Manjaro-specific packages which need an update
You're right - git-version works :wink:
I've changed to this version - is already available in unstable.
gtkhash needs a rebuild for nettle 3.5.1:
$ gtkhash
gtkhash: error while loading shared libraries: libnettle.so.6: cannot open shared object file: No such file or directory
Thanks for the info - done in unstable
plymouth needs update
dash-to-panel got a major update:
done :wink:
mint-themes is out of date. We have 1.7.8-1.
Upstream is at version 1.8.1.
@oberon
Update is done - available in unstable.
Thanks for the info!
@oberon menulibre has updated to 2.2.1 from 2.2.0. :slight_smile:
Also done :wink:
Currently, in vhba-module.install we have
post_remove() {
  _updatemod
  groupdel cdemu
which means that deleting any version of the module (when its corresponding kernel goes EOL for example) will delete the cdemu group (even if other versions corresponding to other kernels are still installed).
This (no cdemu group) doesn't seem to affect the functionality of CDEmu, as far as my usage goes, but systemd complains about it at every boot
systemd-udevd[233]: Specified group 'cdemu' unknown
Can we check if other versions of the vhba module are installed before deleting the group, maybe something like this if it's correct
pacman -Qqs linux.*vhba-module &>/dev/null || groupdel cdemu
A post was merged into an existing topic: Non-Manjaro packages which have been flagged as needing an update
ckbcomp is out of date. The package is currently at 1.175-1, which ships a version that is at least one year old.
Upstream is at version 1.193.
Last packager is @oberon.
According to pacman -Sii, here's the packages that depends on ckbcomp.
[awesome@i56400 Joel]$ pacman -Sii ckbcomp
Repository      : extra
Version         : 1.175-1
Description     : Compile a XKB keyboard description to a keymap suitable for
                  loadkeys or kbdcontrol
Architecture    : any
URL             : https://anonscm.debian.org/cgit/d-i/console-setup.git/
Licenses        : GPL2
Groups          : None
Provides        : None
Depends On      : perl
Optional Deps   : None
Required By     : calamares  calamares-git  keyboardctl
                  manjaro-settings-manager
Thanks. Updated.
Linux 5.2 RT available.
https://mirrors.edge.kernel.org/pub/linux/kernel/projects/rt/5.2/
@oberon
Yes I'm at it, thanks! Normally I wait für the 1st patch update before switching oder basekernel, but seems it takes longer this time and with our current still being at 5.0... I think we should go ahead :wink:
Sorry for not posting here first. @Ste74 will have to do a little update on brisk menu : [Announcement] Brisk Menu 0.6.0 for Mate is out.
Done in unstable :wink:
@Ste74 why did you downgrade kvantum-theme-matcha to 20190613-1?
I have an issue in virtualbox interface with this version which the previous one (the newest one) had resolved. Now the issue is back.
I'm using gnome.
Could you upgrade it please?
