" (type: MOUSE, id 13)
[ 7.890] (**) Option "AccelerationScheme" "none"
[ 7.890] (**) USB OPTICAL MOUSE Keyboard: (accel) selected scheme none/0
[ 7.890] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration factor: 2.000
[ 7.890] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration threshold: 4
[ 7.894] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 7.894] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 7.897] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event17)
[ 7.897] (II) No input driver specified, ignoring this device.
[ 7.897] (II) This device may have been added with another device file.
[ 7.898] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event18)
[ 7.898] (II) No input driver specified, ignoring this device.
[ 7.898] (II) This device may have been added with another device file.
[ 7.899] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event19)
[ 7.899] (II) No input driver specified, ignoring this device.
[ 7.899] (II) This device may have been added with another device file.
[ 7.900] (II) config/udev: Adding input device HDA ATI SB Line Out (/dev/input/event20)
[ 7.900] (II) No input driver specified, ignoring this device.
[ 7.900] (II) This device may have been added with another device file.
[ 7.901] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event21)
[ 7.901] (II) No input driver specified, ignoring this device.
[ 7.901] (II) This device may have been added with another device file.
[ 7.902] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 7.902] (II) No input driver specified, ignoring this device.
[ 7.902] (II) This device may have been added with another device file.
[ 7.922] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 7.922] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 7.922] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 7.922] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 7.922] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 7.922] (**) Option "Device" "/dev/input/event3"
[ 7.922] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: is a virtual subdevice
[ 7.923] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 7.923] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard Consumer Control" (type: KEYBOARD, id 14)
[ 7.923] (**) Option "xkb_layout" "fr"
[ 7.923] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 7.923] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.923] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 7.923] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 7.923] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 7.923] (**) Option "Device" "/dev/input/event7"
[ 7.923] (II) libinput: USB OPTICAL MOUSE Keyboard: is a virtual subdevice
[ 7.923] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 7.923] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE Keyboard" (type: KEYBOARD, id 15)
[ 7.983] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 7.983] (II) No input driver specified, ignoring this device.
[ 7.983] (II) This device may have been added with another device file.
[ 7.983] (II) config/udev: removing device USB OPTICAL MOUSE Keyboard
[ 7.984] (II) UnloadModule: "libinput"
[ 7.984] (II) config/udev: removing device USB OPTICAL MOUSE Keyboard
[ 7.984] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 8.009] (II) UnloadModule: "libinput"
[ 8.011] (II) config/udev: Adding input device USB OPTICAL MOUSE Keyboard (/dev/input/event7)
[ 8.011] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 8.011] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.011] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 8.011] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 8.011] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 8.011] (**) Option "Device" "/dev/input/event7"
[ 8.015] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 8.015] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 8.016] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 8.039] (II) libinput: USB OPTICAL MOUSE Keyboard: needs a virtual subdevice
[ 8.039] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 8.040] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE Keyboard" (type: MOUSE, id 13)
[ 8.040] (**) Option "AccelerationScheme" "none"
[ 8.040] (**) USB OPTICAL MOUSE Keyboard: (accel) selected scheme none/0
[ 8.040] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration factor: 2.000
[ 8.040] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration threshold: 4
[ 8.042] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 8.043] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 8.043] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 8.043] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.043] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 8.043] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 8.043] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 8.043] (**) Option "Device" "/dev/input/event7"
[ 8.043] (II) libinput: USB OPTICAL MOUSE Keyboard: is a virtual subdevice
[ 8.044] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 8.044] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE Keyboard" (type: KEYBOARD, id 15)
[ 8.044] (**) Option "xkb_layout" "fr"
[ 8.044] (II) config/udev: removing device dakai PS/2+USB Keyboard System Control
[ 8.044] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 8.059] (II) UnloadModule: "libinput"
[ 8.061] (II) config/udev: Adding input device dakai PS/2+USB Keyboard System Control (/dev/input/event4)
[ 8.061] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 8.061] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 8.061] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 8.061] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard System Control'
[ 8.061] (**) dakai PS/2+USB Keyboard System Control: always reports core events
[ 8.061] (**) Option "Device" "/dev/input/event4"
[ 8.063] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 8.063] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 8.064] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 8.086] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input4/event4"
[ 8.086] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard System Control" (type: KEYBOARD, id 10)
[ 8.086] (**) Option "xkb_layout" "fr"
[ 8.091] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 8.092] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 8.093] (II) config/udev: removing device dakai PS/2+USB Keyboard Consumer Control
[ 8.093] (II) UnloadModule: "libinput"
[ 8.093] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 8.106] (II) UnloadModule: "libinput"
[ 8.108] (II) config/udev: Adding input device dakai PS/2+USB Keyboard Consumer Control (/dev/input/event3)
