I really like Manjaro, after installing 21.1.5 KDE version, on first update notification and updating, Wifi won’t work properly and would be unstable, it won’t show networks available, and ip addr
won’t show ip assigned, after checking packages updated, it was interesting, I saw two packages which could be related to network and wifi, inxi
, network manager
. but I am not sure which package is resulted to this issue, just I know a fresh install of Manjaro 21.1.5, wifi is working properly. please help to resolve this issue. it is really severe, because almost it is unusable.
inxi
does not affect wifi.
But it would be what you use to share system info. See here:
dmseg | grep wlo1
[ 4255.823737] audit: type=1111 audit(1635064969.163:99): pid=427 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=device-disconnect interface="wlo1" ifindex=3 pid=1516 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 4269.237472] wlo1: authenticate with cc:be:59:d1:2a:23
[ 4269.768043] wlo1: send auth to cc:be:59:d1:2a:23 (try 1/3)
[ 4269.769659] wlo1: authenticated
[ 4269.774707] wlo1: associate with cc:be:59:d1:2a:23 (try 1/3)
[ 4269.784011] wlo1: RX AssocResp from cc:be:59:d1:2a:23 (capab=0x411 status=0 aid=2)
[ 4269.784383] wlo1: associated
[ 4269.891679] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 4635.007493] wlo1: deauthenticating from cc:be:59:d1:2a:23 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 4646.139992] wlo1: authenticate with cc:be:59:d1:2a:23
[ 4646.665679] wlo1: send auth to cc:be:59:d1:2a:23 (try 1/3)
[ 4646.668080] wlo1: authenticated
[ 4646.672379] wlo1: associate with cc:be:59:d1:2a:23 (try 1/3)
[ 4646.684722] wlo1: RX AssocResp from cc:be:59:d1:2a:23 (capab=0x411 status=0 aid=2)
[ 4646.685092] wlo1: associated
[ 4646.769215] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 5989.308328] wlo1: deauthenticating from cc:be:59:d1:2a:23 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 6005.783278] wlo1: authenticate with cc:be:59:d1:2a:23
[ 6006.313304] wlo1: send auth to cc:be:59:d1:2a:23 (try 1/3)
[ 6006.315487] wlo1: authenticated
[ 6006.319870] wlo1: associate with cc:be:59:d1:2a:23 (try 1/3)
[ 6006.329813] wlo1: RX AssocResp from cc:be:59:d1:2a:23 (capab=0x411 status=0 aid=2)
[ 6006.330217] wlo1: associated
[ 6006.413597] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 8011.824559] wlo1: deauthenticating from cc:be:59:d1:2a:23 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 8028.317643] wlo1: authenticate with cc:be:59:d1:2a:23
[ 8028.847902] wlo1: send auth to cc:be:59:d1:2a:23 (try 1/3)
[ 8028.849603] wlo1: authenticated
[ 8028.854378] wlo1: associate with cc:be:59:d1:2a:23 (try 1/3)
[ 8028.863799] wlo1: RX AssocResp from cc:be:59:d1:2a:23 (capab=0x411 status=0 aid=2)
[ 8028.864158] wlo1: associated
[ 8028.911395] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 9057.118281] wlo1: deauthenticating from cc:be:59:d1:2a:23 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 9073.642289] wlo1: authenticate with cc:be:59:d1:2a:23
[ 9074.171930] wlo1: send auth to cc:be:59:d1:2a:23 (try 1/3)
[ 9074.173540] wlo1: authenticated
[ 9074.178529] wlo1: associate with cc:be:59:d1:2a:23 (try 1/3)
[ 9074.189014] wlo1: RX AssocResp from cc:be:59:d1:2a:23 (capab=0x411 status=0 aid=2)
[ 9074.189391] wlo1: associated
[ 9074.250229] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready```
lspci:
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 07)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 10)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #14 (rev f0)
00:1d.6 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #15 (rev f0)
00:1d.7 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #16 (rev f0)
00:1f.0 ISA bridge: Intel Corporation HM470 Chipset LPC/eSPI Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822BE 802.11a/b/g/n/ac WiFi adapter
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)```
inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=671cdfb6-0761-45be-9fe2-dbb9dc393789 rw quiet apparmor=1
security=apparmor resume=UUID=82195435-472d-41a9-b6fe-ca6f927ecc70
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 84DA v: 93.18 serial: <filter> UEFI: AMI v: F.05
date: 06/15/2018
ID-1: BAT0 charge: 28.6 Wh (43.3%) condition: 66.0/66.0 Wh (100.0%)
volts: 14.9 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: Discharging
RAM: total: 23.33 GiB used: 2.8 GiB (12.0%)
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 9 MiB bogomips: 52815
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.2
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-7:3 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 6 state: up address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
Local Storage: total: 238.47 GiB used: 8.38 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: TM8PS7256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: S110 scheme: GPT
ID-1: / raw-size: 212.51 GiB size: 208.11 GiB (97.93%) used: 8.38 GiB (4.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 671cdfb6-0761-45be-9fe2-dbb9dc393789
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: CA54-D3B9
ID-1: swap-1 type: partition size: 25.66 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 82195435-472d-41a9-b6fe-ca6f927ecc70
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-6:2 info: Lite-On HP Wide Vision HD Camera type: Video
Device-2: 1-7:3 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nouveau temp: 34.0 C
Processes: 330 Uptime: 14h 1m wakeups: 6 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1199 lib: 330
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: yakuake
inxi: 3.3.06```
This information is for the time which system is not updated, I’m afraid to update it, because I have a lot of work to do, all will be lost. after update it won’t work properly.
Hi, Another clue is when it is connected to battery this will happen. when it’s on AC it won’t happen
So you say wifi doesn’t work properly on battery but it works when its plugged?
Lets do a little experiment,unplug the laptop,run this command
sudo tlp ac
And test if the wifi is working.
I think power saving is also a good check - though it may be the module rather than TLP.
@masoudesm Maybe also check
modinfo rtw88_8822be | sed -n '/depends/,$p'
