Manjaro stuck at /dev/sda1 clean:
so remove it:
rm /home/test/.Xauthority
and pay attention to the command, dont make any mistakes
then reboot:
systemctl reboot
Ok, i try
Same issue it won’t boots After /dev/sda1: clean …
and your username is test? do you have more than one user?
No it’s just test (it’s a long story)
take picture of this:
mhwd -l && mhwd -li
mhwd-kernel -li
and also picture from this:
find /etc/X11/ -name "*.conf"
I will continue, after you tried to fix your xserver, what i dont think, thats the problem.
unisntall nvidia and see if that helps:
sudo mhwd -r pci video-nvidia
systemctl reboot
pay attention to the commands
Sorry i don’t understand
Ok you are my héro ! It’s that !
But the issue IS not finish i’m on black screen After enter my password. I try toi remove 1 of m’y 2 screen
so can you boot normally or no?
Yes thx you !!! Do you think i Can reinstall NVIDIA drivers ?
yes go to system settings/hardware configuration, and click auto install proprietary driver, when its done, reboot and see if you can normally boot
Yep, thx i try. I’ve Lost thé config of my second screen but’s it’s not important, i Can Do it later.