[ 8.108] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 8.108] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.108] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 8.108] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 8.108] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 8.108] (**) Option "Device" "/dev/input/event3"
[ 8.112] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 8.113] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 8.114] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 8.136] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: needs a virtual subdevice
[ 8.136] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 8.136] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard Consumer Control" (type: MOUSE, id 9)
[ 8.136] (**) Option "AccelerationScheme" "none"
[ 8.136] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 8.136] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 8.136] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 8.138] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 8.138] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 8.138] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 8.138] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.138] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 8.138] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 8.138] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 8.138] (**) Option "Device" "/dev/input/event3"
[ 8.138] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: is a virtual subdevice
[ 8.138] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 8.138] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard Consumer Control" (type: KEYBOARD, id 14)
[ 8.138] (**) Option "xkb_layout" "fr"
[ 8.139] (II) config/udev: removing device dakai PS/2+USB Keyboard
[ 8.139] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 8.156] (II) UnloadModule: "libinput"
[ 8.157] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event2)
[ 8.158] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 8.158] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.158] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 8.158] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 8.158] (**) dakai PS/2+USB Keyboard: always reports core events
[ 8.158] (**) Option "Device" "/dev/input/event2"
[ 8.161] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 8.161] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 8.162] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 8.186] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:0E6A:02C0.0001/input/input2/event2"
[ 8.186] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard" (type: KEYBOARD, id 8)
[ 8.186] (**) Option "xkb_layout" "fr"
[ 8.188] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 8.188] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 8.189] (II) config/udev: removing device dakai PS/2+USB Keyboard
[ 8.189] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 8.206] (II) UnloadModule: "libinput"
[ 8.207] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event5)
[ 8.207] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 8.207] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.207] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 8.207] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 8.207] (**) dakai PS/2+USB Keyboard: always reports core events
[ 8.207] (**) Option "Device" "/dev/input/event5"
[ 8.208] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 8.208] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 8.208] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 8.226] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input6/event5"
[ 8.226] (II) XINPUT: Adding extended input device "dakai PS/2+USB Keyboard" (type: KEYBOARD, id 11)
[ 8.226] (**) Option "xkb_layout" "fr"
[ 8.228] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 8.228] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 8.228] (II) config/udev: removing device USB OPTICAL MOUSE
[ 8.228] (II) event6 - USB OPTICAL MOUSE : device removed
[ 8.273] (II) UnloadModule: "libinput"
[ 8.273] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event6)
[ 8.273] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[ 8.273] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[ 8.273] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[ 8.273] (**) USB OPTICAL MOUSE : always reports core events
[ 8.273] (**) Option "Device" "/dev/input/event6"
[ 8.333] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 8.333] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 8.334] (II) event6 - USB OPTICAL MOUSE : device removed
[ 8.373] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.0/0003:4E53:5406.0003/input/input7/event6"
[ 8.373] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE " (type: MOUSE, id 12)
[ 8.373] (**) Option "AccelerationScheme" "none"
[ 8.373] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[ 8.373] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[ 8.373] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[ 8.432] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 8.433] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 8.435] (II) config/udev: Adding input device C-Media Electronics Inc. USB Audio Device (/dev/input/event8)
[ 8.435] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "evdev keyboard catchall"
[ 8.435] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "libinput keyboard catchall"
[ 8.435] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "system-keyboard"
[ 8.435] (II) Using input driver 'libinput' for 'C-Media Electronics Inc. USB Audio Device'
[ 8.435] (**) C-Media Electronics Inc. USB Audio Device: always reports core events
[ 8.435] (**) Option "Device" "/dev/input/event8"
[ 8.438] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 8.439] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 8.439] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 8.473] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.2/usb1/1-2/1-2.4/1-2.4:1.3/0003:0D8C:0014.0005/input/input11/event8"
[ 8.473] (II) XINPUT: Adding extended input device "C-Media Electronics Inc. USB Audio Device" (type: KEYBOARD, id 16)
[ 8.473] (**) Option "xkb_layout" "fr"
[ 8.474] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 8.474] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 10.263] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 16.616] (II) modeset(0): EDID vendor "SNC", prod id 9056
[ 16.616] (II) modeset(0): Using EDID range info for horizontal sync
[ 16.616] (II) modeset(0): Using EDID range info for vertical refresh
[ 16.616] (II) modeset(0): Printing DDC gathered Modelines:
