Manjaro-specific packages which need an update
development
package
manjaro
#121
Thanks for the tip!
Anyway, I have solved it with sandbox and I will use only NextCloud in the near future. :wink:
#122
Wow, I didn’t know that at all. How REALLY BAD PRACTICE, Booooo :-1: !
This makes me want to stop maintaining this package inside our repos even more.
Shall we drop it back to AUR, what do you guys think?
[Stable Update] 2017-09-23 - Kernels, Mesa, PulseAudio, GST, Python, Haskell
Skype and Dropbox dropped as repo packages?
#123
There’s no reason to package the software if the software then “unpackages” itself.
#124
Drop it
#125
removed.
#126
On unstable, Octopi does not show dropbox as available in the Manjaro repositories.
But on stable, it looks not yet demoted to the AUR. It does not show in:
$ pacman -Qm
And it does not have the alien head on Octopi:
#127
Just wait for that change to trickle down.
#128
It has trickled down to Stable, just as you predicted.
Normally I like to remove packages that get demoted to the AUR. Since Dropbox seems to update itself, can I safely remove the packaged version of Dropbox?
#129
The only reason to maintain also the aur version is if the appearence of dropbox is ugly ( icons , gui etc ) and aur maintainer do some patch … with the dropbox autoupdate this is not correct i think…
#130
Hi,
qupzilla has changed name to Falkon web browse, and is now a part of kde applications.
From https://github.com/QupZilla/qupzilla :
QupZilla was renamed to Falkon and moved to KDE infrastructure
New repository is now available at https://phabricator.kde.org/source/falkon/.
This repository at GitHub will only be used for 2.2 release and after that will be made read-only.
So, please remove qupzilla and add falkon instead.
#131
We have to ask at @excalibur1234 and at @Kirek if are interested of porting this … qupzilla come from Arch so maybe Arch in the near future switch into Falkon
#132
As Ste74 said is packaged upstream
and there isn’t a stable version out
#133
i assume that “qupzilla” will be replaced with “falkon” on our systems automatically in the not so distant future when it comes down from arch linux to manjaro.
#134
If someone is using it on iso, please remember to update iso-profiles repo when the change comes…
#135
@Ste74 Timeshift 17.10 is out
#136
Yep, i see … it contain my command to allow work on wayland… at soon possible push in our repo :grin:
#137
Looks promising. I will start testing it soon. If it works as it should I’ll ad an option for setting it up in manjaro-architect now that it is in the repos.
#138
The package group mate-extra-gtk3 is obsolete.
#139
3 posts were split to a new topic: Megasync doesn’t compile
Megasync doesn't compile
#142
Now that I am receiving Dropbox updates from the AUR, I believe it may cause two instances to start on the first re-boot after an AUR update of Dropbox. Is anybody else getting this:
This is usually because of a permissions error. Storing your home folder on a network share can also cause an error.
Get more help at https://www.dropbox.com/c/help/permissions_error
Please contact Dropbox support with the following info for help: /tmp/dropbox_errorAqFAFv.txt
However, if I:
sudo pacman -Rsn dropbox
Then I needed to manually execute from $HOME
~/.dropbox-dist/dropboxd
