Hello friends,
I am developing Manjaro Starter. It inspired by Manjaro Hello. It is at half of the way, but I want to learn your ideas and opinions.
Here some screens:
Hello friends,
Here some screens:
The kernel order is misleading: linux54 should appear first.
It’s likely caused by the alphabetical order (“510” < “54”).
Careful also if using numeral order, as you’d also have issues with the 4.x series:
44 < 49 < 54 < 414 < 419 < 510
kinda snazzy lookin
Wow I like the UI design, it is like GitHub!
Will it replace Manjaro Hello? Will it puts Manjaro Settings Manager inside it?
It wouldn’t make sense to put Manjaro Settings Manager in it. It is aimed towards new Linux / Manjaro users. It’s like a starter pack to help set up your system.
OK, I found that it can install kernels so I think that it can replace MSM
Besides, it is much more prettier than MSM
That’s not it’s aim. Think of it like a post-installation setup wizard similar to manjaro-application-utility
(Applications button in Manjaro Hello).