[ 16.616] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 16.616] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 16.616] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 16.616] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 16.616] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 16.616] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.616] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 16.616] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 16.616] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 16.616] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 16.616] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 16.616] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 16.616] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 16.616] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 16.616] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 16.616] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 16.616] (II) modeset(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 16.616] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 16.616] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 16.616] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 16.616] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 16.616] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 16.616] (II) modeset(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 16.616] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 16.616] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 16.616] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 16.616] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 16.616] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 16.616] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 34.720] (II) modeset(0): EDID vendor "SNC", prod id 9056
[ 34.720] (II) modeset(0): Using hsync ranges from config file
[ 34.720] (II) modeset(0): Using vrefresh ranges from config file
[ 34.720] (II) modeset(0): Printing DDC gathered Modelines:
[ 34.720] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 34.720] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 34.720] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 34.720] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 34.720] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 34.720] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 34.720] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 34.720] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 34.720] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 34.720] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 34.720] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 34.720] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 34.720] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 34.720] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 34.720] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 34.720] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 34.720] (II) modeset(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 34.720] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 34.720] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 34.720] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 34.720] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 34.720] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 34.720] (II) modeset(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 34.720] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 34.720] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 34.720] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 34.720] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 34.720] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 34.720] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 35.932] (II) modeset(0): EDID vendor "SNC", prod id 9056
[ 35.932] (II) modeset(0): Using hsync ranges from config file
[ 35.932] (II) modeset(0): Using vrefresh ranges from config file
[ 35.932] (II) modeset(0): Printing DDC gathered Modelines:
[ 35.932] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 35.932] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 35.932] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 35.932] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 35.932] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 35.932] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 35.932] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 35.932] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 35.932] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 35.932] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 35.932] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 35.932] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 35.932] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 35.932] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 35.932] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 35.932] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 35.932] (II) modeset(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 35.932] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 35.932] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 35.932] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 35.932] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 35.932] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 35.932] (II) modeset(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 35.932] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 35.932] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 35.932] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 35.932] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 35.932] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 35.932] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 36.078] (II) modeset(0): Allocate new frame buffer 3840x1920 stride
[ 36.281] (II) modeset(0): Allocate new frame buffer 3000x1920 stride
nothing really there…
lets do the possible fix from your link above:
go to /etc/default/grub open the grub config file and edit this following line:
GRUB_CMDLINE_LINUX_DEFAULT
and inside the “” quotes add this parameter:
ibt=off
- dont remove anything just add it there to the existing parameters… then copy the line, just to check if its correct
so in /etc/default i’ve a grub file, but i aslo have a folder “grub-brtfs” with a “config” file in it. i guess, it’s je first one.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX="ibt=off "
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
i’ve had ibt=off
, i’m good ?
no remove it from the:
GRUB_CMDLINE_LINUx line, and add it here:
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 ibt=off"
like that ?
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="ibt=off"
GRUB_CMDLINE_LINUX=""
GRUB_GFXMODE=auto
no i posted you the whole line:
this is how it should look like
this time it’s the good one ^^… ?
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 ibt=off"
no it is not, this is how the line should look like:
but it looks like this:
oh sorry, i’ve noticedit but i d’ont have the time to correct.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
so, i save and try the drivers ?
