Manjaro stuck at boot screen
I installed Manjaro besides Windows (dual boot) on my Dell XPS 13 (9310) and it was stuck at the boot screen.
How I dual booted:
I made the Windows partition smaller (within Windows) and replaced the empty partition with the Manjaro partition.
I am also in need of help.
I have a dell XPS as well. I have it dual booted with Manjaro for over a year now. Randomly the windows side will not boot.
There was just a windows 10 update that occurred, I am also low on space on the windows side.
Thanks in advance
I have found out the problem:
You need to change RAID (in Storage settings) to AHCI.
Windows needs to be configured to work with AHCI:
support(dot)thinkcritical(dot)com/kb/articles/switch-windows-10-from-raid-ide-to-ahci
(idk why I can’t use a normal link)
